45
Is there any way to show that
$$\sum\limits_{k = - \infty }^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}} = \frac{1}{a} + \sum\limits_{k = 1}^\infty {{{\left( { - 1} \right)}^k}\left( {\frac{1}{{a - k}} + \frac{1}{{a + k}}} \right)}=\frac{\pi }{{\sin \pi a}}} $$
Where $0 < a = \dfrac{n+1}{m} < 1$
The infinite series is equal to
$$\int\limits_{ - \infty }^\infty {\frac{{{e^{at}}}}{{{e^t} + 1}}dt} $$
To get to the result, I split the integral at $x=0$ and use the convergent series in $(0,\infty)$ and $(-\infty,0)$ respectively:
$$\frac{1}{{1 + {e^t}}} = \sum\limits_{k = 0}^\infty {{{\left( { - 1} \right)}^k}{e^{ - \left( {k + 1} \right)t}}} $$
$$\frac{1}{{1 + {e^t}}} = \sum\limits_{k = 0}^\infty {{{\left( { - 1} \right)}^k}{e^{kt}}} $$
Since $0 < a < 1$
$$\eqalign{ & \mathop {\lim }\limits_{t \to 0} \frac{{{e^{\left( {k + a} \right)t}}}}{{k + a}} - \mathop {\lim }\limits_{t \to - \infty } \frac{{{e^{\left( {k + a} \right)t}}}}{{k + a}} = \frac{1}{{k + a}} \cr & \mathop {\lim }\limits_{t \to \infty } \frac{{{e^{\left( {a - k - 1} \right)t}}}}{{k + a}} - \mathop {\lim }\limits_{t \to 0} \frac{{{e^{\left( {a - k - 1} \right)t}}}}{{k + a}} = - \frac{1}{{a - \left( {k + 1} \right)}} \cr} $$
A change in the indices will give the desired series.
Although I don't mind direct solutions from tables and other sources, I prefer an elaborated answer.
Here's the solution in terms of $\psi(x)$. By separating even and odd indices we can get
$$\eqalign{ & \sum\limits_{k = 0}^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} = \sum\limits_{k = 0}^\infty {\frac{1}{{a + 2k}}} - \sum\limits_{k = 0}^\infty {\frac{1}{{a + 2k + 1}}} \cr & \sum\limits_{k = 0}^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a - k}}} = \sum\limits_{k = 0}^\infty {\frac{1}{{a - 2k}}} - \sum\limits_{k = 0}^\infty {\frac{1}{{a - 2k - 1}}} \cr} $$
which gives
$$\sum\limits_{k = 0}^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} = \frac{1}{2}\psi \left( {\frac{{a + 1}}{2}} \right) - \frac{1}{2}\psi \left( {\frac{a}{2}} \right)$$
$$\sum\limits_{k = 0}^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a - k}}} = \frac{1}{2}\psi \left( {1 - \frac{a}{2}} \right) - \frac{1}{2}\psi \left( {1 - \frac{{a + 1}}{2}} \right) + \frac{1}{a}$$
Then
$$\eqalign{ & \sum\limits_{k = - \infty }^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} = \sum\limits_{k = 0}^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} + \sum\limits_{k = 0}^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a - k}}} - \frac{1}{a} = \cr & = \left\{ {\frac{1}{2}\psi \left( {1 - \frac{a}{2}} \right) - \frac{1}{2}\psi \left( {\frac{a}{2}} \right)} \right\} - \left\{ {\frac{1}{2}\psi \left( {1 - \frac{{a + 1}}{2}} \right) - \frac{1}{2}\psi \left( {\frac{{a + 1}}{2}} \right)} \right\} \cr} $$
But using the reflection formula one has
$$\eqalign{ & \frac{1}{2}\psi \left( {1 - \frac{a}{2}} \right) - \frac{1}{2}\psi \left( {\frac{a}{2}} \right) = \frac{\pi }{2}\cot \frac{{\pi a}}{2} \cr & \frac{1}{2}\psi \left( {1 - \frac{{a + 1}}{2}} \right) - \frac{1}{2}\psi \left( {\frac{{a + 1}}{2}} \right) = \frac{\pi }{2}\cot \frac{{\pi \left( {a + 1} \right)}}{2} = - \frac{\pi }{2}\tan \frac{{\pi a}}{2} \cr} $$
So the series become
$$\eqalign{ & \sum\limits_{k = - \infty }^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} = \frac{\pi }{2}\left\{ {\cot \frac{{\pi a}}{2} + \tan \frac{{\pi a}}{2}} \right\} \cr & \sum\limits_{k = - \infty }^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} = \pi \csc \pi a \cr} $$
The last being an application of a trigonometric identity.
Pedro
  • 122,002
  • It seems that using contour integration with the residue theorem should work here. Have you tried that? – savick01 Feb 17 '12 at 22:22
    @savick01 I know nothing about Complex Analisys. I'd prefer the use of the Digamma Function, which I'm familiar with. – Pedro Feb 17 '12 at 22:23
  • I suppose you are interpreting that infinite sum as $\frac{1}{a} + \sum_{k=1}^{\infty} (-1)^k(\frac{1}{a+k} + \frac{1}{a-k})$. – Aryabhata Feb 17 '12 at 22:31
  • @Aryabhata What do you mean? – Pedro Feb 17 '12 at 22:32
  • @Peter: The order in which you combine them would matter I would think. – Aryabhata Feb 17 '12 at 22:33
  • @Aryabhata I honestly can't understand you. – Pedro Feb 17 '12 at 22:33
  • @Peter: Ok, different question: What is the $1000^{th}$ terms of the series you just gave? – Aryabhata Feb 17 '12 at 22:34
  • @Aryabhata I know what you mean, but I think the notation is understandable and succint. – Pedro Feb 17 '12 at 22:37
  • @Peter: No. Different mathematicians might have different interpretations. Why be ambiguous deliberately? – Aryabhata Feb 17 '12 at 22:42
  • @Aryabhata I don't think its ambiguous. If you think it is, just edit it and let's move on. – Pedro Feb 17 '12 at 22:45
  • @Peter: I don't care. I was only trying to help. If you don't want it, your problem. – Aryabhata Feb 17 '12 at 22:46
  • @Aryabhata It's OK. Let's don't make this an argument. I accept your suggestion. – Pedro Feb 17 '12 at 22:48
  • @Peter : Let's continue our discussion here : in what course did you encounter this question? – Patrick Da Silva Feb 17 '12 at 23:28
  • @PatrickDaSilva I was trying to solve $$\int\limits_0^\infty {\frac{{{x^m}}}{{1 + {x^n}}}dx} $$ which led me to ($x^n = e^t$) $$\frac{1}{n}\int\limits_{-\infty}^\infty {\frac{{{e^{at}}}}{{1 + {e^t}}}dx} $$ which led me to $$\frac{1}{n}\sum\limits_{k = - \infty }^\infty {\frac{{{{\left( { - 1} \right)}^k}}}{{a + k}}} $$ ($a = \dfrac{m+1}{n}$) – Pedro Feb 17 '12 at 23:32
  • I've had fun computing on wolfram alpha the pairs $(m,n) = (1,1), (1,2), (2,1), (2,2)$ and it always diverges. $(1,3)$ converges to $\frac{2\pi}{ 3 \sqrt 3}$. Since $\frac{3 \sqrt 3}2 > 1$, I expect that something went wrong in your calculations that gave you $\pi/\sin(a\pi)$ since $\sin(ax)$ is never greater than $1$. But again, this is just calculations... maybe I am wrong somewhere. – Patrick Da Silva Feb 17 '12 at 23:39
  • But you turned it upside-down. $\frac{2}{3\sqrt{3}}<1$ – Pedro Feb 17 '12 at 23:44
  • @PatrickDaSilva Also note that I impose an important condition $n+1<m$ which is not satisfied by you values. (I edited to make it consistent with the other post, so in you last case you have $m=3$ and $n=1$ so the criterion is met.) – Pedro Feb 18 '12 at 02:17
  • I found this post today by chance and it reminds me of a generalisation which I had asked some years ago at https://math.stackexchange.com/q/2483738/72031 – Paramanand Singh Oct 27 '23 at 11:01
EDIT: The classical demonstration of this is obtained by expanding in Fourier series the function $\cos(zx)$ with $x\in(-\pi,\pi)$.
Let's detail Smirnov's proof (in "Course of Higher Mathematics 2 VI.1 Fourier series") :
$\cos(zx)$ is an even function of $x$ so that the $\sin(kx)$ terms disappear and the Fourier expansion is given by : $$\cos(zx)=\frac{a_0}2+\sum_{k=1}^{\infty} a_k\cdot \cos(kx),\ \text{with}\ \ a_k=\frac2{\pi} \int_0^{\pi} \cos(zx)\cos(kx) dx$$
Integration is easy and $a_0=\frac2{\pi}\int_0^{\pi} \cos(zx) dx= \frac{2\sin(\pi z)}{\pi z}$ while
$a_k= \frac2{\pi}\int_0^{\pi} \cos(zx) \cos(kx) dx=\frac1{\pi}\left[\frac{\sin((z+k)x)}{z+k}+\frac{\sin((z-k)x)}{z-k}\right]_0^{\pi}=(-1)^k\frac{2z\sin(\pi z)}{\pi(z^2-k^2)}$
so that for $-\pi \le x \le \pi$ :
$$ \cos(zx)=\frac{2z\sin(\pi z)}{\pi}\left[\frac1{2z^2}+\frac{\cos(1x)}{1^2-z^2}-\frac{\cos(2x)}{2^2-z^2}+\frac{\cos(3x)}{3^2-z^2}-\cdots\right] $$
Setting $x=0$ returns your equality : $$ \frac1{\sin(\pi z)}=\frac{2z}{\pi}\left[\frac1{2z^2}-\sum_{k=1}^{\infty}\frac{(-1)^k}{k^2-z^2}\right] $$
while $x=\pi$ returns the $\mathrm{cotg}$ formula :
$$ \cot(\pi z)=\frac1{\pi}\left[\frac1{z}-\sum_{k=1}^{\infty}\frac{2z}{k^2-z^2}\right] $$ (Euler used this one to find closed forms of $\zeta(2n)$)
The $\cot\ $ formula is linked to $\Psi$ via the Reflection formula : $$\Psi(1-x)-\Psi(x)=\pi\cot(\pi x)$$
The $\sin$ formula is linked to $\Gamma$ via Euler's reflection formula : $$\Gamma(1-x)\cdot\Gamma(x)=\frac{\pi}{\sin(\pi x)}$$
Raymond Manzoni
  • 43,021
  • 86
  • 140
  • Very nice. Guess I'll have to study Fourier series... What is the convergence domain of the given series? Do you have a link to Smirnov's book? – Pedro Feb 17 '12 at 23:23
  • check my solution with $\psi(x)$, that's what I wanted! – Pedro Feb 18 '12 at 05:29
  • @Peter: Nice! So we just had to observe (:-)) that $\tan(\frac a2)+\cot(\frac a2)= \frac 2{\sin(a)}\ $ and use the Reflection formula twice! – Raymond Manzoni Feb 18 '12 at 09:55
  • Can you tell me what is the domain of convergence of the series you found by Fourier analysis? – Pedro Feb 20 '12 at 21:34
  • @Peter: I think that the formula is valid for any $z\ $ not in $\mathbb{Z}\ $ but please don't ask me for a rigorous proof! To get a reasonable approximation of the left term taking the sum for $k\ $ from $1$ to a little more than $|z|\ $ should be enough. For $z\in \mathbb{Z}\ $ only one term will remain! – Raymond Manzoni Feb 20 '12 at 22:53
19
This is a very elegant and quick way to evaluate this sum with complex analysis. Consider
$$g(z) = \pi \csc (\pi z)f(z)$$
$\csc$ has poles at $2 \pi n$ and $2 \pi n + \pi$ for $n \in \mathbb Z$. Assuming $f(z)$ has no poles at any integer, the residue of $g(z)$ at $2n$ is
$$\operatorname*{Res}_{z = 2 n} g(z) = \lim_{z\to 2 n}(z-2 n)\pi \csc (\pi z)f(z) = \lim_{z\to 2 n}\pi \left(\frac{z-2 n}{\sin (\pi z)}\right)f(z) = f(n)$$
and at $2n+1$:
$$\operatorname*{Res}_{z = 2 n + 1} g(z) = \lim_{z\to 2 n + 1}(z-(2 n + 1))\pi \csc (\pi z)f(z) = \lim_{z\to 2 n + 1}\pi \left(\frac{z-2 n - 1}{\sin (\pi z)}\right)f(z) = -f(n)$$
Let $C_N$ be the square contour with the verticies $\left(N+\frac{1}{2}\right)(1+i)$, $\left(N+\frac{1}{2}\right)(-1+i)$, $\left(N+\frac{1}{2}\right)(-1-i)$ and $\left(N+\frac{1}{2}\right)(1-i)$.
By residue theorem, we have
$$\int_{C_N}g(z)\,dz = \sum_{n=-N}^N (-1)^n f(n) + S$$
where $S$ is the sum of the residues of the poles of $f$. Now, seeing that the left side vanishes as $N \to \infty$ (see here), we have
$$\sum_{k=-\infty}^\infty (-1)^k f(k)=-\sum \text{Residues of }\pi \csc (\pi z)f(z)$$
Clearly the only singularity of $f(z)=\frac{1}{a+z}$ is at $z_0=-a$. Thus
$$\operatorname*{Res}_{z=z_0} \,(\pi \csc (\pi z)f(z))=\lim_{z \to z_0} (z-z_0)\pi \csc (\pi z)f(z)=\lim_{z \to -a} \pi \csc (\pi z)\frac{z+a}{z+a}=-\pi \csc (\pi a)$$
Thus
$$\sum_{k=-\infty}^\infty (-1)^k f(k)=-\operatorname*{Res}_{z=z_0}\,(\pi \csc (\pi z)f(z))=-(-\pi \csc (\pi a))=\frac{\pi}{\sin (\pi a)}$$
QED
Y.D.X.
  • 144
Argon
  • 25,303
  • To be fair, the main computation is showing that $$\oint_{C_N} g(z) , {\rm d}z =0 , ,$$ as $N\rightarrow \infty$. Took me almost 2 pages. – Diger Jul 01 '22 at 10:12
A related identity is proven in this answer using residue theory. Here is a real approach to that identity.
Convergence of the Principal Value
We will look at the principal value $$ \begin{align} f(x) &=\lim_{n\to\infty}\sum_{k=-n}^n\frac1{k+x}\tag{1a}\\ &=\frac1x-\sum_{k=1}^\infty\frac{2x}{k^2-x^2}\tag{1b} \end{align} $$ $\text{(1b)}$ converges for all non-integer $x$.
Properties of $\boldsymbol{f(x)}$
$\bullet$ $f(x)$ has period $1$: $$ \begin{align} f(x)-f(x+1) &=\lim_{n\to\infty}\left(\sum_{k=-n}^n\frac1{k+x}-\sum_{k=-n}^n\frac1{k+1+x}\right)\tag{2a}\\ &=\lim_{n\to\infty}\left(\sum_{k=-n}^n\frac1{k+x}-\sum_{k=-n+1}^{n+1}\frac1{k+x}\right)\tag{2b}\\ &=\lim_{n\to\infty}\left(\frac1{-n+x}-\frac1{n+1+x}\right)\tag{2c}\\[9pt] &=0\tag{2d} \end{align} $$ Explanation:
$\text{(2a):}$ definition
$\text{(2b):}$ substitute $k\mapsto k-1$ in the right sum
$\text{(2c):}$ the sums telescope
$\text{(2d):}$ evaluate the limit
$\bullet$ $f(1/2)=0$: $$ \begin{align} f(1/2) &=\lim_{n\to\infty}\sum_{k=-n}^n\frac1{k+1/2}\tag{3a}\\ &=\lim_{n\to\infty}\frac1{n+1/2}\tag{3b}\\[9pt] &=0\tag{3c} \end{align} $$ Explanation:
$\text{(3a):}$ definition
$\text{(3b):}$ for $1\le j\le n$, the term with $k=j-1$ cancels the term with $k=-j$
$\phantom{\text{(3b):}}$ which leaves the term with $k=n$
$\text{(3c):}$ evaluate the limit
$\bullet$ $f(x)^2+\pi^2=-f'(x)$: $$ \begin{align} f(x)^2 &=\lim_{n\to\infty}\sum_{k=-n}^n\frac1{k+x}\sum_{j=-n}^n\frac1{j+x}\tag{4a}\\[3pt] &=\sum_{k=-\infty}^\infty\frac1{(k+x)^2}+\lim_{n\to\infty}\sum_{\substack{|j|,|k|\le n\\j\ne k}}\left(\frac1{k+x}-\frac1{j+x}\right)\frac1{j-k}\tag{4b}\\ &=\sum_{k=-\infty}^\infty\frac1{(k+x)^2}+\lim_{n\to\infty}\sum_{\substack{|j|,|k|\le n\\j\ne k}}\frac2{k+x}\frac1{j-k}\tag{4c}\\ &=\sum_{k=-\infty}^\infty\frac1{(k+x)^2}+\lim_{n\to\infty}\sum_{k=1}^n\sum_{\substack{|j|\le n\\j\ne k}}\left(\frac2{k+x}+\frac2{k-x}\right)\frac1{j-k}\tag{4d}\\ &=\sum_{k=-\infty}^\infty\frac1{(k+x)^2}-\lim_{n\to\infty}\sum_{k=1}^n\left(\frac2{k+x}+\frac2{k-x}\right)(H_{n+k}-H_{n-k})\tag{4e}\\ &=-f'(x)-4\int_0^1\frac{\log\left(\frac{1+t}{1-t}\right)}{t}\,\mathrm{d}t\tag{4f}\\[12pt] &=-f'(x)-\pi^2\tag{4g} \end{align} $$ Explanation:
$\text{(4a):}$ product of limits equals the limit of the products
$\text{(4b):}$ the left sum contains the terms with $j=k$
$\phantom{\text{(11):}}$ apply partial fractions to the right sum
$\text{(4c):}$ take advantage of the symmetry in $j$ and $k$
$\text{(4d):}$ for $k=0$, the sum in $j$ is $0$
$\phantom{\text{(4d):}}$ for $k\lt0$, if we substitute $(j,k)\mapsto(-j,-k)$,
$\phantom{\text{(4d):}}$ we get the sum with $k\gt0$ and $k+x\mapsto k-x$
$\text{(4e):}$ the sum in $j$ telescopes to $H_{n-k}-H_{n+k}$
$\text{(4f):}$ the left sum is $f'(x)$
$\phantom{\text{(4f):}}$ the right sum is a Riemann Sum with $\frac kn\mapsto t$ and $\frac1n\mapsto\mathrm{d}t$
$\phantom{\text{(4f):}}$ $H_{n+k}-H_{n-k}\mapsto\log\left(\frac{1+t}{1-t}\right)$ and $\frac2{k-x}+\frac2{k+x}\mapsto\frac{4\,\mathrm{d}t}t$
$\text{(4g):}$ $4\int_0^1\sum\limits_{k=0}^\infty\frac{2\,x^{2k}}{2k+1}\,\mathrm{d}x=4\sum\limits_{k=0}^\infty\frac2{(2k+1)^2}=\pi^2$
Conclude that $\boldsymbol{f(x)=\pi\cot(\pi x)}$
We can separate $(4)$ and integrate: $$ \begin{align} \int\frac{\pi\,\mathrm{d}f}{f^2+\pi^2}&=-\int\pi\,\mathrm{d}x\tag{5a}\\ \tan^{-1}(f/\pi)&=C-\pi x\tag{5b}\\[9pt] f&=\pi\tan(C-\pi x)\tag{5c} \end{align} $$ $(3)$ allows us to compute $C=\pi/2$, giving $$ f(x)=\pi\cot(\pi x)\tag6 $$ for $x\in(0,1)$. $(2)$ removes this restriction on $x$, validating $(6)$ for all non-integer $x$. That is, $$ \sum_{k=-\infty}^\infty\frac1{k+x}=\pi\cot(\pi x)\tag7 $$ when taken in the principal value sense.
Answer to the Question $$ \begin{align} \sum_{k=-\infty}^\infty\frac{(-1)^k}{k+x} &=\sum_{k=-\infty}^\infty\frac2{2k+x}-\sum_{k=-\infty}^\infty\frac1{k+x}\tag{8a}\\ &=\sum_{k=-\infty}^\infty\frac1{k+x/2}-\sum_{k=-\infty}^\infty\frac1{k+x}\tag{8b}\\[6pt] &=\pi\cot(\pi x/2)-\pi\cot(\pi x)\tag{8c}\\[15pt] &=\pi\csc(\pi x)\tag{8d} \end{align} $$ Explanation:
$\text{(8a):}$ the alternating sum is twice the sum of the even terms
$\phantom{\text{(8a):}}$ minus the sum of all the terms
$\text{(8b):}$ adjust the terms of the left sum to apply $(7)$
$\text{(8c):}$ apply $(7)$
$\text{(8d):}$ $\frac{1+\cos(\pi x)}{\sin(\pi x)}-\frac{\cos(\pi x)}{\sin(\pi x)}=\frac1{\sin(\pi x)}$
robjohn
  • 345,667
  • $\text{(4g)}$ references $\sum\limits_{k=0}^\infty\frac1{(2k+1)^2}=\frac{\pi^2}8$. A real derivation can be found here. – robjohn May 29 '23 at 19:08
Set $x=0$ in the Fourier series of $\cos(ax)$:
$$\cos(ax)=\frac{2a\sin(\pi a)}{\pi}\left[\frac1{2a^2}+\sum_{k=1}^\infty\frac{(-1)^k\cos(kx)}{a^2-k^2}\right],\quad a\notin\mathbb{Z}$$
we get
\begin{align} \frac{\pi}{\sin(\pi a)}&=\frac1a+\sum_{k=1}^\infty\frac{2a(-1)^k}{a^2-k^2}\\ &=\frac1a+\sum_{k=1}^\infty\frac{(-1)^k}{a-k}+\sum_{k=1}^\infty\frac{(-1)^k}{a+k}\\ &=\frac1a+\sum_{k=-\infty}^{-1}\frac{(-1)^k}{a+k}+\sum_{k=1}^\infty\frac{(-1)^k}{a+k}\\ &=\sum_{k=-\infty}^{\infty}\frac{(-1)^k}{a+k} \end{align}
Ali Shadhar
  • 25,498
    How is this different from the accepted answer by Raymond Manzoni? – Gary Apr 25 '22 at 06:57
  • @Gary First thanks for the downvote. Second I don't care if its different or not from other solutions, I just solve it my way. Third I see my solution well explained giving the desired result. – Ali Shadhar Apr 25 '22 at 08:50
    Imagine a hundred other people thought the same way and so we would have the same solution posted a hundred times. Would that make any sense? – Gary Apr 25 '22 at 09:18
  • @Gary its very rare to have many people to think the same way. we are created to be different in almost every little thing – Ali Shadhar Apr 25 '22 at 09:44
    $+1$ Nice.${}{}{}{}{}$ – Felix Marin Apr 26 '22 at 01:18
    @AliShadhar, I agree with you +1. – Lai Jul 01 '22 at 08:48
