14
I was looking for a proof of $e^{x+y}=e^xe^y$ using the fact that $$e^x=\lim_{n\to\infty }\left(1+\frac{x}{n}\right)^n.$$
So I have that $$\left(1+\frac{x+y}{n}\right)^n=\sum_{k=0}^n\binom{n}{k}\frac{(x+y)^k}{n^k}=\sum_{k=0}^n\frac{1}{n^k}\sum_{i=0}^k\binom{k}{i}x^iy^{k-i}=\sum_{k=0}^n\binom{n}{k}\sum_{i=0}^k\binom{k}{i}\left(\frac{x}{n}\right)^i\left(\frac{y}{n}\right)^{k-i}$$
But I can't get $$\left(1+\frac{x+y}{n}\right)^n=\sum_{k=0}^n\binom{n}{k}\left(\frac{x}{n}\right)^k\sum_{i=0}^n\binom{n}{i}\left(\frac{y}{n}\right)^i.$$
Any idea ?
idm
  • 11,824
    try the other way $\lim_{n \to \infty} (1+\frac{x}{n})^n(1+\frac{y}{n})^n$. Then ignore the higher order terms –  Sep 25 '15 at 16:50
  • I got it, but I would like to conclude like this if it's possible :-) – idm Sep 25 '15 at 16:54
  • I think it does not matter. Anyways I will try to explain it to you without writing it mathematically. While going in the direction you want, we have to add and substract the terms we neglected to make $\lim_{n\to \infty} (1 + \frac{x}{n})^n(1+\frac{y}{n})^n = \lim_{n\to \infty} (1+\frac{x+y}{n})^n$. Then we will be left with two terms $(1+\frac{x+y}{n})^n - (something)$. This something has powers of $n$ in the denominator and will go to $0$ after taking the limit. I personally do not like this approach. –  Sep 25 '15 at 17:11
My favorite approach to these problems is to first prove:
Lemma: If $g$ is a real-valued function on the natural numbers such that $$\lim_{n\to\infty}n(g(n)-1)=c$$ then: $$\lim_{n\to\infty} g(n)^{n} = e^c$$
Proof:
Case c=0:
Restrict to $n$ so that $n|g(n)-1|<1$. Then: $$\begin{align} g(n)^n &= (1+(g(n)-1))^n\\ & = 1+ \sum_{k=1}^{n}\binom{n}{k}(g(n)-1)^k\end{align}$$ Since $\binom{n}{k}\leq \frac{n^k}{k!}$ and $\frac{1}{k!}\leq \frac{1}{2^{k-1}}$:
$$\begin{align} |g(n)^n-1| &\leq \sum_{k=1}^{n}\frac{1}{k!}\left(n|g(n)-1|\right)^k\\ &\leq n|g(n)-1|\sum_{k=1}^\infty \frac{1}{2^{k-1}}\\ &=2n|g(n)-1| \end{align}$$
So $\left|g(n)^n-1\right|\to 0$.
General case:
Let $h(n)=\frac{g(n)}{1+c/n}$. Then $$n(h(n)-1)=\frac{n(g(n)-1)-c}{1+c/n}\to 0.$$ So, by the case $c=0$, we have that $h(n)^n\to 1$. But we know that $(1+c/n)^n\to e^c$, so we are done.
The case $c=0$ used only binomial theorem and basic inequalities. The general case requires knowledge that $\lim_{n\to\infty}\left(1+\frac{c}{n}\right)^n\to e^c.$
The lemma can be rewritten in little-$o$ notation as:
If $g(n)=1+\frac{c}{n}+o\left(\frac1n\right)$ then $g(n)^n\to e^c$.
The problem at hand
Next, show that, for fixed $x,y$ that: $$\begin{align}G(n)&=\left(1+\frac{x}{n}\right)\left(1+\frac{y}{n}\right) \end{align}$$
satisfies the property that $n(G(n)-1)\to x+y$ since $$n(G(n)-1)=x+y+\frac{xy}{n}.$$
This shows what you wanted.
Another application: Euler's formula
If $h(x)$ is a function such that $h(x)=1+cx+o(x)$ then $h(x/n)^n\to e^{cx}$. This condition $h(x)=1+cx+o(x)$ is equivalent to $h(0)=1,h'(0)=c$.
One interesting case is $h(x)=\cos x+i\sin x$. We can show purely geometrically that $\cos x+i\sin x= 1+ix+o(x)$, and by induction prove that $h(x)^n=h(nx)$, so we have that $$\cos x+i\sin x =h(x)= \lim_{n\to\infty} h(x/n)^n=\lim_{n\to\infty}\left(1+\frac{ix}n\right)^n$$
The geometric proof is roughly, for all $x\in(0,\pi/2)$:
  1. $\sin x<x$. This is because $\frac{1}{2}\sin x$ is the area of a triangle contained in the circle wedge of angle $x$ which has area $x/2$.
  2. $0\leq 1-\cos x<\frac{1}{2}x^2$. This is true because $1-\cos x = 2\sin^2(x/2)<\frac{x^2}{2}$ by step (1).
  3. $x<\tan x$. This is because the wedge of angle $x$ is contained in the triangle $(0,0)$, $(1,0)$, $(1,\tan x)$ of area $\frac{1}{2}\tan x$.
  4. From (3) and (1), we get $x\cos x< \sin x<x$. But $\cos x =1+o(x)$ so $x\cos (x)=x+o(x^2)$ and thus $\sin(x)=x+o(x^2)$.
This shows that $\cos x +i\sin x = 1+ix + o(x)$.
Thomas Andrews
  • 177,126
  • what is $g(n)$ ? – idm Sep 25 '15 at 17:03
  • Any function with the property that I've stated. Edited the answer to make that clear. – Thomas Andrews Sep 25 '15 at 17:07
    Well done! ... +1 – Mark Viola Sep 25 '15 at 21:01
  • Beautiful proof! – Hasan Saad Sep 25 '15 at 23:47
    In past I had shown that $(1 + x/n)^{n}(1 + y/n)^{n} - (1 + (x + y)/n)^{n}$ tends to $0$ (see http://math.stackexchange.com/a/541330/72031), but it appears that showing $a/b \to 1$ is easier here than showing $a - b \to 0$. Plus derivation of the final result involving $\cos x + i\sin x$ is truly a gem. +1 – Paramanand Singh Sep 27 '15 at 10:37
  • @ThomasAndrews: Your Lemma can also be obtained as follows: $(g(n))^n=\big(1+\tfrac{n(g(n)-1)}{n}\big)^n$. Since $c_n=n(g(n)-1)\xrightarrow{n\rightarrow\infty}c$, $(g(n))^n\xrightarrow{n\rightarrow\infty}e^c$. This also holds for $c\in\mathbb{C}$ by a well known result by de Moivre. – Mittens May 26 '22 at 13:55
  • Well, sure, if you assume what is to be proven, then you are done. @OliverDíaz The Lemma is an attempt to prove that result using relatively simple means. – Thomas Andrews May 26 '22 at 14:00
  • My proof nowhere uses exponential expansion, just binomial theorem. Reread. @OliverDíaz – Thomas Andrews May 26 '22 at 16:19
  • Sigh, that is a given in the question. @OliverDíaz – Thomas Andrews May 26 '22 at 16:39
  • In any event, we can show $e(x)=\lim (1+x/n)^n$ exists for $x\geq 0$ by showing it is increasing and bounded above. This requires some knowledge of power series (to prove bounded above - essentially proving that the power series of $e^x$ converges and is an upper bound, but we don’t need to know that the power series is $e^x$) We can then use my lemma for $c=0$ to $((1-x/n)(1+x/n))^n\to 1,$ to show that $e(x)$ can be defined for $x<0.$ So we don’t need to know the power series of $e^x$ to prove $e(x+y)=e(x)e(y).$ @OliverDíaz – Thomas Andrews May 26 '22 at 17:00
  • @ThomasAndrews: understood. Thanks. – Mittens May 26 '22 at 17:01
  • The main disadvantage I see of ignoring the power series: It isn’t 100% obvious to me how to prove $(1+z/n)^n$ converges for complex $z.$ This amounts to proving $(1+ix/n)^n$ converges for real $x,$ by the fact that $e(y+xi)=e(y)e(xi)$ for any case where two of the three values are defined. But I don’t know how to go from there. – Thomas Andrews May 26 '22 at 17:21
\begin{align*} e^x e^y &= \lim_{n\rightarrow \infty}(1+\frac{x}{n})^n\lim_{n\rightarrow \infty}(1+\frac{y}{n})^n\\ &=\lim_{n\rightarrow \infty}(1+\frac{x}{n})^n(1+\frac{y}{n})^n\\ &=\lim_{n\rightarrow \infty}(1+\frac{x+y}{n}+\frac{xy}{n^2})^n\\ &=\lim_{n\rightarrow \infty}(1+\frac{x+y}{n})^n \frac{(1+\frac{x+y}{n}+\frac{xy}{n^2})^n}{(1+\frac{x+y}{n})^n}\\ &=\lim_{n\rightarrow \infty}(1+\frac{x+y}{n})^n \left(1+\frac{xy}{n^2(1+\frac{x+y}{n})}\right)^n\\ &=\lim_{n\rightarrow \infty}(1+\frac{x+y}{n})^n\left(1+\frac{xy}{n^2(1+\frac{x+y}{n})}\right)^{\frac{n^2(1+\frac{x+y}{n})}{xy}\frac{xy}{n^2(1+\frac{x+y}{n})}n}\\ &= \lim_{n\rightarrow \infty}(1+\frac{x+y}{n})^n\\ &=e^{x+y}. \end{align*}
Gordon
  • 4,461
    It would facilitate to use $$1+\frac1n\le \left(1+\frac1{n^2}\right)^n\le 1+\frac2n$$and squeeze the second term in Lines $3-5$. – Mark Viola Sep 26 '15 at 15:48
  • Hi Mark, can you explain your approach further? Or maybe submit an answer modifying Gordon's answer using your approach for lines 3-5? I am not sure what the modified version of lines 3-5 would look like, but I would love to see it, in case it makes Gordon's proof easier to follow. – EthanAlvaree Aug 17 '21 at 09:10
  • Gordon, could you please fill in the details why $\lim_{n \to \infty} \left(1+\frac{xy}{n^2(1+\frac{x+y}{n})}\right)^{\frac{n^2(1+\frac{x+y}{n})}{xy}\frac{xy}{n^2(1+\frac{x+y}{n})}n}=1$? Thank you in advance. – EthanAlvaree Aug 17 '21 at 09:38
  • As $\lim_{x\rightarrow 0^+}(1+x)^{\frac{1}{x}} = e$. – Gordon Aug 17 '21 at 12:05
