23
There is a general formula for indeterminate form $1 ^ {\infty}$ which I'm looking for a proof which is also used here. (picture)
Given $$\lim_{x\to a} f(x) = 1$$ and $$\lim_{x\to a} g(x) = \infty$$, what is $$\lim_{x\to a} f^{g} = e^{\lim_{x\to a}{(f-1)g}}\quad ? $$
I would appreciate it if somone could give me a proof of this formula.
Wolgwang
  • 1,563
I believe this is where the identity is coming from.
\begin{align} \lim_{x\to a}f^g &= \lim_{x\to a}(1+f-1)^g \\ &= \lim_{x\to a}\left(1+\frac{1}{\left(\frac{1}{f-1}\right)}\right)^g \\ \\ &= \lim_{x\to a}\left(1+\frac{1}{\left(\frac{1}{f-1}\right)}\right)^{g\frac{f-1}{f-1}} \\ \\ &= \lim_{x\to a}\left[\left(1+\frac{1}{\left(\frac{1}{f-1}\right)}\right)^{\frac{1}{f-1}}\right]^{g(f-1)} \\ \\ &= \lim_{x\to a}\left[\left(1+\frac{1}{\left(\frac{1}{f-1}\right)}\right)^{\frac{1}{f-1}}\right]^{\lim_{x\to a}g(f-1)} \qquad (*) \\ \\ &= e^{\lim_{x\to a}g(f-1)} \end{align}
Where the first limit is a form of the limit definition of $e$. I put a note (*) next to one step I am uneasy about. I am unsure why we can separately evaluate limits here. Perhaps someone else can comment on this.
zahbaz
  • 10,441
    This works when the limits both exist, since $\exp$ and $\log$ are both continuous. (Phrase $\lim r^s$ as $\lim \exp(s \log r)$, and use that the limit of a product is the product of the limits.) – Patrick Stevens Apr 03 '18 at 10:51
18
Remember that $f$ and $g$ are functions of $x$, so to be more precise, we should write $f(x)$ and $g(x)$ instead of $f$ and $g$. This applies to the answer below and to the other answers which have also adopted the shorthand used in the question of $f$ for $f(x)$ and $g$ for $g(x)$.
If $\lim\limits_{x\to a}f=1$, then $$ \begin{align} \log\left(\lim_{x\to a}f^g\right) &=\lim_{x\to a}\log\left(f^g\right)\\[6pt] &=\lim_{x\to a}\log(f)\,g\\ &=\lim_{x\to a}\frac{\log(f)}{f-1}\lim_{x\to a}\,(f-1)\,g\\[6pt] &=\lim_{x\to a}\,(f-1)\,g \end{align} $$ Therefore, $$ \lim_{x\to a}f^g=\exp\left(\lim\limits_{x\to a}\,(f-1)\,g\right) $$
robjohn
  • 345,667
    How did you get $\lim_{x\rightarrow a} \log(f)/(f-1) = 1$ in the 4th step? I used l'Hopital's to verify it, but often this formula is taught to students before they see derivatives, so I'm wondering if it can be proved without resort to calculus?! – Fixee May 11 '19 at 02:20
    Without calculus, we are limited in the ways to define $\log(x)$. One way is to define $e^x=\lim\limits_{n\to\infty}\left(1+\frac xn\right)^n$. Then Bernoulli's Inequality says not only that $e^x\ge1+x$, but also that $e^{-x}\ge1-x$ which implies that $e^x\le\frac1{1-x}$. Substituting $x\mapsto\log(x)$ and rearranging gives, for $x\gt0$, $$\frac{x-1}x\le\log(x)\le x-1$$ which says that $$\min\left(\tfrac1x,1\right)\le\frac{\log(x)}{x-1}\le\max\left(\tfrac1x,1\right)$$ – robjohn May 11 '19 at 23:32
    Would the downvoter care to comment? I appreciate your opinion, but it is hard to fix something without knowing what is broken. – robjohn Jan 20 '23 at 16:31
$$\begin{align} \lim \limits_{x \to a} f^g = e^{\lim \limits_{x \to a} g\cdot \log[1+ (f-1)]} &= e^{\lim_{x \to a} g\cdot [(\frac{(f-1)}{1}) + (\frac{(f-1)^2}{2}) + (\frac{(f-1)^3}{3}) + ...]} \\ &= e^{\lim \limits_{x \to a} g\cdot (f-1)[1 + (\frac{(f-1)}{1}) + (\frac{(f-1)^2}{2}) + ...]}. \end{align}$$
Now, since $f \to 1$ when $x \to a$, all the subsequent terms in the expansion involving $(f-1)$ will become zero, and the expression becomes:
$$\lim_{x \to a} f^g = e^{\lim \limits_{x \to a} g\cdot (f-1)}.$$
amWhy
  • 209,954
-1
It's wrong in the general.
It's true if there exist $\lim\limits_{x\rightarrow a}g(f-1)$ and
there is $\delta>0$ for which $f\neq1$ for any $0<|x-a|<\delta$ we have $f(x)\neq1$.
Indeed, since $h(x)=e^x$ is a continues function we obtain: $$\lim_{x\rightarrow a}f^g=\lim_{x\rightarrow a}e^{\frac{\ln(1+f-1)}{f-1}\cdot g(f-1)}=e^{\lim\limits_{x\rightarrow a}\left(\frac{\ln(1+f-1)}{f-1}\cdot g(f-1)\right)}=e^{\lim\limits_{x\rightarrow a}g(f-1)}.$$
  • I belive there is no need in the assumtion that $f \neq 1$ in a neirbourhood of $a$. See Daniel Fischer's proof. – Enzo Giannotta Aug 09 '21 at 19:56
  • @Enzo Giannotta Maybe. It not says that my reasoning is wrong. By the way, why does in the solution there exist $\lim\limits_{x\rightarrow a}g(f-1)$? It's not given! – Michael Rozenberg Aug 09 '21 at 21:06
