I am a grade 12th student. I am having doubts about limits as follows:-
If $a>1$, then $\lim\limits_{x \to \infty}a^x = \infty$.
The above is because a number greater than $1$ when multiplied with itself, increases. If we do it a large number of times, the number will get close to $\infty$. Therefore its limiting value becomes $\infty$.
Applying same logic $\lim\limits_{x \to 0^+}(1+ x)^\frac1x = \infty$.
But $\lim\limits_{x \to 0^+}(1+ x)^\frac1x = e$.
Can anyone suggest to me where I am wrong?
Edit
I had asked my mentor about this. He said the following.
In case of $\lim\limits_{x \to \infty}a^x$, base and exponent are independent of each other whereas in case of $\lim\limits_{x \to 0^+}(1+ x)^\frac1x$, the base and exponent are dependent on each other. Because of this dependence, as soon as we create the base, i.e. $(1+x)$, $x$ becomes fixed and as a result the exponent becomes fixed and can't approach infinity. However, for $a^x$, $x$ can become as small as we want and therefore tends to infinity.
Can anyone please explain me why are we trying to fix the base in case of $\lim\limits_{x \to 0^+}(1+ x)^\frac1x$? Is there any such rule that we have to first create a base and then apply the limits? Am I having a wrong interpretation of limits? Can anyone please interpret his statements in a simplified language.
Any help is appreciated. Thank you.
