The gradient of $\frac1r$ (noting that $r=\sqrt{x^2+y^2+z^2}$) is
\nabla \frac1r = -\frac{\mathbf{r}}{r^3}
when $r\neq 0$, where $\mathbf{r}=x\mathbf{i}+y\mathbf{j}+z\mathbf{k}$. Now, the divergence of this is
\nabla\cdot \left(-\frac{\mathbf{r}}{r^3}\right) = 0
when $r\neq 0$. Therefore, for all points for which $r\neq 0$,
\nabla^2\frac1r = 0
However, if we integrate this function over a sphere, $S$, of radius $a$, then, applying Gauss's Theorem, we get
\iiint_S \nabla^2\frac1rdV = \iint_{\Delta S} -\frac{\mathbf{r}}{r^3}.d\mathbf{S}
where $\Delta S$ is the surface of the sphere, and is outward-facing. Now, $d\mathbf{S}=\mathbf{\hat r}dA$, where $dA=r^2\sin\theta d\phi d\theta$. Therefore, we may write our surface integral as
$$\begin{align}
\iint_{\Delta S} -\frac{\mathbf{r}}{r^3}.d\mathbf{S}&=-\int_0^\pi\int_0^{2\pi}\frac{r}{r^3}r^2\sin\theta d\phi d\theta\\
&=-\int_0^\pi\sin\theta d\theta\int_0^{2\pi}d\phi\\
&= -2\cdot 2\pi = -4\pi
\end{align}$$
Therefore, the value of the laplacian is zero everywhere except zero, and the integral over any volume containing the origin is equal to $-4\pi$. Therefore, the laplacian is equal to $-4\pi \delta(\mathbf{r})$.
EDIT: The general case is then obtained by replacing $r=|\mathbf{r}|$ with $s=|\mathbf{r}-\mathbf{r_0}|$, in which case the function shifts to $-4\pi \delta(\mathbf{r}-\mathbf{r_0})$
