I looked at a couple of ways of examining this using series expansions. A difficulty that I noted in a comment to mathlove's answer is that this requires rather careful selection of estimators, since the permissible "error budget" is very limited if we are to show that the difference is less than 1 , when its actual value is about 0.682. Another issue is that we would like to use rational approximations in a way that makes these computations look credibly like ones that can be managed without a calculator. I use some "number facts" here that are either generally familiar or can be found readily enough (while these can be obtained using a calculator, that can be avoided if one is acquainted with approximate values); it proves to be very important to use values that closely approximate the needed numbers.
We can attempt to estimate an upper limit the difference $ \ e^{\pi} \ - \ \pi^e \ $ by setting up an inquality in which $ \ e^{\pi} \ $ is overestimated and $ \ \pi^e \ $ is underestimated. In this first one, we will start from
$$ \left( \frac{68}{25} \right)^{22/7} \ > \ e^{\pi} \ > \ \pi^{e} \ > \ \left( \frac{157}{50} \right)^{19/7} \ \ $$
$$ \Rightarrow \ \ \left( 3 \ - \ \frac{7}{25} \right)^{3 + \frac{1}{7}} \ > \ e^{\pi} \ > \ \pi^{e} \ > \ \left( 3 \ + \ \frac{7}{50} \right)^{3 - \frac{2}{7}} \ \ $$
$$ \Rightarrow \ \ 3^3 \ \cdot \ 3^{1/7} \ \cdot \left( 1 \ - \ \frac{7}{75} \right)^3 \ \left( 1 \ - \ \frac{7}{75} \right)^{\frac{1}{7}} \ > \ e^{\pi} \ > \ \pi^{e} \quad > \ 3^3 \ \cdot \ 3^{-2/7} \ \cdot \left( 1 \ + \ \frac{7}{150} \right)^3 \ \left( 1 \ + \ \frac{7}{150} \right)^{-\frac{2}{7}} \ \ . $$
We can construct Taylor polynomials for the powers of $ \ 3 \ $ based on the function $ \ 3^x \ $ [using $ \ \ln 3 \ \approx \ 1.1 \ $ ], and can apply the (generalized) binomial series for the other factors:
$$ 3^3 \ \cdot \ 3^{1/7} \ \cdot \left( 1 \ - \ \frac{7}{75} \right)^3 \ \left( 1 \ - \ \frac{7}{75} \right)^{\frac{1}{7}} $$ $$ \approx \ 27 \ \left( 1 \ + \ \ln 3 \cdot \frac{1}{7} \ + \ \frac{(\ln 3)^2}{2} \cdot \frac{1}{7^2} \right) \ \left( 1 \ - \ 3 \cdot \frac{7}{75}\ + \ 3 \cdot \frac{7^2}{75^2} \right) $$ $$ \cdot \left( 1 \ - \ \frac{1}{7} \cdot \frac{7}{75} \ + \ \frac{\frac{1}{7} \cdot \frac{-6}{7}}{2} \cdot \frac{7^2}{75^2} \right) \ $$
$$ \approx \ 27 \ \left( 1 \ + \ \frac{11}{10} \cdot \frac{1}{7} \ + \ \frac{6}{10} \cdot \frac{1}{7^2} \right) \ \left( 1 \ - \ \frac{7}{25}\ + \ 3 \cdot \frac{7^2}{75^2} \right) \ \left( 1 \ - \ \frac{1}{75} \ - \ \frac{3}{75^2} \right) \ \ , $$
and similarly,
$$ 3^3 \ \cdot \ 3^{-2/7} \ \cdot \left( 1 \ + \ \frac{7}{150} \right)^3 \ \left( 1 \ + \ \frac{7}{150} \right)^{-\frac{2}{7}} $$ $$ \approx \ 27 \ \left( 1 \ - \ \ln 3 \cdot \frac{2}{7} \ + \ \frac{(\ln 3)^2}{2} \cdot \frac{4}{7^2} \ - \ \frac{(\ln 3)^3}{6} \cdot \frac{8}{7^3} \right) \ \left( 1 \ + \ 3 \cdot \frac{7}{150}\ + \ 3 \cdot \frac{7^2}{150^2} \right) $$ $$ \cdot \left( 1 \ - \ \frac{2}{7} \cdot \frac{7}{150} \ + \ \frac{\frac{-2}{7} \cdot \frac{-9}{7}}{2} \cdot \frac{7^2}{150^2} \right) \ $$
$$ \approx \ 27 \ \left( 1 \ - \ \frac{11}{10} \cdot \frac{2}{7} \ + \ \frac{6}{10} \cdot \frac{4}{7^2} \ - \ \frac{4 \cdot 4}{3 \cdot 3} \cdot \ \frac{1}{7^3} \right) \ \left( 1 \ + \ \frac{7}{50}\ + \ 3 \cdot \frac{7^2}{150^2} \right) $$ $$ \cdot \ \left( 1 \ - \ \frac{1}{75} \ + \ \frac{9}{150^2} \right) \ \ . $$
In order for the series for $ \ 3^{-2/7} \ $ to remain an underestimate, it is necessary to extend the Taylor polynomial to third-degree. Simple linearizations give far too "coarse" approximations to resolve the inequality we desire clearly enough; we are also unable to obtain sufficient precision by only keeping the "linear" terms in the product. There isn't much for it other than to arrange each factor to have a single denominator, which gives us
$$ 27 \ \left[ \ \left( \frac{573}{490} \right) \ \left( \frac{4197}{5625} \right) \ \left( \frac{5547}{5625} \right) \ - \ \left( \frac{11260}{15435} \right) \ \left( \frac{25797}{22500} \right) \ \left( \frac{22209}{22500} \right) \right] \ > \ e^{\pi} \ - \ \pi^e \ \ . $$
From this point, it becomes a question of how much calculation one has the patience to do without the aid of a device; it would likely be easiest to divide out each ratio, multiply the three factors in each term, take the difference between terms, and multiply the result by $ \ 27 \ $ . In the pre-calculator era, this would not have been considered unreasonable: after all, the Ludolphine number $ ( \pi ) $ was computed to 35 decimal places over 400 years ago using polygon-approximations over the course of some years. If we avail ourselves of a calculator at this point, we see that we have
$$ 27 \ \left( \ 1.16939 \cdot 0.74613 \cdot 0.98613 \ - \ 0.72951 \cdot 1.14653 \cdot 0.98707 \right) \ \approx \ 0.9403 \ > \ e^{\pi} \ - \ \pi^e \ \ . $$
This may be compared with the first inequality we wrote, for which our result is an intended overestimate,
$$ \left( \frac{68}{25} \right)^{22/7} \ - \ \left( \frac{157}{50} \right)^{19/7} \ \approx \ 0.8901 > \ e^{\pi} \ - \ \pi^{e} \ \ . $$
We might well wish for something more tractable, which can be obtained by making the estimate a bit differently. If we're permitted the "number facts" $ \ e^3 \ \approx \ 20.1 \ \ , \ \ \pi^3 \ \approx \ 31 \ \ , \ \pi \ < \ \frac{22}{7} \ $ and $ \ e \ > \ \frac{19}{7} \ $ , we can proceed from
$$ \frac{201}{10} \ \cdot \ e^{1/7} \ > \ e^{3 \ + \ \frac{1}{7}} \ > \ e^{\pi} \ > \ \pi^{e} \ > \ \pi^{3 \ - \ \frac{7}{25}} \ > \ 31 \ \cdot \ \pi^{-7/25} \ > \ 31 \ \cdot \ \left( \frac{\pi}{e} \right)^{-7/25} \ \cdot \ e^{-7/25} \ \ . $$
We would like the factor $ \ \left( \frac{\pi}{e} \right)^{-7/25} \ $ to be underestimated, so we will use the overestimate
$$ \ \left( \frac{\pi}{e} \right) \ < \ \frac{22/7}{19/7} \ = \ \frac{22}{19} \ \ . $$
As above, we will use Taylor polynomials for the powers of $ \ e \ $ and the generalized binomial series to produce
$$ \frac{201}{10} \ \cdot \ \left( 1 \ + \ \frac{1}{7} \ + \ \frac{1}{2 \cdot 7^2} \right) \ > \ e^{\pi} \ > \ \pi^{e} \ > \ 31 \ \cdot \ \left( 1 \ + \ \frac{3}{19} \right)^{-7/25} \ \cdot \ \left( 1 \ - \ \frac{7}{25} \ + \ \frac{7^2}{2 \cdot 25^2} \right) $$
$$ \Rightarrow \ \ \frac{201}{10} \ \cdot \ \left( 1 \ + \ \frac{1}{7} \ + \ \frac{1}{98} \right) \ > \ e^{\pi} \ > \ \pi^{e} \ > \ 31 \ \cdot \ \left( 1 \ - \ \frac{7}{25} \cdot \frac{3}{19} \right) \ \cdot \ \left( 1 \ - \ \frac{7}{25} \ + \ \frac{49}{1250} \right) $$
$$ \Rightarrow \ \ \frac{201}{10} \ \cdot \ \frac{113}{98} \ > \ e^{\pi} \ > \ \pi^{e} \ > \ 31 \ \cdot \ \frac{454}{475} \ \cdot \ \frac{949}{1250} \ \ , $$
these ratios being obtainable by reasonably simple hand-calculation. We can make the work we face in the right-hand term of this inequality a bit less onerous by using
$$ 31 \ \cdot \ \frac{454}{475} \ \cdot \ \frac{949}{1250} \ > \ 31 \ \cdot \ \frac{450}{475} \ \cdot \ \frac{945}{1250} \ = \ 31 \ \cdot \ \frac{18}{19} \ \cdot \ \frac{189}{250} \ \ . $$
Re-arranging the inequality gives us
$$ \frac{201}{10} \ \cdot \ \frac{113}{98} \ - \ 31 \ \cdot \ \frac{18}{19} \ \cdot \ \frac{189}{250} \ = \ \frac{201 \cdot 113 \cdot 19 \cdot 25 \ - \ 31 \cdot 18 \cdot 189 \cdot 98}{980 \cdot 19 \cdot 25} \ > \ e^{\pi} \ - \ \pi^{e} \ \ . $$
While this looks a bit daunting, it is considerably easier to compute by hand than the earlier estimate: a little work with binomials simplifies some of the multiplicaton and the rest is not too bad to work out "long-hand". Hence,
$$ \frac{10,788,675 \ - \ 10,335,276}{465,500} \ = \ \frac{453,399}{465,500} \ > \ e^{\pi} \ - \ \pi^{e} \ \ . $$
So we again establish the desired inequality, this time with more handiwork. We can make use of the calculator (or divide long-hand if we really want to remain "pure") to find that this ratio is about 0.9740 .
I will admit to a bit of guidance from a calculator to make adequate selections for the rational approximations in the interests of saving some time. It would take rather longer than to refine the numbers used in this investigation if one had to work entirely without "machine assistance".
