I'm trying to create a program to solve a set of Kepler's Equation and I cannot isolate the single variable to use the expression in my program.
The Kepler Equation is $$M = E - \varepsilon \sin(E)$$
I will enter the values of $M$ and $\varepsilon$ and wish to find the value of $E$.
The website Wolfram Alpha could find a solution for this input $30(\frac{\pi}{180})=x-0.3 \sin(x)$
How can I find $E$?
EDIT:
I would like to propose this algorithm (Javascript) to solve the equation. It might require some adjustments depending on the programming language used. I did some basic tests with it, and would like feedback on it.
The following algorithm doesn't have an user input method and is treating the expression:
$0 = -x + \sin(-x)$
which is related to:
$x = \sin(-x)$
I used this algorithm to solve $E$ in Kepler's Equation rewriting it as (And swapping M and e for numerical constants, that in my case will be user inputs):
$0 = -M + E - e*sin(E)$
<script>
var start = Number.MIN_SAFE_INTEGER; end = Number.MAX_VALUE;
var result = null;
while(result === null) {
    var resultStart = Math.abs(-start + Math.sin(-start));
    var resultEnd = Math.abs(-end + Math.sin(-end));
    if(resultStart === 0) {
        result = start;
    } else if (resultEnd === 0) {
        result = end;
    } else {
        if (resultStart > resultEnd) {
            var startOld = start;
            start = (start+end)/2;
            if(startOld === start) { // underflow
                result = start;
        } else {
            var endOld = end;
            end = (start+end)/2;
            if(endOld === end) { // underflow
                result = end;
console.log(result);
</script>
dustin
  • 8,241
hawaii
  • 163
    i think it is not possible, you will need a numerical method – Dr. Sonnhard Graubner Dec 05 '14 at 20:14
  • Because the derivative can be very close to zero, any derivative-based methods can be numerically unstable. I recommend the bisection method as the most stable. It converges quite fast enough on modern computers: 17 or 18 iterations will give you 4-5 digits of accuracy. – Adrian Keister Dec 28 '19 at 18:07
There is no known closed form inverse for Kepler's equation. Newton's Method works well numerically, except in the case of near parabolic orbits ($\varepsilon\approx1$). It says to iterate $$ E_{n+1}=\frac{M+\varepsilon\sin(E_n)-\varepsilon E_n\cos(E_n)}{1-\varepsilon\cos(E_n)} $$ until it converges.
robjohn
  • 345,667
  • Thank you for your answer. I created an algorithm based on the Binary Search/Newton's Method. I'm editing my question with the Algorithm. – hawaii Dec 05 '14 at 22:50
An analytical and elegant solution is the following Kapteyn / Fourier series:
$$E(M)=M+\sum_{n=1}\frac{ 2 J_n(n\epsilon) }{n} \sin(n M)$$
where $J_n(x)$ are the Bessel functions.
Other analytical solutions based on series expansion are discussed in:
"Solving Kepler's Equation Over Three Centuries", Peter Colwell, 1993
For implementation of Bessel functions in Javascript, several codes are available. For example:
http://www.mhtl.uwaterloo.ca/old/courses/me3532/js/bessel.html
https://github.com/SheetJS/bessel
  • The question http://math.stackexchange.com/questions/10427/solving-2x-sin-2x-pi-2-for-0-x-pi-2/1174724#1174724 seems related.
    I have posted in such thread numerical evaluations based on raw summation of Bessel functions and accelerated summation and c++ code for the particular case $M=\pi/2$ and $\epsilon=1$ (related to the so-called Dottie number)
    – giorgiomugnaini Mar 04 '15 at 07:01
$\def\L{\operatorname L} \def\J{\operatorname J}$
@giorgiomugnaini gave a Fourier series solution and the following integral representations was not found elsewhere online, but here are other solutions to the Kepler equation
Laplace Transform:
We apply the Laplace inversion theorem and one could expand $\sin(\phi)$, like in the Fourier series derivation, or:
$$f(\phi)=\sin(\phi)+a\phi=x\implies \phi=\L^{-1}_x(\L_s(\phi(t))$$
We define $\phi(x)=0\not<x\not<\pi a$, substitute $\phi(t)\to t$, and integrate by parts:
$$\L_s(\phi(t))=\int_0^{\pi a}e^{-st}\phi(t)dt=\int_0^\pi e^{-sf(t)}t\ df(t)=-\frac\pi s e^{-\pi a s}+\int_0^\pi e^{-s\sin(t)-a s t}dt$$
$-\frac\pi s e^{-\pi a s}$’s inverse Laplace transform is a Heaviside theta function which is zero for $x<\pi a$. Alternatively, if $f(x)$ is monotonic, then there is global inverse, so another setup is:
$$\L_s(h(t))=\int_0^\infty e^{-st}dt=\int_0^\infty t e^{-sf(t)}df(t)=\frac1s\int_0^\infty e^{-s\sin(t)-a s t}dt$$
Finally, expand $e^{c\sin(x)}$ via Maclaurin series, integrate, and sum over to obtain an Anger J. Therefore:
$$\bbox[3px,border: solid blue 3px]{\sin(\phi)+a\phi=x\implies \phi=\int_{ic-\infty}^{ic+\infty}\frac{e^{isx}\J_{a s}(s)}{is(e^{\pi i a s}+1)}ds,\int_{ic+\infty}^{ic-\infty}\frac{e^{isx}}{2s}\csc(\pi a s)\J_{as}(s)ds}$$
The first integral represents a period of $\phi(x)$ while the second is the global inverse. shown here:
Fourier Transform:
The Fourier inversion theorem uses Anger J:
$$\bbox[3px,border: solid blue 3px]{\sin(\phi)-a\phi=x\implies \phi=\int_0^\infty\frac2t\sin(tx)\operatorname J_{at}(t)dt}$$
shown here:
Тyma Gaidash
  • 12,081
For $E\neq 0$, Kepler's equation can be solved by Hyper Lambert W:
$$E-\varepsilon\sin(E)=M$$ $$E\ e^{\ln(1-\varepsilon\frac{\sin(E)}{E})}=M$$ $$E=HW\left(\left\{\ln(1-\varepsilon\frac{\sin(x)}{x})\right\}_1;M\right)$$
So we have a closed form for $E$, and the series representations of Hyper Lambert W give some hints for calculating $E$.
[Galidakis 2005] Galidakis , I. N.: On solving the p-th complex auxiliary equation $f^{(p)}(z)=z$. Complex Variables 50 (2005) (13) 977-997
Galidakis, I. N.: On some applications of the generalized hyper-Lambert functions. Complex Variables and Elliptic Equations 52 (2007) (12) 1101-1119
[Dubinov/Galidakis 2007] Dubinov, A.; Galidakis, Y.: Explicit solution of the Kepler equation. Physics of Particles and Nuclei Letters 4 (2007) 213-216
[Masson] Masson, Paul: Analytic Physics - An Exact Solution of the Complex Kepler Equation
IV_
  • 6,964
  • Looking at section $4$, where it says, “Transcendental equations solvable exactly by HW functions” in this article, gives one equation as $e^{f(x)\cdot e^x}+x+a=0$. It would seem that one can use HW functions to solve any transcendental equation, like the Kepler equation. Is this really a closed form? – Тyma Gaidash Jul 08 '23 at 12:53
  • Those “transcendental equations which are algebraically solvable by the $HW$ functions” are, for example, “$e^{f(x)e^x}+x+a=0$ where $f(x)$ is an arbitrary function of $x$”. It does seem very useful. – Тyma Gaidash Jul 08 '23 at 14:29
  • @ТymaGaidash A closed form is a placeholder for the other representations of a function. I don't know if Hyper Lambert W with further functions in the exponential tower make the things really easier. – IV_ Oct 31 '23 at 18:32
