19
I am trying to get the probability distribution function of $Z=X-Y$. Given that $f_X(x)$ and $f_Y(y)$ are known, and both variables are chi-square distributed, $X\in\mathbb{R}$, $X\ge 0$, and similarly $Y\in\mathbb{R}$, $Y\ge 0$. So how can I get $f_Z(z)$.
Sophie
  • 543
    Are they $\chi^2$-distributed with the same parameters, or different ? – Sasha Nov 24 '11 at 16:08
    Regardless of the distribution, you need to know the joint distribution of $X$ and $Y$ in order to answer the question. For the special case when $X$ and $Y$ are independent, the density of $X-Y$ is the convolution of the densities of $X$ and $-Y$, in particular, $$f_{X-Y}(z) = \int_{-\infty}^{\infty} f_X(x)f_Y(x-z)\mathrm dx.$$ As Sasha hints, this integral is easier to compute when the densities of $X$ and $Y$ have the same scale parameter. – Dilip Sarwate Nov 24 '11 at 16:35
  • @DilipSarwate : I took Sasha's comment to be about degrees of freedom. The number of degrees of freedom is not a scale parameter. – Michael Hardy Nov 24 '11 at 18:45
  • @MichaelHardy : Sasha wrote parameters and so could have meant both scale and degrees of freedom. As you know, $\Chi^2$ random variables are also Gamma random variables, and the sum of independent Gamma random variables with the same scale parameter is a Gamma random variable with the same scale parameter and order parameter equal to the sum of the orders, but the density is a lot messier when the scale parameters are different. I suspect a similar situation for the density of the difference of two $\Chi^2$ random variables; easier to find when the scale parameters are the same. – Dilip Sarwate Nov 24 '11 at 19:49
  • @Sasha: they have the same distribution paramters. – Sophie Nov 25 '11 at 11:15
    A more general question: http://stats.stackexchange.com/questions/48378/difference-of-gamma-random-variables – Felipe G. Nievinski Jun 18 '16 at 18:13
Let's assume that $X$ and $Y$ are independent, and both follow $\chi^2$-distribution with $\nu$ degrees of freedom.
Then $Z = X-Y$ follows symmetric about the origin variance-gamma distribution with parameters $\lambda = \frac{\nu}{2}$, $\alpha=\frac{1}{2}$, and $\beta=0$ and $\mu = 0$.
The best way to see this is through the moment-generating function: $$ \mathcal{M}_X(t) = \mathcal{M}_Y(t) = \left(1-2 \, t\right)^{-\nu/2} $$ Then $$ \mathcal{M}_Z(t) = \mathcal{M}_X(t) \mathcal{M}_Y(-t) = \left( 1-4 t^2 \right)^{-\nu/2} = \left( \frac{1/4}{1/4-t^2}\right)^{\nu/2} $$ We now this that it match the moment generating function of the variance gamma distribution: $$ \mathcal{M}_{\rm{V.G.}(\lambda,\alpha,\beta,\mu)}(t) = \mathrm{e}^{\mu t} \left( \frac{\alpha^2 -\beta^2}{\alpha^2 - (\beta+t)^2 } \right)^\lambda $$ For the said parameters, $\mu=\beta=0$, $\alpha=\frac{1}{2}$ and $\lambda=\frac{\nu}{2}$, the density has the following form: $$ f_Z(z) = \frac{1}{2^{\nu/2}\sqrt{\pi}} \frac{1}{\Gamma\left(\frac{\nu}{2}\right)} \vert z \vert^{\tfrac{\nu-1}{2}} K_\tfrac{\nu-1}{2}\left(\vert z \vert \right) $$ The function $f_Z(z)$ is continuous at $z=0$ for $\nu > 1$, with $$ \lim_{z \to 0} f_Z(z) =\frac{1}{4 \sqrt{\pi }} \frac{\Gamma \left(\frac{\nu }{2}-\frac{1}{2}\right)}{ \Gamma \left(\frac{\nu }{2}\right)} $$
Sasha
  • 70,631
  • Thanks, now I understand it better. I have never thought that I can use the MGF with the variable inverted in sign, i.e., $\mathcal{M}(-t)$. – Sophie Nov 25 '11 at 15:03
  • @Remmy This simply follows because $\mathcal{M}_Z(t) = \mathbb{E}(\exp(t Z)) = \mathbb{E}(\exp(t X) \exp(-t Y)) = \mathcal{M}_X(t) \mathcal{M}_Y(-t)$, because of independence. – Sasha Nov 25 '11 at 15:05
    I thought it would be appropriate to add a paper that referenced this answer (been reading it just now) as a token of appreciation to Sasha: https://arxiv.org/pdf/2005.10009.pdf – NULL Jul 28 '20 at 19:57
  • I am comparing this answer with https://en.wikipedia.org/wiki/Variance-gamma_distribution#:~:text=The%20variance%2Dgamma%20distribution%2C%20generalized,density%20is%20the%20gamma%20distribution. I suspect that there is a mistake in the expression of the pdf... it looks like $\alpha$ should be incorporated into the expression inside the modified Bessel function, shouldn't it? Correspondingly, the normalizing constant should be adjusted. Am I missing something? – Roja Dec 28 '20 at 13:12
