Recently I got interested in the Series of Form,
$$\sum_{r=0}^{\infty}\frac{r^p}{A^{r}}\binom{2r}{r}^{b}$$
I was able to derive this,
$$\left(\frac{\pi^{2}}{4}\right)\sum_{r=0}^{\infty}\frac{a+br}{x^{r}}\binom{2r}{r}^3=\left(\frac{b}{1-2\alpha}\right)K\left(\alpha\right)E\left(\alpha\right)+\left(a-\frac{16b}{32-x\alpha}\right)K\left(\alpha\right)^{2}$$
Where,
$K(k)$ is the Complete Elliptical Integral of the First Kind and $E(k)$ is the Complete Elliptical Integral of the Second Kind with the following convention:
$$K\left(k\right)=\int_{0}^{1}\frac{1}{\sqrt{\left(1-t^{2}\right)\left(1-kt^{2}\right)}}dt$$
$$E\left(k\right)=\int_{0}^{\frac{\pi}{2}}\sqrt{1-k\sin^{2}t}dt$$
and,
$$\alpha=\frac{1}{2}-\frac{1}{2}\sqrt{1-\frac{64}{x}}$$
Now to make the series have an Elegant Form we need to eliminate the Elliptical Integrals from the Right Side.
What I mean by elegant form is something like,
$$\sum_{r=0}^{\infty}\frac{a+br}{x^{r}}\binom{2r}{r}^3=\frac{C}{\pi^2}$$
Where $a, b$ are Integers and $C$ should be a known constant, preferably an Integer but other closed form expressions work too!
$x$ would most likely be a power of $2$ but I am not sure on that.
Modifying the Equations a bit we can write it as,
$$\left(\frac{\pi^{2}}{4}\right)\sum_{r=0}^{\infty}\left(\frac{\left[q+p\left(1-s\right)\right]+\left[p\left(1-2s\right)\right])r}{\left[\frac{16}{s\left(1-s\right)}\right]^{r}}\right)\binom{2r}{r}^3=p\cdot K\left(s\right)E\left(s\right)+q\cdot K\left(s\right)^{2}$$
Now the main problem is that I haven't been able to find $p, q, s$ such that
$$p\cdot K\left(s\right)E\left(s\right)+q\cdot K\left(s\right)^{2}$$
is a known constant.
EDIT:
I searched out some values for the Elliptical Integrals and was able to at least derive this:
$$\sum_{r=0}^{\infty}\left(\frac{1+6r}{2^{8r}}\right)\binom{2r}{r}^3=\frac{4}{\pi}$$
