A1. If you are not familiar with distribution theory, we might consider an alternative approach using the idea of approximate Dirac delta function. Indeed, define
$$ f_{\epsilon}(\mathbf{x}) = \frac{1}{\sqrt{\|\mathbf{x}\|^2+\epsilon^2}}=\frac{1}{\sqrt{x^2+y^2+z^2+\epsilon^2}}. $$
Then its Laplacian is
$$ \Delta f_{\epsilon}(\mathbf{x}) = -\frac{3\epsilon^2}{(x^2+y^2+z^2+\epsilon^2)^{5/2}}. $$
So, if $\varphi$ is any compactly supported smooth function on $\mathbb{R}^3$, then
\begin{align*}
\int_{\mathbb{R}^3} \varphi(\mathbf{x}) \Delta f_{\epsilon}(\mathbf{x}) \, \mathrm{d}\mathbf{x}
&= - \int_{\mathbb{R}^3} \varphi(\mathbf{x}) \frac{3\epsilon^2}{(x^2+y^2+z^2+\epsilon^2)^{5/2}} \, \mathrm{d}\mathbf{x} \\
&= - \int_{0}^{\infty} \int_{\mathbb{S}^2} \varphi(r\omega) \frac{3\epsilon^2 r^2}{(r^2+\epsilon^2)^{5/2}}\, \sigma(\mathrm{d}\omega)\mathrm{d}r \tag{$\mathbf{x}=r\omega$} \\
&= - \int_{0}^{\infty} \int_{\mathbb{S}^2} \varphi(\epsilon s \omega) \frac{3s^2}{(s^2+1)^{5/2}}\, \sigma(\mathrm{d}\omega)\mathrm{d}s, \tag{$r=\epsilon s$}
\end{align*}
where $\mathbb{S}^2$ is the unit sphere centered at the origin and $\sigma$ is the surface measure of $\mathbb{S}^2$. (If this sounds a bit abstract, just think of the spherical coordinates change!) Now letting $\epsilon \to 0^+$, the dominated convergence theorem tells that switching the order of limit and integration is valid in this case, hence the integral converges to
\begin{align*}
\lim_{\epsilon \to 0^+} \int_{\mathbb{R}^3} \varphi(\mathbf{x}) \Delta f_{\epsilon}(\mathbf{x}) \, \mathrm{d}\mathbf{x}
= - \int_{0}^{\infty} \int_{\mathbb{S}^2} \varphi(0) \frac{3s^2}{(s^2+1)^{5/2}}\, \sigma(\mathrm{d}\omega)\mathrm{d}s
= - 4\pi \varphi(0).
\end{align*}
Here, we utilized $\int_{\mathbb{S}^2} \sigma(\mathrm{d}\omega) = 4\pi$ and $\int_{0}^{\infty} \frac{3s^2}{(s^2+1)^{5/2}} \, \mathrm{d}s = 1$.
A2. Still using the above setting, we have
\begin{align*}
\partial^2_x f_{\epsilon}(\mathbf{x})
= \frac{2x^2-y^2-z^2-\epsilon^2}{(\|\mathbf{x}\|+\epsilon^2)^{5/2}}
= \frac{2x^2-y^2-z^2}{(\|\mathbf{x}\|^2+\epsilon^2)^{5/2}} + \frac{1}{3}\Delta f_{\epsilon}(\mathbf{x})
\end{align*}
So it suffices to analyze the contribution of the first term in the last line. To this end, note that if $B_r$ denotes the ball of radius $r$ centered at the origin, then
$$ \int_{B_r} \frac{2x^2-y^2-z^2}{(\|\mathbf{x}\|^2+\epsilon^2)^{5/2}} \, \mathrm{d}\mathbf{x} = 0 $$
by the symmetry, and so, we may write
\begin{align*}
&\int_{\mathbb{R}^3} \varphi(\mathbf{x}) \frac{2x^2-y^2-z^2}{(\|\mathbf{x}\|^2+\epsilon^2)^{5/2}} \, \mathrm{d}\mathbf{x} \\
&= \int_{\mathbb{R}^3} \left( \varphi(\mathbf{x}) - \varphi(0)\mathbf{1}_{B_r}(\mathbf{x}) \right) \frac{2x^2-y^2-z^2}{(\|\mathbf{x}\|^2+\epsilon^2)^{5/2}} \, \mathrm{d}\mathbf{x}
\end{align*}
Introducing the regularizing term $- \varphi(0)\mathbf{1}_{B_r}(\mathbf{x})$ makes the integrand decay fast enough, i.e.,
$$ \left( \varphi(\mathbf{x}) - \varphi(0)\mathbf{1}_{B_r}(\mathbf{x}) \right) (2x^2-y^2-z^2) = \mathcal{O}(\|\mathbf{x}\|^3) $$
as $\|\mathbf{x}\| \to 0$, and so, we can utilize the dominated convergence theorem to conclude that
\begin{align*}
&\lim_{\epsilon \to 0^+} \int_{\mathbb{R}^3} \varphi(\mathbf{x}) \frac{2x^2-y^2-z^2}{(\|\mathbf{x}\|^2+\epsilon^2)^{5/2}} \, \mathrm{d}\mathbf{x} \\
&= \int_{\mathbb{R}^3} \left( \varphi(\mathbf{x}) - \varphi(0)\mathbf{1}_{B_r}(\mathbf{x}) \right) \frac{2x^2-y^2-z^2}{\|\mathbf{x}\|^5} \, \mathrm{d}\mathbf{x}.
\end{align*}
This defines a distribution on $\mathbb{R}^3$ which we may write
$$ \operatorname{p.v.}\left(\frac{2x^2-y^2-z^2}{\|\mathbf{x}\|^5}\right) $$
by analogy with the Cauchy principal value in the one-dimensional setting. In conclusion, we get
$$ \partial_x^2 \frac{1}{\|\mathbf{x}\|} = \operatorname{p.v.}\left(\frac{2x^2-y^2-z^2}{\|\mathbf{x}\|^5}\right) - \frac{4\pi}{3}\delta(\mathbf{x}). $$
