i'm trying to solve the Poisson equation: $$ \begin{split} -\Delta u &= f \quad \text{in } \Omega\\ u &= g \quad \text{on } \partial \Omega, \end{split} $$
where $ \Omega$ is bounded a Lipschitz-continues domain and $u \in H^2(\Omega), f,g \in L^2(\Omega)$. The least squares finite element method minimizes the following energy functional:
$$ J(u;f,g) := \frac{1}{2} \int_{\Omega} (-\Delta u-f)^2 + \int_{\partial\Omega} (u -g)^2 $$
this method leads to the following variational problem: $$ a(u,v) = l(v), \quad \forall v \in V \subset H^2(\Omega) $$ where
$$ \begin{split} a(u,v) &= \int_{\Omega} \Delta u\Delta v + \int_{\partial\Omega} uv \\ l(v) &= \int_{\Omega} -f\Delta v + \int_{\partial\Omega} gv \end{split} $$
It's clear that this bilinear operator is continues. Now i'm trying to proof that $a(v,v)$ is coercive, e.q.
$$ a(v,v) = \int_{\Omega} (\Delta v)^2 + \int_{\partial\Omega} v^2 \geq C\| v\|^2_{H^2(\Omega)} $$
It seems to be hard to prove that, so I tried to show this weaker inequality: $$a(v,v) = \int_{\Omega} (\Delta v)^2 + \int_{\partial\Omega} v^2 \geq C\| v\|^2_{L^2(\Omega)} $$ but with no success.
I don't have the opportunity to choose $u \in H^2(\Omega) \cap H^1_0(\partial \Omega)$, so i had to add the boundary residual to the energy functional $J$. I guess i'm working with the wrong energy.
This is my first question here and i'm thankful for every hint.
skymath
skymath
  • 51
  • Please continue writing the question body. – daw Jul 18 '19 at 14:24
  • i'm finished. Please don't hesitate to ask if i forgot some information – skymath Jul 18 '19 at 15:11
  • I think there is a small issue with the question: if $g$ is only in $L^2(\Omega)$, there is no natural interpretation for its value at the boundary. I believe you need at least $g \in H^{1/2}(\Omega)$ to make sense of it using the trace. – Roberto Rastapopoulos Jul 18 '19 at 15:43
  • could you please explain in more details? – skymath Jul 18 '19 at 15:48
  • You mean: the trace operator i guess only maps $H^{k+2}(\Omega) \rightarrow H^{k+2-1/2}(\partial \Omega)?$ so $g$ has to be from $H^{3/2}$? – skymath Jul 18 '19 at 15:51
  • But then i have to use the following energy functional: $$ J(u;f,g) := \frac{1}{2} |-\Delta u-f|^2_{L^2(\Omega)} + \frac{1}{2} |u -g|^2_{H^{3/2}(\partial\Omega)}$$
    which is pretty ugly and not practical :(
    – skymath Jul 18 '19 at 15:59
  • Sorry, I'm a bit rusty and made lots of typos. Why do you think you would need that functional? – Roberto Rastapopoulos Jul 18 '19 at 16:02
  • Ah ok, I found a reference on the LSFEM. I wasn't aware of it before, and you're right that norm that appears in the energy functional is related to the space of the data. – Roberto Rastapopoulos Jul 18 '19 at 16:05
  • Do you know a way to overcome this impractical functional? I would like to have all the residual-term measured in the $L^2$ norm. Is there some inequality like: $$ | u-g|{H^{3/2}(\partial \Omega)} \leq \tilde{C}| u-g|{L^2(\partial \Omega)} $$ – skymath Jul 18 '19 at 16:11
  • No, that certainly does not hold. Think of a more and more oscilatory $(u - g)$, for example. – Roberto Rastapopoulos Jul 18 '19 at 16:14
  • Where did $\Delta v$ even come from in the first place? The way that $\nabla v$ enters into the conventional weak formulation of the Poisson equation is by integrating by parts once, which converts $\Delta u$ into $\nabla u$. You can get $\Delta v$ as well by integrating by parts twice instead, but then $\nabla u$ becomes $u$. Either way you don't have $\Delta u \Delta v$. – Ian Jul 18 '19 at 16:46
  • It seems to me that if the goal is to minimize that $J$ then you would set $\int_\Omega (-\Delta u - f) v$ and $\int_{\partial \Omega} (u-g) v$ both equal to zero for all $v$ in some suitable class. – Ian Jul 18 '19 at 16:50
  • The energy functional i defined on the beginning was: $$ J(u) = \frac{1}{2}|-\Delta u - f |^2_{L^2(\Omega)} + \frac{1}{2} |u - g|^2_{L^2(\partial \Omega)}$$ If I calculate $\lim_{t \rightarrow 0} \frac{d}{dt}J(u+tv)$ i got: $$ \lim_{t \rightarrow 0} \frac{d}{dt}J(u+tv) = \left<-\Delta u - f, -\Delta v\right>{L^2(\Omega)} + \left<u-g, v\right>{L^2(\partial \Omega)}$$ after setting it equal to zero, i got: $$ \left<\Delta u, \Delta v\right>{L^2(\Omega)} + \left<u, v\right>{L^2(\partial \Omega)} = \left<f, -\Delta v\right>{L^2(\Omega)} + \left<g, v\right>{L^2(\partial \Omega)}$$ – skymath Jul 18 '19 at 17:42
The first coercivity inequality does not hold. Take, for example, the disk-shape domain $\Omega = \{x, y: x^2 + y^2 \leq 1\}$ and consider a sequence of boundary data $g_n$, $n \in \mathbb R$, defined by $g_n = \cos(n\theta(x, y))$, where $\theta(\cdot, \cdot)$ denotes the angle of the argument in $[0, 2\pi]$. Take $v_n$ as being the solution of \begin{align} - \Delta v_n = 0, \qquad & \text{in $\Omega$}, \\ v_n = g_n, \qquad & \text{in $\partial \Omega$}. \end{align} Clearly, $$ \int_{\Omega} (\Delta v_n)^2 + \int_{\partial\Omega} v_n^2 = \int_{\partial \Omega} g_n^2 \leq C. $$ If the first coercivity inequality you wrote was true, it would imply: $$ \|v_n\|_{H^2(\Omega)} \leq C, $$ and thus, by the trace inequality $$ \|v_n\|_{H^{m}(\partial \Omega)} = \|g_n\|_{H^m(\partial\Omega)}\leq C, \qquad 0 \leq m \leq 3/2. $$ Given the form of $g_n$, this is clearly false for $m = 1$.
  • Thank you for that counter example. I also guessed, i chose the wrong energy functional. I'm trying to find other energy, so that i got the coercivity proven. – skymath Jul 18 '19 at 18:00
  • I think you do still get continuity with the $3/2$ Sobolev space, but coercivity seems a bit trickier... – Roberto Rastapopoulos Jul 19 '19 at 10:26
  • last time i read about this inverse inequality, i dont know exactly where: $$ |u|{H^{3/2}(\partial \Omega)} \leq C h^{-3/2} |u|{L^{2}(\partial \Omega)}$$
    would you say with the estimate obove, i would be able to prove this weaker coercivity: $$a(v,v) \geq C(h) |v|_{H^2(\Omega)}$$
    – skymath Jul 19 '19 at 12:38
  • You need to specify the spaces in which you think these inequalities are valid; what is $h$ here? – Roberto Rastapopoulos Jul 24 '19 at 14:11
