There is an answer on the site for solving simple linear congruences via so called 'Gauss's Algorithm' presented in a fractional form. Answer was given by Bill Dubuque and it was said that the fractional form is essentially Gauss, Disquisitiones Arithmeticae, Art. 13, 1801.
Now I have studied the article from the book, but I am not seeing the connection to the fractional form. What Gauss does is reducing $b$ via $p\bmod b= p - qb$ and I do not see that happening in the fractional form nor do I see how it computes an inverse. I have already talked with Bill about this via comments, but decided to open a new question so he or anyone else can help me more intuitively understand what is going on here. This article is supposed to give an algorithm to compute inverses in a prime modulus, yet I have no idea how.
Edit:
Actual question for Bill:
I may have been asking some stupid questions up till now so I will give something concrete and hopefully you can provide an answer to that.
Let's take your sci.math example for this:
So we are looking for a multiplicative inverse $x$ of $60$ in modulo $103$
$$60x \equiv 1 \pmod{103}$$
The tool we can use for this is, as Bill has said, a special case of the Euclidean algorithm which iterates $(p\bmod b,\, p)$ instead of the usual Euclidean algorithm that iterates $(p \bmod b,\, b)$.
This is the result of that algorithm:
$$103=60 \cdot \color{#c00} 1 + 43 = 43 \cdot \color{#c00}2 + 17 = 17 \cdot \color{#c00} 6 + 1$$
And then this translates into the following in mod $103$: $$60 \cdot \color{#c00}{(-1)} \equiv 43 \rightarrow 43 \cdot \color{#c00}{(-2)} \equiv 17 \rightarrow 17 \cdot \color{#c00}{(-6)} \equiv 1$$
Producing the numbers in red which when multiplied give an inverse:
$$60 \cdot \color{#c00}{(-1)(-2)(-6)} \equiv 1 \pmod{103}$$ $$x \equiv-12 \pmod{103}$$
And this is fine and I see it works, of course only when the number and modulo are coprime.
Now my question is why this works. I am not interested in optimisations and different ways of reaching the inverse, but specifically why do the same values of the numbers in red(the coefficients of the algorithm descent) produce an inverse? This method of reusing the coefficients does not work via the normal Euclidean algorithm, but only with this special case. What is special about this? I would like to see a generalized proof or reason as to why the generated numbers produced via this special algorithm have this property.
Bill Dubuque
  • 272,048
    I will answer later when I have more spare time. Others who may be interested in answering can learn the detailed context from the "via comments" link above. – Bill Dubuque Jan 02 '19 at 17:02
  • @BillDubuque I have edited the question to give you specifically the problem I am having with this. Hopefully you will be able to give an answer now. – Michael Munta Feb 28 '19 at 12:21
  • I'm not sure precisely where you are stuck, but maybe placing the various forms side-by-side will prove illuminating - see my answer. – Bill Dubuque Feb 28 '19 at 22:05
  • Are you asking about how congruences like the $\rm\color{#0a0}{green}$ congruence in my answer follow from the corresponding $\rm\color{#0a0}{green}$ equation in the iterated mods preceding it? Or are you asking how the congruence in the final line follows from all before it? – Bill Dubuque Mar 01 '19 at 02:38
  • @BillDubuque Well I am asking both really. Why do the coefficients ${1, 2, 6}$ generated from the initial descent algorithm produce an inverse when multiplied mod $103$? I understand all the other optimizations work simply because of multiplication property of congruences. You keep picking numbers to multiply with as long as it will produce a lesser number mod $n$. But here you don't pick, you generate them with the algorithm first. $p - \color{red}{q_1}b_1 \rightarrow p - \color{red}{q_2}b_2...$ – Michael Munta Mar 01 '19 at 05:55
  • It is like a rule that these specific numbers $\color{red}{q_1}, \color{red}{q_2}$ always produce an inverse. Doesn't such a thing need to be proven not with numbers but generally? Like what is special about those numbers in mod $n$? – Michael Munta Mar 01 '19 at 05:58
  • Maybe it does not even require a proof, I am not sure. Thing is not many people discuss this with you (at least on the internet) and to me that is strange, they just accept that it works. This algorithm has been bothering me since the first time you showed it and I keep feeling that some sort of proof is missing. – Michael Munta Mar 01 '19 at 06:12
  • I added a recursive algorithm and an inductive proof. – Bill Dubuque Mar 04 '19 at 03:51
Below we compare the related forms. First is the iterated descent $\,a\to 103\bmod a\,$ used by Gauss. Second is that rearranged into the form of descending multiples of $60.\,$ Third is the fractional view, and fourth is the graph of the descending multiples of $60$ (denominator descent graph).
$$\begin{align} 103\bmod{60} &= 103 - 1(60) = 43\\ 103\bmod 43 &= 103\color{#0a0}{-2(43)=17}\\ 103\bmod 17 &= 103-6(17) = 1 \end{align}\qquad\qquad\quad$$
$$\begin{array}{rl} \bmod{103}\!:\qquad\ (-1)60\!\!\!\! &\equiv\, 43 &\Rightarrow\ 1/60\equiv -1/43\\[.3em] \smash[t]{\overset{\large\color{#0a0}{*(-2)}}\Longrightarrow}\ \ \ \ \ \ \ \ \ \ (-2)(-1)60\!\!\!\! &\equiv \color{#0a0}{(-2)43\equiv 17}\!\! &\Rightarrow\ 1/60\equiv\ \ \ 2/17\\[.3em] \smash[t]{\overset{\large *(-6)}\Longrightarrow}\ \ \color{#c00}{(-6)(-2)(-1)}60\!\!\!\! &\equiv (-6)17\equiv 1 &\Rightarrow\ 1/60 \equiv {\color{#c00}{-12}}/1\\ \end{array}$$
$$ \begin{align} &\dfrac{1}{60}\ \,\equiv\ \ \dfrac{-1}{43}\, \ \equiv\, \ \dfrac{2}{17}\, \equiv\, \dfrac{\color{#c00}{-12}}1\ \ \ \rm[Gauss's\ algorithm]\\[.3em] &\, 60\overset{\large *(-1)}\longrightarrow\color{#0a0}{43}\overset{\large\color{#0a0}{*(-2)}}\longrightarrow\,\color{#0a0}{17}\overset{\large *(-6)}\longrightarrow 1\\[.4em] \Rightarrow\ \ &\,60*(-1)\color{#0a0}{*(-2)}*(-6)\equiv 1\ \Rightarrow\ 60^{-1}\rlap{\equiv (-1)(-2)(-6)\equiv \color{#c00}{-12}} \end{align}$$
The translation from the first form (iterated mods) to the second (iterated smaller multiples) is realized by viewing the modular reductions as modular multiplications, e.g.
$$\ 103\color{#0a0}{-2(43) = 17}\,\Rightarrow\, \color{#0a0}{-2(43) \equiv 17}\!\!\pmod{\!103} $$
This leads to the following simple recursive algorithm for computing inverses $\!\bmod p\,$ prime.
$\begin{align}\rm I(a,p)\ :=\ &\rm if\ \ a = 1\ \ then\ \ 1\qquad\qquad\ \ \ ; \ \ a^{-1}\bmod p,\,\ {\rm for}\ \ a,p\in\Bbb N\,\ \ \&\,\ \ 0 < a < p\ prime \\[.5em] &\rm else\ let\ [\,q,\,r\,]\, =\, p \div a\qquad ;\, \ \ p = q a + r\ \Rightarrow \color{#0a0}{-qa\,\equiv\, r}\!\!\pmod{\!p},\ \ 0 < r < a\,\\[.2em] &\rm\ \ \ \ \ \ \ \ \ ({-}q*I(r,p))\bmod p\ \ \ ;\ \ because\ \ \ \dfrac{1}a \equiv \dfrac{-q}{\color{#0a0}{-qa}}\equiv \dfrac{-q}{\color{#0a0}r}\equiv -q * I(r,p)\ \ \ \ \ \color{#90f}{[\![1]\!]} \end{align} $
Theorem $\ \ {\rm I(a,p)} = a^{-1}\bmod p$
Proof $\ $ Clear if $\,a = 1.\,$ For $\,a > 1,\,$ suppose for induction the theorem holds true for all $\,n < a$. Since $\,p = qa+r\,$ we must have $\,r > 0\,$ (else $\,r = 0\,\Rightarrow\,a\mid p\,$ and $\,1< a < p,\,$ contra $\,p\,$ prime). Thus $\,0 < r < a\,$ so induction $\,\Rightarrow\,{\rm I(r,p)}\equiv \color{#0a0}{r^{-1}}$ so reducing equation $\color{#90f}{[\![1]\!]}\bmod p\,$ yields the claim.
Bill Dubuque
  • 272,048
  • Thank you for the edit. Now I have a full picture of this. So the only important fact about the algorithm is that eventually it will reach $1$. Once we have the equational forms we can rearrange each of them into mod $103$ like so: $$103 - 1(60) = 43 \rightarrow -60 + 1(103) = 43 \rightarrow -60 \equiv 43$$ From here on we just use the next steps of the algorithm to write the congruences in terms of $60$ and it is true because of the $a \equiv b$ (mod $n$) $\rightarrow ka \equiv kb$ (mod $n$) property. Is that about right? – Michael Munta Mar 04 '19 at 10:20
  • Also this normal method (where there is no allowing of +/- multipliers/remainders) works only when the modulus is prime like the example here. But since an inverse exists when the numbers are coprime then a prime modulo is not always required if we allow +/- multipliers/remainders like in your post. For example inverse of $4$ modulo $15$. $$15 - 3(4) = 3$$ $$15 - 3(5) = 0$$ It does not terminate at $1$ because $15$ is not prime. – Michael Munta Mar 11 '19 at 13:33
  • But when we allow the above mentioned quicker method then it sometimes works. $$15 - 4(4) = -1$$ Multiply both sides by $-1$ and then $$-15 + 4(4) = 1$$ Is this correct and are we allowed to multiply the intermediary steps like so? So is this also called 'Gauss algorithm' or only when we restrict positive remainders? – Michael Munta Mar 11 '19 at 13:36
  • @Michael Yes, it may fail for composite moduli, but then we can use the general extended Eucldiean algorithm, which also can be viewed in fractional form. – Bill Dubuque Mar 11 '19 at 14:34
  • And multiplying the equation as I have done is ok to do? It should still be the same mod $15$? I suppose that is what you did in quicker method. – Michael Munta Mar 11 '19 at 17:41
  • @Michael The scaled congruence will be equivalent only if the scale factor is invertible (so cancellable). Ditto for scaling fractions (where denominators must be coprime to the modulus for the fraction to be uniquely defined). – Bill Dubuque Mar 11 '19 at 17:48
  • Does that mean what I did is correct? Not really sure I understand what you meant. – Michael Munta Mar 11 '19 at 18:45
  • @Michael Yes, $\bmod 15!:\ \dfrac{1}4\equiv \dfrac{4}{16}\equiv \dfrac{4}{1}\ $ is true, but not $,\dfrac{1}4\equiv \dfrac{3}{12}\equiv \dfrac{3}{-3}\equiv -1\ $ because we multiplied (and cancelled) by a noninvertible element $3$. The multipliers (and denominators) must all be invertible (coprime to the modulus) to obtain correct results. – Bill Dubuque Mar 11 '19 at 18:53
  • I believe you misinterpreted me. I meant where I multiplied both sides by $-1$. Is that allowed because it should still be in modulo $15$? – Michael Munta Mar 11 '19 at 19:47
  • @MichaelMunta $-1$ is invertibe (its own inverse) so scaling by it yields an equivalent congruence. – Bill Dubuque Mar 11 '19 at 19:51
I'm not sure I've properly understood what you're looking for, but since the reason why the algorithm works seems to me to be patently clear from the formal proof that it does, in fact, work, here's such a proof for the general case.
Starting with a prime $\ p\ $, and an integer $\ b_0\in \left[1, p\right]\ $, the algorithm successively produces integers $\ b_1<b_0,b_2<b_1, \dots, b_{i+1} < b_i, \dots\ $, with $\ b_{i+1} \equiv -q_i\ b_i\ \left(\,\mathrm{mod }\ p\,\right)\ $, until it obtains $\ b_n = 1\ $. As long as $\ b_i \not\in\left\{0, 1\right\}\ $, it's always possible to carry out the next step of the procedure by using the division algorithm: $\ p = q_i\,b_i + b_{i+1}\ $, and since the sequence $\ b_0, b_1, \dots\ b_i, \dots $ is strictly decreasing, the algorithm must eventually terminate with $\ b_n\in\left\{0, 1\right\}\ $. If $\ b_n\ $ were $\ 0\ $, however, the final step of the algorithm would have been $\ p = q_{n-1}\,b_{n-1} + b_n = q_{n-1}\,b_{n-1}\ $, whence $\ b_{n-1}\ $, strictly smaller than the prime $\ p\ $, would be a divisor of it, and hence equal to $\ 1\ $. Thus, the algorithm would have terminated on the preceeding step.
Thus the algorithm always terminates with $\ b_n=1\ $, and we then have \begin{eqnarray} 1&\equiv& -q_{n-1}\,b_{n-1}\equiv q_{n-1}\,q_{n-2}\,b_{n-2}\equiv\dots\\ &\equiv& \left(-1\right)^n\,q_{n-1}\,q_{n-2}\dots q_0\,b_0\ \left(\,\mathrm{mod}\,p\,\right)\ \end{eqnarray}.
lonza leggiera
  • 28,646
  • 33
  • Do you think that my last comment on Bill's answer generally sums up the algorithm? – Michael Munta Mar 07 '19 at 19:11
  • It looks ok to me, although I wouldn't say that the algorithm's eventually reaching $\ 1\ $ is the only important fact about it. There's also the fact that the number you calculate at each stage is just a non-zero multiple $\ \mathrm{mod}\ p\ $ of the previous one. If it were a more complicated polynomial function of the previous number, with a non-zero constant term, for instance, the algorithm wouldn't work. – lonza leggiera Mar 07 '19 at 22:49
  • Well, yes. But the thing with rearranging and the property are fine though? – Michael Munta Mar 08 '19 at 05:12
  • Sure. $\ \ \ \ \ $ – lonza leggiera Mar 08 '19 at 09:08
  • Did you take a look at Gauss article that is linked in the question? The answer that Bill provided here is related to that article, but do you think that this answer, also shown by Bill, https://math.stackexchange.com/questions/174676/solving-linear-congruences-by-hand-modular-fractions-and-inverses/174687#174687 is related to that article? – Michael Munta Sep 11 '20 at 09:18
