finding points of discontinuity of the function $f(x) = e^{x + (1/x)} $ and state their types.
My answer: this function has an essential discontinuity at 0, am I correct?
A key data about $f$ is missong: its domain and codomain.
Anyway. It is simpler to deal with $e^{1/x}$ and, once you have understood it, may be multiply it by $e^x$ and then try to apply L'Hospital rule or something.
For complex numbers $z\in\mathbb{C}\setminus\{0\}$, the imaginary poles of the function $$f(z)=e^{1/z}$$ around $z=0$ are easily figured out: For any integer number $k$, $f$ has a pole at $$z_k=\frac{1}{2\pi ik}.$$ Now notice that, for any positive radius $r>0$, the domain of $f$ restricted to the open ball of radius $r$ centered at $z_\infty=0$ has an infinite number of poles. Thus $f$ has an essential singularity at $0$.
Now I ask you to complete the reasoning and comment: If $e^{1/z}$ has an essential singularity at $z=0$, then which type of singularity does $e^{z+1/z}$ has?
