Let $U$ be a unitary operator on a Hilbert space $\mathcal{H}$. By the spectral theorem, it is known that $\sigma(U)\subseteq \{z\in \mathbb{C}:|z|=1\}$. How can the explicit inverse of $\lambda-U$ be calculated for $|\lambda|<1$ (or $|\lambda|>1$)?
Next let $R$ be the right shift operator on $l^{2}(\mathbb{N})$. Consider $[R]\in \frac{B(l^{2}(\mathbb{N}))}{K(l^{2}(\mathbb{N}))}$, where $K(l^{2}(\mathbb{N})$) is the set of compact operators on $l^{2}(\mathbb{N})$, and so the algebra considered is the Calkin algebra. $R$ is then unitary mod a compact operator, i.e., $[R]$ is unitary in the Calkin algebra. How can the explicit inverse of $\lambda-[R]$ be found for $|\lambda|<1$ (or $|\lambda>1$)?
