174
I have a friend who turned $32$ recently. She has an obsessive compulsive disdain for odd numbers, so I pointed out that being $32$ was pretty good since not only is it even, it also has no odd factors. That made me realize that $64$ would be an even better age for her, because it's even, has no odd factors, and has no odd digits. I then wondered how many other powers of $2$ have this property. The only higher power of $2$ with all even digits that I could find was $2048.$
So is there a larger power of $2$ with all even digits? If not, how would you go about proving it?
I tried examining the last $N$ digits of powers of $2$ to look for a cycle in which there was always at least one odd digit in the last $N$ digits of the consecutive powers. Unfortunately, there were always a very small percentage of powers of $2$ whose last $N$ digits were even.
Edit: Here's a little more info on some things I found while investigating the $N$ digit cycles.
$N$: $2,3,4,5,6,7,8,9$
Cycle length: $20,100,500,2500,12500,62520,312500,1562500,\dotsc, 4\cdot 5^{N-1}$
Number of suffixes with all even digits in cycle: $10, 25, 60, 150, 370, 925, 2310,5780,\sim4\cdot2.5^{N-1}$
It seems there are some interesting regularities there. Unfortunately, one of the regularities is those occurrences of all even numbers! In fact, I was able to find a power of $2$ in which the last $33$ digits were even $(2^{3789535319} = \dots 468088628828226888000862880268288)$.
Yes it's true that it took a power of $2$ with over a billion digits to even get the last $33$ to be even, so it would seem any further powers of $2$ with all even digits are extremely unlikely. But I'm still curious as to how you might prove it.
Edit 2: Here's another interesting property I noticed. The next digit to the left of the last $N$ digits will take on every value of its parity as the $N$ digits cycle each time. Let me illustrate.
The last $2$ digits cycle every $20$ powers. Now examine the following:
$2^7 = 128$
$2^{27} = \dots 728$
$2^{47} = \dots 328$
$2^{67} = \dots 928$
$2^{87} = \dots 528$
$2^{107} = \dots 128$
Notice that the hundreds place starts out odd and then proceeds to take on every odd digit as the final 2 digits cycle.
As another example, let's look at the fourth digit (knowing that the last 3 digits cycle every 100 powers.)
$2^{18} = 262144$, $2^{118} = \dots 6144$, $2^{218} = \dots 0144$, $2^{318} = \dots 4144$, $2^{418} = \dots 8144$, $2^{518} = \dots 2144$
This explains the power of 5 in the cycle length as each digit must take on all five digits of its parity.
EDIT 3: It looks like the $(N+1)$st digit takes on all the values $0-9$ as the last $N$ digits complete half a cycle. For instance, the last $2$ digits cycle every $20$ powers, so look at the third digit every $10$ powers:
$2^{8} = 256$, $2^{18} = \dots 144$, $2^{28} = \dots 456$, $2^{38} = \dots 944$, $2^{48} = \dots 656$, $2^{58} = \dots 744$, $2^{68} = \dots 856$, $2^{78} = \dots 544$, $2^{88} = \dots 056$, $2^{98} = \dots 344$
Not only does the third digit take on every value 0-9, but it also alternates between odd and even every time (as the Edit 2 note would require.) Also, the N digits cycle between two values, and each of the N digits besides the last one alternates between odd and even. I'll make this more clear with one more example which looks at the fifth digit:
$2^{20} = \dots 48576$, $2^{270} = \dots 11424$, $2^{520} = \dots 28576$, $2^{770} = \dots 31424$, $2^{1020} = \dots 08576$, $2^{1270} = \dots 51424$, $2^{1520} = \dots 88576$, $2^{1770} = \dots 71424$, $2^{2020} = \dots 68576$, $2^{2270} = \dots 91424$
EDIT 4: Here's my next non-rigorous observation. It appears that as the final N digits cycle 5 times, the $(N+2)$th digit is either odd twice and even three times, or it's odd three times and even twice. This gives a method for extending an all even suffix.
If you have an all even N digit suffix of $2^a$, and the (N+1)th digit is odd, then one of the following will have the (N+1)th digit even:
$2^{(a+1*4*5^{N-2})}$, $2^{(a+2*4*5^{N-2})}$, $2^{(a+3*4*5^{N-2})}$
Edit 5: It's looking like there's no way to prove this conjecture solely by examining the last N digits since we can always find an arbitrarily long, all even, N digit sequence. However, all of the digits are distributed so uniformly through each power of 2 that I would wager that not only does every power of 2 over 2048 have an odd digit, but also, every power of 2 larger than $2^{168}$ has every digit represented in it somewhere.
But for now, let's just focus on the parity of each digit. Consider the value of the $k^{th}$ digit of $2^n$ (with $a_0$ representing the 1's place.)
$$ a_k = \left\lfloor\frac{2^n}{10^k}\right\rfloor \text{ mod 10}\Rightarrow a_k = \left\lfloor\frac{2^{n-k}}{5^k}\right\rfloor \text{ mod 10} $$
We can write $$2^{n-k} = d\cdot5^k + r$$ where $d$ is the divisor and $r$ is the remainder of $2^{n-k}/5^k$. So $$ a_k \equiv \frac{2^{n-k}-r}{5^k} \equiv d \pmod{10} $$ $$\Rightarrow a_k \equiv d \pmod{2}$$ And $$d\cdot5^k = 2^{n-k} - r \Rightarrow d \equiv r \pmod{2}$$ Remember that $r$ is the remainder of $2^{n-k} \text{ div } {5^k}$ so
$$\text{The parity of $a_k$ is the same as the parity of $2^{n-k}$ mod $5^k$.}$$
Now we just want to show that for any $2^n > 2048$ we can always find a $k$ such that $2^{n-k} \text{ mod }5^k$ is odd.
I'm not sure if this actually helps or if I've just sort of paraphrased the problem.
EDIT 6: Thinking about $2^{n-k}$ mod $5^k$, I realized there's a way to predict some odd digits.
$$2^a \pmod{5^k} \text{ is even for } 1\le a< log_2 5^k$$
The period of $2^a \pmod{5^k}$ is $4\cdot5^{k-1}$ since 2 is a primitive root mod $5^k$. Also
$$2^{2\cdot5^{k-1}} \equiv -1 \pmod{5^k}$$
So multiplying any $2^a$ by $2^{2\cdot5^{k-1}}$ flips its parity mod $5^k$. Therefore $2^a \pmod{5^k}\text{ }$ is odd for
$$1 + 2\cdot5^{k-1} \le a< 2\cdot5^{k-1} + log_2 5^k$$
Or taking the period into account, $2^a \pmod{5^k} \text{ }$ is odd for any integer $b\ge0$ such that
$$1 + 2\cdot5^{k-1} (1 + 2b) \le a< 2\cdot5^{k-1} (1 + 2b) + log_2 5^k$$
Now for the $k^{th}$ digit of $2^n$ ($ k=0 \text{ } $ being the 1's digit), we're interested in the parity of $2^{n-k}$ mod $5^k$. Setting $ a =n-k \text{ } $ we see that the $k^{th}$ digit of $2^n$ is odd for integer $b\ge0$ such that
$$1 + 2\cdot5^{k-1} (1 + 2b) \le n - k < 2\cdot5^{k-1} (1 + 2b) + log_2 5^k$$
To illustrate, here are some guaranteed odd digits for different $2^n$:
(k=1 digit): $ 2\cdot5^0 + 2 = 4 \le n \le 5 $
(k=2 digit): $ 2\cdot5^1 + 3 = 13 \le n \le 16 $
(k=3 digit): $ 2\cdot5^2 + 4 = 54 \le n \le 59 $
(k=4 digit): $ 2\cdot5^3 + 5 = 255 \le n \le 263 $
Also note that these would repeat every $4\cdot5^{k-1}$ powers.
These guaranteed odd digits are not dense enough to cover all of the powers, but might this approach be extended somehow to find more odd digits?
Edit 7: The two papers that Zander mentions below make me think that this is probably a pretty hard problem.
Simon Fraser
  • 2,528
    I just wrote a program that tested all of the powers of 2 up to 2^1,000,000 and 2^11 (2048) was the highest one it could find. – PhiNotPi Mar 03 '12 at 17:49
  • 75
    Do not mention 64. Try flowers. – Will Jagy Mar 03 '12 at 19:28
    Flowers would probably be easier at this point. I have been pointedly silent on the matter since I offhandedly mentioned that "I might see if I can prove this conjecture" a while ago. – Brian Rothstein Mar 04 '12 at 08:50
    I find it interesting that only 5 of these numbers have been found (with a conjecture that the list is complete). This strikes me as oddly similar to Fermat primes. There are only 5 known Fermat primes (primes of the form $2^{2^n}+1$) and conjecturally that list is complete. Maybe these conjectures are equivalent. +1 Nice question. – Bill Cook Mar 09 '12 at 21:59
  • Have you tried posting this at MO? – Fernando Martin Mar 31 '12 at 18:12
  • @Fernando: I haven't tried posting it there. Maybe it would make a good post. After all, it seems shocking that a conjecture with such overwhelming evidence (e.g. the number of odd and even digits in powers of 2 stay very close to a 50/50 ratio) is resistant to a definitive proof. I'm sort of scared to post it on MathOverflow though, because I'm really out of my depth. – Brian Rothstein Mar 31 '12 at 23:45
    @WillJagy Just make sure it's an even number of flowers. – Evicatos Jan 04 '14 at 00:24
  • There's some surprising structure in the digits of the powers of five. One can prove the distribution of digits in each position tends to equality for larger positions. One can also show any amount of zeros in a row occur (which much easier to prove for powers coprime to $10$). Ex: $5^{262164} = ...9900000095367431640625$. My work is here (secion 10: https://arxiv.org/abs/1910.13829). There's similar work here: https://math.stackexchange.com/questions/1086583/pattern-in-decimal-representation-of-powers-of-5 Not clear yet if any of it applies to powers of $2$. –  Nov 12 '19 at 19:35
  • Maybe techniques from Digitally Delicate Prime proofs could help with this problem? – Brian Rothstein Mar 31 '21 at 19:44
  • @Evicatos: Actually, in many cultures, please make sure it's NOT an even number of flowers.. – Catalin Zara Mar 25 '24 at 20:13
This seems to be similar to (I'd venture to say as hard as) a problem of Erdős open since 1979, that the base-3 representation of $2^n$ contains a 2 for all $n>8$.
Here is a paper by Lagarias that addresses the ternary problem, and for the most part I think would generalize to the question at hand (we're also looking for the intersection of iterates of $x\rightarrow 2x$ with a Cantor set). Unfortunately it does not resolve the problem.
But Conjecture 2' (from Furstenberg 1970) in the linked paper suggests a stronger result, that every $2^n$ for $n$ large enough will have a 1 in the decimal representation. Though it doesn't quantify "large enough" (so even if proved wouldn't promise that 2048 is the largest all-even decimal), it looks like it might be true for all $n>91$ (I checked up to $n=10^6$).
Zander
  • 10,948
  • 26
  • 54
35
This sequence is known to the OEIS.
Here are the notes, which give no explicit answer but suppose that your conjecture is correct:
Are there any more terms in this sequence?
Evidence that the sequence may be finite, from Rick L. Shepherd (rshepherd2(AT)hotmail.com), Jun 23 2002:
1) The sequence of last two digits of $2^n$, A000855 of period $20$, makes clear that $2^n > 4$ must have $n = 3, 6, 10, 11,$ or $19 (\text{mod }20)$ for $2^n$ to be a member of this sequence. Otherwise, either the tens digit (in $10$ cases), as seen directly, or the hundreds digit, in the $5$ cases receiving a carry from the previous power's tens digit $\geq 5$, must be odd.
2) No additional term has been found for n up to $50000$.
3) Furthermore, again for each n up to $50000$, examining $2^n$'s digits leftward from the rightmost but only until an odd digit was found, it was only once necessary to search even to the 18th digit. This occurred for $2^{12106}$ whose last digits are $\ldots 3833483966860466862424064$. Note that $2^{12106}$ has $3645$ digits. (The clear runner-up, $2^{34966}$, a $10526$-digit number, required searching only to the $15$th digit. Exponents for which only the $14$th digit was reached were only $590, 3490, 8426, 16223, 27771, 48966$ and $49519$ - representing each congruence above.)
Listing
  • 13,937
  • and 3) clearly don't prove anything, and 1) sounds rather vague to me, too – but my number theory knowledge is $<\varepsilon$, so... Perhaps someone comment on how much this actually means?
  • – leftaroundabout Mar 03 '12 at 22:37
    @leftaroundabout, indeed this is not a proof but what this suggests is that the theorem is likely to be true due to probabilistic reasons even though it can be very hard to find a proof for this. – Listing Mar 03 '12 at 22:43
    @Listing: Thanks for putting the bounty on this question! I don't want my OCD friend worrying that there might be a small chance that she'll need to live past age 2048 to reach another nice age. – Brian Rothstein Mar 09 '12 at 11:49
