In typical experimental tradition, let's write code to check this out.
(defun difficult-to-double-p (n)
(loop :for (x y) := (multiple-value-list (floor n 10))
:then (multiple-value-list (floor x 10))
:thereis (> y 4)
:until (zerop x)))
(defun test (max-pow)
(loop :for x := 1 :then (* 2 x)
:for i :from 0 :to max-pow
:unless (difficult-to-double-p x)
:do (format t "~D " i)))
This will print out the powers of 2 that satisfy your condition. I tried it up to $n=500,000$ and only came up with $\{0, 1, 2, 5, 10\}$. Is it a coincidence that those powers of 2, except for $n=0$, are factors of 10?
Here is the output for the curious.
> (test 500000)
0 1 2 5 10
Evaluation took:
174.270 seconds of real time
174.940405 seconds of total run time (173.307653 user, 1.632752 system)
[ Run times consist of 5.225 seconds GC time, and 169.716 seconds non-GC time. ]
100.38% CPU
371,799,804,896 processor cycles
46,761,694,928 bytes consed
NIL
EDIT: Instead of doubling, let's try $k$-tupling. Here's a good ol' table for $2 \le n \le 100$:
2: 0 1 2 5 10
3: 0 1 5
4: 0 1 5
5: 0
6: 0
7: 0 3 4
8: 0
9: 0
10: 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
11: 0 1 2 3
12: 0 1 2
13: 0 1
14: 0 1
15: 0
16: 0
17: 0
18: 0 2 6
19: 0 4
20: 0 1 2 5 10
21: 0 1 2
22: 0 1
23: 0 1
24: 0 1
25: 0
26: 0
27: 0
28: 0
29: 0
30: 0 1 5
31: 0 1
32: 0 1 2
33: 0 1
34: 0 1
35: 0
36: 0
37: 0
38: 0 2
39: 0 4
40: 0 1 5
41: 0 1
42: 0 1
43: 0 1
44: 0 1
45: 0
46: 0
47: 0
48: 0 2
49: 0 2
50: 0
EDIT 2: Next, let's try changing the base $b$, where the digits must be between $0$ and $\tfrac{b}{2}-1$ if $b$ is even, $\lfloor b/2\rfloor$ if odd. Here's a table of $b$ for $2 \le n\le 100$.
3: 0 2 8
4: 0 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100
5: 0 1 5 8
6: 0 1 3 9
7: 0 1 3 4 6 9
8: 0 1 3 4 6 7 9 10 12 13 15 16 18 19 21 22 24 25 27 28 30 31 33 34 36 37 39 40 42 43 45 46 48 49 51 52 54 55 57 58 60 61 63 64 66 67 69 70 72 73 75 76 78 79 81 82 84 85 87 88 90 91 93 94 96 97 99 100
9: 0 1 2 8 13 14
10: 0 1 2 5 10
11: 0 1 2 4 8 14 30
12: 0 1 2 4 6 12
13: 0 1 2 4 5 9 24
14: 0 1 2 4 5 8 10 25
15: 0 1 2 4 5 6 8 9 12 13 16 24
16: 0 1 2 4 5 6 8 9 10 12 13 14 16 17 18 20 21 22 24 25 26 28 29 30 32 33 34 36 37 38 40 41 42 44 45 46 48 49 50 52 53 54 56 57 58 60 61 62 64 65 66 68 69 70 72 73 74 76 77 78 80 81 82 84 85 86 88 89 90 92 93 94 96 97 98 100
17: 0 1 2 3 11 18
18: 0 1 2 3 7 13
19: 0 1 2 3 6 14 18 19 34
20: 0 1 2 3 6 7 11
21: 0 1 2 3 6 7 9 12 18 45
22: 0 1 2 3 5 9 11 12 19
23: 0 1 2 3 5 8
24: 0 1 2 3 5 7 25
25: 0 1 2 3 5 7 8 14 21
26: 0 1 2 3 5 6 13
27: 0 1 2 3 5 6 8 13
28: 0 1 2 3 5 6 8 12
29: 0 1 2 3 5 6 7 10
30: 0 1 2 3 5 6 7 10 11 13 15 22
31: 0 1 2 3 5 6 7 8 10 11 12 15 16 17 20 21 25 36
32: 0 1 2 3 5 6 7 8 10 11 12 13 15 16 17 18 20 21 22 23 25 26 27 28 30 31 32 33 35 36 37 38 40 41 42 43 45 46 47 48 50 51 52 53 55 56 57 58 60 61 62 63 65 66 67 68 70 71 72 73 75 76 77 78 80 81 82 83 85 86 87 88 90 91 92 93 95 96 97 98 100
33: 0 1 2 3 4 14 23 42
34: 0 1 2 3 4 9 17 49
35: 0 1 2 3 4 8 12 14 40
36: 0 1 2 3 4 8 9
37: 0 1 2 3 4 7 11
38: 0 1 2 3 4 7 9 14 21 38
39: 0 1 2 3 4 7 9 13 16 33
40: 0 1 2 3 4 7 8 11 20 27
41: 0 1 2 3 4 7 8 9 15
42: 0 1 2 3 4 7 8 9 14 19 20 28
43: 0 1 2 3 4 6 12 20
44: 0 1 2 3 4 6 12 13 14 22
45: 0 1 2 3 4 6 9 12 13 14 15 24 25 26 36 45
46: 0 1 2 3 4 6 9 10 15
47: 0 1 2 3 4 6 8 19 21 39
48: 0 1 2 3 4 6 8 10 14 20
49: 0 1 2 3 4 6 8 9 13
50: 0 1 2 3 4 6 8 9 10 15 17 23
And here's a pictorial representation. Dot means easy, space means not.
4: . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
5: .. . .
6: .. . .
7: .. .. . .
8: .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ..
9: ... . ..
10: ... . .
11: ... . . . .
12: ... . . .
13: ... .. . .
14: ... .. . . .
15: ... ... .. .. . .
16: ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... ... .
17: .... . .
18: .... . .
19: .... . . .. .
20: .... .. .
21: .... .. . . . .
22: .... . . .. .
23: .... . .
24: .... . . .
25: .... . .. . .
26: .... .. .
27: .... .. . .
28: .... .. . .
29: .... ... .
30: .... ... .. . . .
31: .... .... ... ... .. . .
32: .... .... .... .... .... .... .... .... .... .... .... .... .... .... .... .... .... .... .... .... .
33: ..... . . .
34: ..... . . .
35: ..... . . . .
36: ..... ..
37: ..... . .
38: ..... . . . . .
39: ..... . . . . .
40: ..... .. . . .
41: ..... ... .
42: ..... ... . .. .
43: ..... . . .
44: ..... . ... .
45: ..... . . .... ... . .
46: ..... . .. .
47: ..... . . . . .
48: ..... . . . . .
49: ..... . .. .
50: ..... . ... . . .
51: ..... . ... . . .
52: ..... .. ... .
53: ..... .. . . . .
54: ..... .. . .
55: ..... .. . .
56: ..... .. .. . .
57: ..... ... . . .
58: ..... ... .
59: ..... ... . . . . . . .
60: ..... ... . . .. .
61: ..... .... .. . .
62: ..... .... ... . .. .. .
63: ..... ..... .... .... ... .. . .
64: ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... ..... .....
65: ...... . . .
66: ...... . .
67: ...... . . .
68: ...... .. . . .
69: ...... . .
70: ...... . . . . .
71: ...... .. .. . . . .
72: ...... ... . . ..
73: ...... ... . .
74: ...... . .
75: ...... . . . .
76: ...... . . . . .
77: ...... . . . .. .
78: ...... . .. . . . .
79: ...... .. . .. .
80: ...... .. . ..
81: ...... .. . ..
82: ...... ... . .
83: ...... ... . .. .
84: ...... .... . . . . .
85: ...... .... . ... . . . . .
86: ...... . . . . . .
87: ...... . .. .. .
88: ...... . . ... .
89: ...... . . .... . .
90: ...... . . ..... .... ..
91: ...... . . .
92: ...... . .. .
93: ...... . ... . . .
94: ...... . . . .
95: ...... . . . . . .
96: ...... . . . . .
97: ...... . . .. . .
98: ...... . .. .
99: ...... . .. .
100: ...... . ... . . .
EDIT 3: Define base $b$ to be easy if there are an infinite number of easy doublings.
CONJECTURE 1: The only easy bases are $2^j$ for $j\ge 2$.
A friend noticed...
CONJECTURE 2: The only hard-to-double numbers in base $2^j$ are numbers whose power is $\{ij-1\mid i\ge 1\}$.
And from the picture, notice when the leftmost column gets thicker. It happens after each power of two.
CONJECTURE 3: $2^n$ in base $2^k$ is easy to double for all $k > n$.
