I have to prove why each Peano axiom that doesn't hold for a set $\mathbb{N}$ with base case $1$, and $S(1) = 2, S(2) = 3, S(3) = 1$, and $S(n) = n + 1$ for all $n \geq 4$.
Obviously $S(3) = 1$ breaks one of the axiom's rules because the base case is not allowed to be a successor. I'm not sure if this requires a rigorous proof.
The induction principle does not hold (intuitively) because the number $4$ is not a successor of anything, even though it has to be a successor of something in order for the induction principle to work. However, I don't know how to rigorously show that the induction principle in general does not work for this entire system, and not just for the special case of the number $4$.
  • Reading the title, I thought you were taking up the challenge in this answer (are you by any means called Nelson?). Fortunately this impression appears to be wrong. – Marc van Leeuwen Sep 23 '14 at 06:16
  • See post and Qiaochu's answer: "One point of view is that 'the natural numbers satisfy induction' is part of what we mean when we're talking about the natural numbers; that is, part of the definition of the natural numbers should be 'those things that satisfy induction.' This is just a slightly more sophisticated version of "the natural numbers are what you get when you start with 1, then add 1 to it, then add 1 to it, then..." In your model you can never reach 4 iterating the basic operation "+1". – Mauro ALLEGRANZA Sep 23 '14 at 06:33
Assuming you have $S(4)=5, S(5)=6, S(6)=7, ...$
Some of the Peano Axioms do hold:
$1\in \mathbb{N}$ (edit)
$S: \mathbb{N} \to \mathbb{N}$
$S$ is injective
The two remaining axioms do not hold. (edit)
As you point out, $\forall x\in \mathbb{N}:S(x)\ne 1$ is falsified since you have $S(3)=1$. (edit)
The induction principle does not hold (intuitively) because the number 4 is not a successor of anything, even though it has to be a successor of something in order for the induction principle to work.
Peano's axioms do not require that every number but $1$ has a predecessor, although induction can be used to prove this.
Hint as to the actual reason why this function $S$ does not satisfy the induction axiom:
Let $P=\{1, 2, 3\}$.
$1\in P$.
$k\in P \implies S(k)\in P$
ADDED:
That was not very clear, I'm afraid. Induction will not hold on $\mathbb{N}$ with your successor function $S$ because we have a subset $X=\{4, 5, 6, ...\}$ the elements of which are not connected in any way to the subset $P=\{1, 2, 3\}.$
We have:
$1\notin X$
$\forall x\in X:\neg \exists y\in \mathbb{N}:[y\notin X\land S(y)=x]$
If we have $P=\{1,2,3\}$, then it can be shown that:
$$1\in P \land \forall x\in P: S(x)\in P\land \exists x\in N: x\notin P]$$
Generalizing...
$$\exists P\subset N : [1\in P \land \forall x\in P: S(x)\in P\land \exists x\in N: x\notin P]]$$
Or equivalently...
$$\neg\forall P\subset N:[1\in P \land \forall a\in P: S(a)\in P \implies P=N]$$
This the negation of the induction axiom.
Also see my answer at Are there natural numbers that are not the descendant of 0?
It seems you have already established that one of the axioms is not made true by the model, so you don't anything more to see that you don't have a valid model of Peano's axioms.
But you can easily show that that the induction principple fails as well, for instance for the predicate $P(n):n\neq 4$, or if you want something more interesting looking $P(n):n\in\{1,2,3\}\lor n>99$.
