In First Order Logic with Identity (FOL+I), one can express the proposition that there are exactly 3 items that have the property P.
Why is it not possible to express the proposition that there is a finite number of items that have the property P (in FOL+I)?
bryn
  • 9,746
We can define formula $P_i$ that says "there are at most $i$ elements satisfying $P$". Now, if the infinite disjunction of the $P_i$ was definable in FO, it would (by compactness) imply a conjunction of some finite subset of the $P_i$, hence it would imply $P_i$ for some $i$. That is not true, if $P$ can have (say) $i+1$ elements satisfying it.
14
Any property expressible under first-order logic is closed under ultraproducts. The property of finite sets is not, however, closed under ultraproducts.
Akhil Mathew
  • 31,310
-1
Well, it would mean that you have the statement $P_1\vee P_2\vee\ldots$ where $P_i$ stands for "there are $i$ objects with property $P$", and infinite disjunctions aren't allowed. As for proving that this isn't equivalent to anything else you can write that IS allowed, I don't know how to do that.
  • Yes, I agree that the fact that I could define $P_3$ was irrelevant because of the inability to form an infinite disjunction, but I included it to give the question a bit of a context. – bryn Jul 28 '10 at 02:17
-3
I think you can express "forall but finitely many" in FOL, which means "for all sufficiently large". But I am not sure whether this is equivalent to "finitely many", it seems to be a little bit different. See http://arxiv.org/pdf/math/0602415.pdf.
    This is not the same thing. Not all structures are the natural numbers, and not all languages have a binary symbol interpreted as a linear order. It is true that in $(\Bbb N,\leq)$ you can say that something happens to only finitely many numbers; or to all but finitely many. But it is not true in general for FOL. – Asaf Karagila Feb 27 '13 at 18:32
  • (This, by the way, is the difference between expressibility in logic and expressibility in a theory and expressibility in a structure.) – Asaf Karagila Feb 27 '13 at 18:35
