prove {$\neg(\forall x)\alpha \rightarrow \alpha$}$\vdash\space(\forall x)\alpha$
Im not sure what is the convention, so to be clear I am talking about proving the formula from the seven axiom schemes:
$(A_1) \alpha \rightarrow(\beta \rightarrow \alpha)$
$(A_2) (\alpha \rightarrow(\beta \rightarrow \gamma))\rightarrow((\alpha\rightarrow\beta)\rightarrow(\alpha\rightarrow\gamma)) $
$(A_3) (\neg\beta \rightarrow\neg\alpha)\rightarrow((\neg\beta \rightarrow \alpha)\rightarrow\beta)$
$(A_4) (\forall x)\alpha\rightarrow \alpha(t)$ where $x\in FV(\alpha)$ and $\alpha(t)$ is the subtition of $t$ to all appearances of $x$ in $\alpha$
$(A_5) (\forall x)(\alpha\rightarrow\beta)\rightarrow(\alpha\rightarrow(\forall x)\beta))$ when $x\not\in FV(\alpha)$
$(A_6) (\forall x)x=x$
$(A_7) x=y\rightarrow(\alpha\rightarrow\alpha<y>)$ where $y\in FV(\alpha)$ and $\alpha<y>$ is the subtition of $y$ to some appearances of $x$ in $\alpha$
and the deduction rules (not sure about the accepted term but I hope you will understand) are:
if $\alpha$ appeared in the proof then it is eligible to use $(\forall x)\alpha$
and
if $\alpha\rightarrow\beta$ and $\alpha $appeared in the proof then it is eligible to use $\beta$
sorry if I misused some of the terms and if it's not a burden I'd like to be corrected.
- 1,165
- 8
- 18
Complete the list of axioms, please. – Git Gud Jul 17 '14 at 15:00
The set of axioms for first-order logic is not "so standard" as you presume... Thus, it would be better if you can list them all, or otherwise give us the reference to the math log textbook you are using. Thanks ... – Mauro ALLEGRANZA Jul 17 '14 at 15:00
please rewrite your formula with brackets to remove ambiguity. – Rene Schipperus Jul 17 '14 at 15:17
See Elliott Mendelson, Introduction to mathematical logic (4ed - 1997), page 69.
We need at least a third propositional axiom, like :
(A3) --- $(\lnot γ → \lnot β) → ((\lnot γ → β) → γ)$
to be able to prove all tautologies.
In addition, I assume two axioms for the predicate calculus (and two further axioms for equality : we do not need them here) :
(A4) --- $\forall x \alpha(x) \rightarrow \alpha (t)$, where $t$ is a term free for $x$ in $\alpha(x)$
(A5) --- $(∀x(\alpha → \beta) → (\alpha → ∀x \beta))$, where $x$ is not free in $\alpha$.
We need also inference rules :
modus ponens
generalization : form $\alpha$, $\forall x \alpha$ follows.
Proof
(1) $\lnot \forall x \alpha \rightarrow \alpha$ --- assumed
(2) $\lnot \alpha \rightarrow \forall x \alpha$ --- form (1) using the tautology : $(\lnot \varphi \rightarrow \psi) \rightarrow (\lnot \psi \rightarrow \varphi)$ and modus ponens
(3) $\forall x \alpha \rightarrow \alpha$ --- by axion (A4), with $x$ as $t$
(4) $\lnot \alpha \rightarrow \lnot \forall x \alpha$ --- from (3) as above
(5) $\alpha$ --- from axiom (A3) with (4) and (2), by mp twice
(6) $\forall x \alpha$ --- from (5) by generalization
Thus, form (1) and (6) :
$\lnot \forall x \alpha \rightarrow \alpha \vdash \forall x \alpha$.
Note
In order to conclude from the above formula, by soundness, that :
$\lnot \forall x \alpha \rightarrow \alpha \vDash \forall x \alpha$
we have to check if the fine details regarding the definitions of satisfaction and logical consequence are consistent with those in Mendelson's book.
Comment
To prove the tautology : $(\lnot \varphi \rightarrow \psi) \rightarrow (\lnot \psi \rightarrow \varphi)$ we need some extra-work.
See this post for the "basic tools" according to Mendelson's proof system :
$\vdash \varphi \rightarrow \varphi$, Deduction Theorem, Syllogism and Double Negation laws.
With these theorems available, it is easy to prove the above tautology.
- 94,169
