I would like to perform an inverse laplace and at some point of the calculation I have to compute this integral
$$ \int_{\gamma - \mathrm{i}\infty} ^{\gamma + \mathrm{i}\infty} z^{\left(1 + n\right)\alpha-1}\,\,\,\mathrm{e}^{z} \,\frac{\mathrm{d}z}{2\pi\mathrm{i}} $$
where $\gamma > 0\;, \,0 < \alpha < 1 $and n is a positive integer. I am reading an article that gives $$\frac{1}{\Gamma(1-n\alpha)}$$ as a result, but I can't figure out how to do it. They say just fold the path around the negative real axis. But as z to the power alpha has no laurent expansion in 0, the residue theorem is not applicable. Any idea? thanks
Felix Marin
  • 89,464
antoine
Generally speaking, you use Cauchy's theorem for the following integral:
$$\frac1{i 2 \pi} \oint_C dz \, z^{(1+n) \alpha-1} \, e^z $$
Yes, you provide a keyhole contour $C$ about the negative real axis and evaluate the integral along each piece of the contour and set the contour integral to zero (or, the sum of the residues of the poles if there are any; there are none here).
For a picture of the contour $C$, see this answer. The integral vanishes along the outer circular arcs only for certain values of $n$. To find those values, consider the integral about the arc in the upper half-plane, which upon parametrization by $z=R e^{i \theta}$, where $\theta \in [\pi/2,\pi)$. Thus, the integral there is
$$\frac1{2 \pi} \int_{\pi/2}^{\pi} d\theta \, e^{i \theta} \, R^{(1+n) \alpha} e^{i (1+n) \alpha \theta} e^{R\cos{\theta}} e^{i R \sin{\theta}}$$
We now consider the upper bound of the magnitude of this integral (as it is not really in a good form for exact evaluation). Note that, in general,
$$\left | \int_{\gamma} dz \, f(z) \right | \le \int_{\gamma} |dz|\, |f(z)|$$
Let's apply this principle to the integral over $\theta$, but let's also subtract $\pi/2$ from $\theta$ for later convenience. The magnitude of this integral is now bounded by:
$$\frac1{2 \pi} R^{(1+n)\alpha} \int_0^{\pi/2} d\theta \, e^{-R \sin{\theta}}$$
Convenienetly, we may use the inequality $\sin{\theta} \ge 2 \theta/\pi$ for $\theta \in [0,\pi/2]$. Thus, we get a final upper bound for the magnitude of the integral:
$$\frac1{2 \pi} R^{(1+n)\alpha} \int_0^{\pi/2} d\theta \, e^{-R 2 \theta/\pi} \le \frac14 R^{(1+n)\alpha-1}$$
As $R \to \infty$, we hope that the integral vanishes. For this to happen, $(1+n)\alpha -1 \lt 0$, or $n+1 \lt 1/\alpha$.
The same analysis applies to the integral about the arc in the lower half-plane.
You can also apply a similar analysis to the integral about the inner circle, except now we parametrize as $z=\epsilon e^{i \phi}$, where $\phi \in (-\pi,\pi)$. Taking the limit as $\epsilon \to 0$, we find that the integral vanishes as $\epsilon^{(1+n) \alpha}$.
Thus you are left with three pieces of $C$ along which the integral does not vanish:
$$\frac1{i 2 \pi} \int_{c-i \infty}^{c+i \infty} dz\, z^{(1+n) \alpha -1} \, e^z + \frac{e^{i (1+n) \alpha \pi}}{i 2 \pi} \int_{\infty}^0 dx \, x^{(1+n) \alpha-1} \, e^{-x} \\+ \frac{e^{-i (1+n) \alpha \pi}}{i 2 \pi} \int_0^{\infty} dx \, x^{(1+n) \alpha-1} \, e^{-x}$$
The first integral is the original ILT. The second is just above the real axis, where we parametrize by $z=e^{i \pi} x$. The third is just below, where $z=e^{-i \pi} x$. Note that we are respecting the branch cut along the negative real axis.
Since there are no poles inside $C$, the contour integral is zero by Cauchy's theorem. Thus we have
$$\frac1{i 2 \pi} \int_{c-i \infty}^{c+i \infty} dz\, z^{(1+n) \alpha -1} \, e^z = \frac1{\pi} \sin{\pi (1+n)\alpha} \int_0^{\infty} dx \, x^{(1+n) \alpha-1} \, e^{-x}$$
Use the fact that
$$\int_0^{\infty} dx \, x^{y-1} e^{-x} = \Gamma(y)$$
to get that
$$\frac1{i 2 \pi} \int_{c-i \infty}^{c+i \infty} dz\, z^{(1+n) \alpha -1} \, e^z = \frac1{\pi} \sin{ [\pi (1+n)\alpha}] \, \Gamma((1+n) \alpha)$$
Use the reflection formula
$$\Gamma(y) \Gamma(1-y) = \frac{\pi}{\sin{\pi y}}$$
and I get, finally,
$$\frac1{i 2 \pi} \int_{c-i \infty}^{c+i \infty} dz\, z^{(1+n) \alpha -1} \, e^z = \frac1{\Gamma(1-(n+1) \alpha)}$$
Ron Gordon
  • 138,521
  • yes, but even if the integral along the circle in the left half plane vanishes (which I'm not sure). It remains the integral along the circle centered at $0$, which I can't evaluate – antoine Apr 11 '14 at 13:49
  • @antoine: hopefully the above explains everything sufficiently. – Ron Gordon Apr 11 '14 at 18:14
  • ok thank you very much, I thought that the integrals on C3 and C5 were compensating each other, I realize it is not necessarily the fact if the function has a branching point. – antoine Apr 22 '14 at 08:27
