Prove that
$$\lim_{x\to 0} \frac{\ln(x+1)}{x} = 1$$
without using L'Hôpital Rule.
M. Vinay
  • 9,004
6 Answers6
This is just the derivative of $y=lnx$ at $x=1$ by using the classic definition of the derivative. And so the answer is $1$. In this way, L'Hospital is avoided.
imranfat
  • 10,029
If you define $\log(1+x)$ as the integral of $\frac{1}{1+x}$ and you don't want to use the fundamental theorem of calculus either, you could bound $\frac{1}{1+x}$ between $1-\epsilon$ and $1+\epsilon$ for sufficiently small $x$, and use this to get the required limit.
Mikhail Katz
  • 42,112
  • 66
  • 131
HINT :
If that limit you are asking, then you can use Maclaurin series for $\ln(1+x)$ to prove $\lim\limits_{x\to0} \frac{\ln(1+x)}{x} = 1.$
$$\Large\color{blue}{\text{# }\mathbb{Q.E.D.}\text{ #}}$$
Tunk-Fey
  • 24,849
    I believe if he can use McLaurin series he would not bother with avoiding l'Hôspital Rule and just go straight for an equivalent – T_O Apr 10 '14 at 14:04
  • @T_O I just try to give a hint in case he didn't know. – Tunk-Fey Apr 10 '14 at 14:06
    @Tunk-Fey You beat me to it. – Josh Apr 10 '14 at 14:06
  • @T_O I don't necessarily think he wouldn't know about Taylor series. Some calc books don't mention l'Hospital until doing sequences and series. – Josh Apr 10 '14 at 14:08
    Why on earth are you putting a huge "Q.E.D." after something that is a hint not a proof? – hmakholm left over Monica Apr 10 '14 at 17:04
  • @HenningMakholm Sorry if my Q.E.D. sign is bothering you. I put it behind of every my answer, even if only a hint, just as my signature. It's kind of a personal touch. I hope you don't mind. :) – Tunk-Fey Apr 10 '14 at 17:11
Integrate $\frac{1}{1+y}$ between 0 and x. Look at the picture below to get an upper and lower bound for this integral. Divide through by x and take the limit.
Paul
  • 1,482
This limit is equivalent to $$ \lim_{x \to 0} \frac{e^x-1}{x}=1, $$ which is easily handled with the definition $$ e^x = \sum_{k=0}^\infty \frac{x^k}{k!}. $$ As noticed above, it all boils down to your definition of the exponential or the logarithmic function.
Siminore
  • 35,136
For any $x>0$ We have $$\frac{x}{x+1} =\int_{0}^x\frac{dt}{x+1} \le \int_{0}^x\frac{dt}{t+1} =\color{red}{\ln(x+1 )}=\int_{0}^x\frac{dt}{t+1} \le \int_{0}^x\frac{dt}{1} = x $$
that is for $x>0$
$$\frac{x}{x+1} \le \ln(x+1 ) \le x \implies\color{red}{\frac{1}{x+1}\le \frac{\ln(x+1 )}{x} \le 1}$$ $$\color{red}{1=\lim_{x\to 0}\frac{1}{x+1}\le \lim_{x\to 0}\frac{\ln(x+1 )}{x} \le 1}$$
that $$\color{blue}{ \lim_{x\to 0}\frac{\ln(x+1 )}{x} = 1}$$
By Squeeze Theorem, we have,
Guy Fsone
  • 23,903
