I would like to get alot better at trig than I am. What is the best/most efficient method?
Thanks much in advance
Joe
Joe
I would emphasize how to derive trigonometric identities from a few ones. Learn:
Added. Examples. From
$$\sin (\alpha +\beta )=\sin \alpha \cdot \cos \beta +\cos \alpha \cdot \sin \beta ,\tag{A}$$
if we set $\alpha =\beta =a$, we get
$$\sin 2a=2\sin a\cdot \cos a.\tag{1}$$
And from
$$\cos (\alpha +\beta )=\cos \alpha \cdot \cos \beta -\sin \alpha \cdot \sin \beta \tag{B}$$
for $\alpha =\beta =a$, we have
$$\cos 2a=\cos ^{2}a-\sin ^{2}a.\tag{2}$$
Using the Pythagorean identity
$$\cos ^{2}a+\sin ^{2}a=1,\tag{C}$$
if $\cos a\neq 0$, then $$\begin{eqnarray*} \sin 2a &=&2\sin a\cdot \cos a=2\dfrac{\sin a\cdot \cos a}{\cos ^{2}a+\sin ^{2}a} \\ &=&\dfrac{2\dfrac{\sin a\cdot \cos a}{\cos ^{2}a}}{\dfrac{\cos ^{2}a+\sin ^{2}a }{\cos ^{2}a}}=\dfrac{2\dfrac{\sin a}{\cos a}}{1+\dfrac{\sin ^{2}a}{\cos ^{2}a}} \\ &=&\dfrac{2\tan a}{1+\tan ^{2}a}. \end{eqnarray*}\tag{3}$$
Similarly $$\begin{eqnarray*} \cos 2a &=&\cos ^{2}a-\sin ^{2}a=\dfrac{\cos ^{2}a-\sin ^{2}a}{\cos ^{2}a+\sin ^{2}a} \\ &=&\dfrac{\dfrac{\cos ^{2}a-\sin ^{2}a}{\cos ^{2}a}}{\dfrac{\cos ^{2}a+\sin ^{2}a}{\cos ^{2}a}}=\dfrac{1-\dfrac{\sin ^{2}a}{\cos ^{2}a}}{1+\dfrac{\sin ^{2}a }{\cos ^{2}a}} \\ &=&\dfrac{1-\tan ^{2}a}{1+\tan ^{2}a}. \end{eqnarray*}\tag{4}$$
Then
$$\tan 2a=\dfrac{\sin 2a}{\cos 2a}=\dfrac{\dfrac{2\tan a}{1+\tan ^{2}a}}{\dfrac{ 1-\tan ^{2}a}{1+\tan ^{2}a}}=\dfrac{2\tan a}{1-\tan ^{2}a}.\tag{5}$$
Added 2. The linear equation in $\sin x$ and $\cos x$
$$ A\sin x+B\cos x=C\tag{6} $$ can be solved by a resolvent quadratic equation in $\tan \frac{x}{2}$, by writting the $\sin x$ and the $\cos x$ functions in terms of $\tan \frac{x}{2 }$ (set $x=2a$ in $(3)$ and $(4)$):
$$ \sin x=\dfrac{2\tan \dfrac{x}{2}}{1+\tan ^{2}\dfrac{x}{2}},\tag{7} $$
$$ \cos x=\dfrac{1-\tan ^{2}\dfrac{x}{2}}{1+\tan ^{2}\dfrac{x}{2}}.\tag{9} $$
The equation $(6)$ is equivalent to $$\begin{eqnarray*} A\dfrac{2\tan \dfrac{x}{2}}{1+\tan ^{2}\dfrac{x}{2}}+B\frac{1-\tan ^{2}\dfrac{x}{ 2}}{1+\tan ^{2}\dfrac{x}{2}} &=&C, \\ 2A\tan \dfrac{x}{2}+B-B\tan ^{2}\dfrac{x}{2} &=&C+C\tan ^{2}\dfrac{x}{2}, \\ \left( B+C\right) \tan ^{2}\dfrac{x}{2}-2A\tan \dfrac{x}{2}+C-B &=&0. \end{eqnarray*}\tag{10}$$
Some arrays of trigonometric identities have rhythmic patterns that can help you remember them: $$ \begin{align} \sin(x+y) & = \sin x\cos y + \cos x\sin y \\ \sin(x-y) & = \sin x\cos y - \cos x\sin y \\ \cos(x+y) & = \cos x\cos y - \sin x\sin y \\ \cos(x-y) & = \cos x\cos y + \sin x\sin y \end{align} $$
But you should not simply learn these four identities SEPARATELY. If you know the first identity, you immediately get the second one from it by knowing that the sine function is odd and the cosine is even, and in the same way you get the fourth from the third. And you can get the sine identities from the cosine identities and vice-versa by recalling that $\sin x = \cos(\pi/2 - x)$ and $\cos x = \sin(\pi/2-x)$. If you don't know how to do things like these, you're missing something you should learn.
If you know how to find $\sin(x+y)$ as a function of the sines and cosines of $x$ and $y$, that immediately tells you the double-angle formula $\sin(2x)=2\sin x\cos x$, so you should not just SEPARATELY memorize that. Again, if you don't know that, then learn it. Similarly for the other double-angle formulas.
If you know the four identities above, that tells you how to show that $$ \tan(x+y) = \frac{\tan x + \tan y}{1-\tan x\tan y} $$ by first recalling that $\tan = \sin/\cos$ and then dividing the numerator and denominator both by $\cos x\cos y$. So again, don't merely SEPARATELY learn the identity above; learn how it emerges from the others.
And this applies to trigonometric identities generally.
Learn how $\sin^2 x + \cos^2 x = 1$ emerges from the Pythagorean theorem. Draw a triangle whose hypotenuse length is $1$. Then the opposite side is $\sin x$ and the adjacent side is $\cos x$. Similarly if you draw a triangle whose adjacent side has length $1$, then the opposite side is $\tan x$ and the hypotenuse is $\sec x$, so we get another Pythagorean identity: $1+\tan^2 x = \sec^2 x$.
Another useful thing to do if you can, is to tutor those who are first learning the subject who are not as adept as you are. After taking a dozen-or-so such students through the whole course, you'll find some things much more firmly fixed in place in your mind.
$$e^{i \theta}=\cos(\theta)+i\sin(\theta)$$
and that
$$e^{i(\theta + \phi)}=e^{i \theta}e^{i \phi}.$$
All trig identities may be derived from this. Thank Euler!
– Giuseppe Negro Sep 19 '11 at 00:36The complex-valued function $h(\theta)=\cos(\theta)+i \sin (\theta)$ is uniquely determined by the following three properties:
This means that any other property of $\cos$ and $\sin$, including all trigonometric formulas, can be derived from the above.
Those properties are especially easy to remember if you write $e^{i \theta}=\cos(\theta)+i\sin(\theta)$ (this great idea is due to Euler), and this notation provides also a convenient algebraic way of deriving trig identities.
Example. We want to expand $\cos^2(\theta)$. Write $\left( e^{i\theta}\right)^2= e^{i 2 \theta}$. The left hand side is
$$(\cos \theta + i \sin \theta)(\cos \theta + i \sin \theta)=\cos^2\theta-\sin^2\theta+i(2\sin\theta \cos \theta),$$
while the right hand side is
$$\cos 2\theta + i \sin 2 \theta.$$
Equating real parts we get
$$\cos^2\theta=\sin^2\theta+\cos 2\theta,$$
and since $\lvert e^{i \theta}\rvert^2=1$, that is $\cos^2\theta+\sin^2\theta=1$, we conclude
$$\cos^2\theta=\frac{1+\cos 2 \theta}{2}.$$
And if you are into calculus, use the addition (or subtraction) formulae to get the derivatives of sin, cos, and tan. See what additional fact is needed to get the derivatives.
And if you are metaphysical, ponder why the addition formula for tan involves only tan, while the addition formulae for sin and cos involve both sin and cos.
