Let $x$ and $y$ be positive integers. Is it possible that $(x+2)(x+1)x=3(y+2)(y+1)y$?
I ran a program for $1\le{x,y}\le1\text{ }000\text{ }000$ and found no solution, so I believe there are none.
The equation $x(x+1)(x+2) = 3y(y+1)(y+2)$ is equivalent to $\left(\frac{24}{3y-x+2}\right)^2 = \left(\frac{3y-9x-6}{3y-x+2}\right)^3-27\left(\frac{3y-9x-6}{3y-x+2}\right)+90$.
This is an elliptic curve of conductor $3888$. Cremona's table says its group of rational points is of rank $2$, and is generated by the obvious solutions $(x,y) \in \{-2;-1;0\}^2$
I am not sure how one would go about proving an upper bound for the integral solutions of the original equation. There are papers on the subject (for example, Stroeker and de Weger's "Solving elliptic diophantine equations: The general cubic case." seems to be applicable here)
Also, see How to compute rational or integer points on elliptic curves
It seems unlikely. The search you have done seems to get us out of the law of small numbers. Somebody's law says that when the reciprocal powers in an equation like this sum to less than $1$ you should expect finitely many solutions. Here it is $\frac 23$. The equation can be written $(x+1)((x+1)^2-1)=3(y+1)((y+1)^2-1)$ so you need $\frac {x+1}{y+1}$ to be very close to $\sqrt[3]3$ You could use the continued fraction to find convergents
Completing mercio's answer: There are no other integer solutions.
Mercio's portion:
Let $(x,y)$ be an integer solution to $x(x+1)(x+2)=3y(y+1)(y+2)$.
We can rewrite it as
$$\left(\dfrac{24}{3y-x+2}\right)^2=\left(\dfrac{3y-9x-6}{3y-x+2}\right)^3-27\left(\dfrac{3y-9x-6}{3y-x+2}\right)+90$$
or simply
$$E:Y^2=X^3-27X+90.$$
$E$ is an Elliptic curve since $\Delta=-139968\neq 0$.
Since $x,y$ are integers, they give rise to a rational solution in $E(\mathbb Q)$, via
$$(x,y)\mapsto \left(\dfrac{3y-9x-6}{3y-x+2},\dfrac{24}{3y-x+2}\right)=(X,Y).$$
However this only makes sense if $3y-x+2\neq 0$. Suppose otherwise, $x=3y+2$, then
$$24^2(3y-x+2)=(3y-9x-6)^3-27(3y-9x-6)(3y-x+2)^2+90(3y-x+2)^3$$
$$0=3y-9x-6\Leftrightarrow 0=y-3x-2$$
Together with $x=3y+2$, we have
$$ y-9y-6-2=0\implies y=-1$$
So it fails when $(x,y) = (-1,-1)$.
Ignoring this, then each $(x,y)$ integral solution must give rise to a rational point $(X,Y)$ in $E$.
We can use the following commands in Sage:
E = EllipticCurve([0,0,0,-27,90]);
E.rank()
E.gens()
Which will tell us that $E(\mathbb Q)$ is torsion free and of rank 2 and generated by $(-5, 10), (-3, 12)$.
Therefore all the rational points on $E$ can be written as:
$$P\in E(\mathbb Q)\Longleftrightarrow P = [a](-5,10)\oplus [b](-3,12)$$
for some $a,b\in\Bbb Z$.
Solving for $(x,y)$ using $E(\mathbb Q)$:
If any $P\in E(\mathbb Q)$ can be mapped from an integral solution $(x,y)$, then we have relations
$$\dfrac{3y-9x-6}{3y-x+2}=X,\dfrac{24}{3y-x+2}=Y,$$
and we can check validity by solving the simultaneous equations.
Note that for $Y$, the numerator will always be small since $x$ and $y$ are integers.
Therefore all we have to do is to generate all $(a,b)\in \mathbb Z^2$, then form $P=(X,Y)$ and check if it satisfies the simultaneous equations.
The problem is $\{(a,b)\}$ is an infinite set.
However, a (Height) property of Elliptic curve tells us that:
(1) As we add more points, we expect $X$ and $Y$ to be not integers.
(2) Since they are not torsion points, we also expect numerator/denominator to grow exponentially.
(3) Numerator and denominator will have approximately same number of digits as they grow.
Combining all (3), this says that gradually the numerator of $Y$ must increase.
Edit2: Not quite enough. This is true for almost all points but we need to show that we did not miss any. Temporary solution in comments, will add proper solution after checking my workings.
End_Edit_2
As an example, let $P=(-5,10)$ and consider $\varphi(P)=\{P,[2]P,\dots\}$.
We will get:
$$\left\{(-5,10),\left(\dfrac{394}{25}, \dfrac{-7478}{125} \right), \left(\dfrac{148795}{269361},\dfrac{1212735770}{139798359} \right), \left(\dfrac{25189696321}{5592048400},\dfrac{-3233187530793631}{418173379352000}\right),\left(\dfrac{41697179388698395}{10487471993072881}, \dfrac{7244632674771290918438950}{1074004796869053110612279}\right),\dots\right\}$$
We then observe that for our solution in $(x,y)$, we require $Y=24/(3y-x+2)$.
In particular, this says that the numerator must be rather small.
Therefore it suffices to check for $P=[a](-5,10)\oplus [b](-3,12)$ for small values of $(a,b)$.
(For example, say $-5\leq a,b\leq 5$.)
We will then find that the only solutions are the trivial negative ones.
