Determine whether the following permutation is even or odd and write it as a product of transpositions in two different ways.
$(1527)(3567)(273)$
So far, I have the following: $(1527)(3567)(273) = (15)(12)(17)(35)(36)(37)(27)(23) = (57)(51)(56)(53)$
I can understand the part which states that $(1527)(3567)(273) = (15)(12)(17)(35)(36)(37)(27)(23)$, but I can't understand why that might be equal to $(57)(51)(56)(53)$.
Can someone explain why it is so?
Mikasa
  • 67,374
  • If I understand you well then $(1527)$=$(15)(12)(17)$. What makes you think that? – drhab Nov 30 '13 at 13:43
  • My first comment arose because I was "going to the left". You are "goint to the right" as I understand now. – drhab Nov 30 '13 at 14:11
It looks like you're using the fact that $(a_1a_2\ldots a_n)=(a_1a_2)(a_1a_3)\ldots (a_1a_n)$. This leads to the first equality immediately by using the above on each component of the permutation.
To get the second, we first multiply each component out to write the permutation as a cycle $(16357)$ which is equal by cyclically permuting the elements to $(57163)$. We may now use the above decomposition rule again to get that it is equal to $(57)(51)(56)(53)$.
As a tip, there is also another way to decompose a chain into transpositions using the fact that $(a_1a_2\ldots a_{n-1}a_{n})=(a_{n}a_{n-1})(a_{n-1}a_{n-2})\ldots (a_3a_2)(a_2a_1)$ which in the above example would give you $(16357)=(75)(53)(36)(61)$.
Dan Rust
  • 30,108
  • If you hadn't written the additional "algorithm" (last paragraph), I would have! ;-) +1 – amWhy Nov 30 '13 at 14:41
  • @amWhy thinking about it, the identity offers one advantage to using the right-to-left multiplication convention. It's much easier to remember $(16357)=(16)(63)(35)(57)$ than the above because it reads in the same direction. – Dan Rust Nov 30 '13 at 14:47
  • I agree! That's my favorite transposition identity for the right-to-left convention. I find it awkward to go left to right, sort of like trying to switch directions when reading: having learned to read from left to right, it takes great effort to try to read a sentence from right to left! – amWhy Nov 30 '13 at 14:52
I can understand the part which states that $$(1527)(3567)(273) = (15)(12)(17)(35)(36)(37)(27)(23)$$ but I can't understand why that might be equal to $(57)(51)(56)(53)$.
To see why they are equal, you might find it helpful to first write your permutation as a product of disjoint cycles.
So, for example, assuming you are composing products of permutation from left to right, then note that $\varphi = (1527)(3567)(273)$ is not a product of disjoint cycles: we see that $7$ appears in all three of the factors, $2$, $3$ and $5$ each appear twice, etc.
So, composing from left to right gives us $$\varphi = (1527)(3567)(273) = (16357)(2) = (16357) = (63571) = (35716) = (57163) \ldots$$ Then writing the last as the product of transpositions gives us $$(57163) = (57)(51)(56)(63)$$
But recall, the decomposition of permutations into the product of transpositions is NOT unique: What is guaranteed is that for a given permutation, it can always and only be decomposed into the product of an even number of transpositions (hence is an even permutation), or an odd number of transpositions (in this case we call it an odd permutation.)
For your posted permutation, note that:
$$(1527)(3567)(273) = \underbrace{(15)(12)(17)(35)(36)(37)(27)(23)}_{\large 8\;\text{ transpositions: even}} = \underbrace{(57)(51)(56)(53)}_{\large 4\;\text{transpositions: even}}$$
Hence, your permutation is an even permutation.
amWhy
  • 209,954
To answer the first question it is not really necessary to write the permutation as a product of $2$-cycles. $4$-cycles are odd and $3$-cycles are even. More generally $2n$-cycles are odd and $2n+1$-cycles are even. You have odd-odd-even here. This results in an even permutation (the composition of two odds is even, the composition of two evens is even, the composition of odd and even is odd).
drhab
  • 151,093
Since you write $(1527)=(15)(12)(17)$, I assume that you compose permutations “going to the right”. Thus $$ \sigma=(1527)(3567)(273)=(16357) $$ Thus $\sigma=(16)(13)(15)(17)$; but you can also write $\sigma=(63571)$ or $\sigma=(57163)$, can't you?
amWhy
  • 209,954
egreg
  • 238,574
