16
Can anyone provide a simple concrete example of a non-arithmetic commutative and unitary ring (i.e., a commutative and unitary ring in which the lattice of ideals is non-distributive)?
Bill Dubuque
  • 272,048
Hint $ $ Distributivity easily yields that a finitely generated ideal is $\,1\,$ if it contains a cancellable element $\rm\,u\,$ that is $\rm\,lcm$-coprime to the generators. For example, for a $2$-generated ideal $\rm\,(x,y)$
Lemma $\,\ $ If $\rm\ x,\,y\,$ and cancellable $\rm\,u\,$ are elements of an arithmetical ring then $$\rm\ \begin{array}{}\rm (u)\cap(x)\ =\ (u\,x)\\ \rm (u)\cap(y)\ =\ (u\,y)\end{array}\ \ \ and\ \ \ (u) \subseteq (x,y)\ \ \Rightarrow\ \ (x,y) = 1$$
Proof $\rm\ \ (u) = (u)\cap(x,y) = (u)\cap(x) + (u)\cap(y) = u\ (x,y)\,$ so $\rm\,(x,y)=1\,$ by cancelling $\rm\,u$
Remark $ $ Thus to prove that a domain is not arithmetical it suffices to exhibit elements that violate the Lemma. That is easy, e.g. put $\rm\ u = x+y\ $ for $\rm\ x,y \in \mathbb Q[x,y]\,,\, $ or $\rm\ x,\,y=2\in \mathbb Z[x]\,.$
Arithmetical domains are much better known as Prüfer domains. They are non-Noetherian generalizations of Dedekind domains. Their ubiquity stems from a remarkable confluence of interesting characterizations. For example, they are those domains satisfying: $\rm CRT$ (Chinese Remainder Theorem) for ideals, or Gauss's Lemma for polynomial content ideals, or for ideals: $\rm\ A\cap (B + C) = A\cap B + A\cap C\,,\ $ or the $\rm\, GCD\cdot LCM\,$ law: $\rm\, (A + B)\ (A \cap B) = A\ B\,,\ $ or $\,$ "contains $\rm\Rightarrow$ divides" $\rm\ A\supset B\ \Rightarrow\ A\,|\,B\ $ for finitely generated $\rm\,A\,$ etc. It's been estimated that there are over $100$ known characterizations, e.g. see my prior answer for close to $30$ interesting such.
Bill Dubuque
  • 272,048
In the ring $K[X,Y]$, where $K$ is a field and $X$ and $Y$ are indeterminates, we have
$$(X+Y)\cap\Big((X)+(Y)\Big)\not\subset\Big((X+Y)\cap (X)\Big)+\Big((X+Y)\cap (Y)\Big).$$
[Thank you to Bill Dubuque for having pointed out a catastrophic typo!]
A commutative integral domain is "arithmetic" in the sense that you specify iff it is a Prüfer domain, i.e., iff every nonzero finitely generated ideal is invertible. This class of domains is famously robust: there is an incredibly long list of equivalent characterizations: see e.g. the beginning of this paper for some characterizations. For a proof that a domain is arithmetic iff its finitely generated ideals are invertible, see e.g. Theorem 6.6 of Larsen and McCarthy's text Multiplicative Theory of Ideals.
Note in particular that a Noetherian domain is Prüfer iff it is Dedekind, i.e., iff it is integrally closed and of Krull dimension at most one. Therefore examples of rings with non-distributive lattice of ideals abound, e.g.:
For any field $k$, $k[t_1,\ldots,t_n]$, $n \geq 2$. (The dimension is greater than one.)
For any nonfield Noetherian domain $k$, $k[t_1,\ldots,t_n]$, $n \geq 1$. (The dimension is greater than one.)
$\mathbb{Z}[\sqrt{-3}]$, $k[t^2,t^3]$ for any field $k$. (The rings are not integrally closed.)
And so forth...
Pete L. Clark
  • 97,892
  • @Pet That's not an answer to the question unless you first prove that one of those equivalent characterizations is implied by distributivity. But that is a nontrivial task in many cases. So I think this answer is far from providing a simple example, as requested by the OP. – Bill Dubuque Aug 18 '11 at 18:09
    @Bill: The paper linked to in my answer cites references where the equivalences are proved. If you (or the OP, or anyone else) do not have access to any of these references but are still interested in the proof, probably someone here could help you out. (Sorry for not wanting to argue about whether something is "simple": surely it's best for you to leave your own answer, as you have.) – Pete L. Clark Aug 18 '11 at 19:06
  • @Pet I do have a copy of said paper somewhere since I linked to it here and elsewhere long ago (probably that's where you learned the reference). But, if memory serves correct, none of those characterizations yield a simple answer to the OP's query since the proofs go through nontrivial paths. Did you have some specific simple proof in mind? Lacking such, I don't think you've answered the question. – Bill Dubuque Aug 18 '11 at 19:14
    @Bill: Actually I said that I do not want to argue about whether my answer is "simple" (or whether the word "simple" in the OP's answer is meant to apply to the ring itself or to the proof that it is not arithmetic, etc.). Again, I apologize. If none of the answers given so far are satisfactory to the OP, he will surely tell us so. – Pete L. Clark Aug 18 '11 at 19:22
  • @Pet Ok, drop the word "simple". Which specific proof do you have in mind? Do you often make claims without proof? Do you have any familiarity with the difficulty of these results? – Bill Dubuque Aug 18 '11 at 19:25
  • @Pet Your newly added reference to Larsen and McCarthy (the source cited in said paper of Bazzoni and Glaz) yields a rather roundabout way to an example, going through a handful of equivalent characterizations of Prufer domains to finally deduce that distributivity implies that finitely generated ideals are invertible. That's an order of magnitude more work than need be. But at least it is (finally!) specific. – Bill Dubuque Aug 18 '11 at 21:12
  • Thanks for your answer and for the link. I'll go with Bill's answer since it gives a simple mechanism to find non-arithmetic rings. – Gonzalo Medina Aug 19 '11 at 01:04
    @Gonzalo If you continue your study of these rings I highly recommend that you do study the many diverse characterizations. They are both important and fascinating (that's why I typed $27$ of them into my answer last Decemeber!) But they are a bit overkill for the simple question that you posed. Note: not all of the $27$ I mentioned are in the Bazzoni and Glaz paper that I cite in the comments there. There are also many other interesting characterizations in the literature. Perhaps more than for any other algebraic structure. – Bill Dubuque Aug 19 '11 at 01:20
