I am asking to what extent this problem is true:
Uncountable product of separable spaces is separable.
I need these statements to be explained if possible:
  1. How to construct a countable subset of uncountable product of separable spaces.
  2. Counterexample for the contradicted case.
A product $X=\prod_{\alpha\in A}X_\alpha$ of non-trivial separable spaces is separable if and only if $|A|\le 2^\omega=\mathfrak{c}$. (By non-trivial I mean that a space does not have the indiscrete topology; for $T_1$ spaces this simply means that it has at least two points.) This is the countable case of the Hewitt-Marczewski-Pondiczery theorem. Hewitt’s original paper can be found here. This result itself is Theorem $16.4$c in Willard’s General Topology; it is also proved here at Ask a Topologist by Henno Brandsma.
Added: Here’s a sketch of the construction of a countable dense subset of $X$ when $|A|\le 2^\omega$. Without loss of generality assume that $|A|=2^\omega$, and identify $A$ with $\Bbb R$. For $\alpha\in\Bbb R$ let $D_\alpha=\{y_\alpha(k):k\in\Bbb N\}$ be a countable dense subset of $X_\alpha$. Let $F=\{q_1,\ldots,q_n\}$ be any finite set of rational numbers with $q_1<\ldots<q_n$, and let $\sigma=\langle m_0,\ldots,m_n\rangle\in\Bbb N^{n+1}$ be any $(n+1)$-tuple of natural numbers. Define a point $x^{F,\sigma}=\langle x_\alpha^{F,\sigma}:\alpha\in\Bbb R\rangle\in X$ as follows:
$$x_\alpha^{F,\sigma}=\begin{cases} y_\alpha(m_0),&\text{if }\alpha<q_1\\ y_\alpha(m_k),&\text{if }q_k\le\alpha<q_{k+1}\text{ for some }k\in\{1,\ldots,n-1\}\\ y_\alpha(m_n),&\text{if }q_n\le\alpha\;. \end{cases}$$
Then
$$D=\left\{x^{F,\sigma}:F\subseteq\Bbb Q\text{ is finite and }\sigma\in\Bbb N^{|F|+1}\right\}$$
is a countable dense subset of $X$.
Brian M. Scott
  • 616,228
  • could you please construct a countable subset of continuum product of separable space like what you did here:
    http://math.stackexchange.com/questions/244427/proving-separability-of-the-countable-product-of-separable-spaces-using-density
    – Zirko Tammado Oct 15 '13 at 00:08
  • @Zirko: It’s a bit messy, so I was hoping that the link to the proof in Willard would be good enough. Give me a little while, and I’ll at least sketch the construction. – Brian M. Scott Oct 15 '13 at 00:16
  • I will read these steps and in Willard as well, thanks for your time. – Zirko Tammado Oct 15 '13 at 00:44
  • @Zirko: You’re welcome. If you have any questions, feel free to leave a comment here. – Brian M. Scott Oct 15 '13 at 00:45
  • "Non-trivial" is stronger than that. Every product of indiscrete spaces is trivially separable (every non-empty subset is dense). – dfeuer Oct 15 '13 at 01:40
  • @dfeuer: Habit: my default is that all spaces are $T_1$. – Brian M. Scott Oct 15 '13 at 01:44
