I'm currently trying to implement an algorithm to $3$-colour the edges of cubic graphs. (I want to do this with Matlab's Symbolic toolbox). After restricting to planar graphs to ensure the existence of a solution, I tried the following:
First, I observed that once a colouring is found the adjacency matrix $A$ split into three matrices with the following properties:
  • $\hskip-5.0in A_1+A_2+A_3=A \tag{1}$
  • $\hskip-5.0in A_k^2=1, \tag{2} $
where $1$ is the unit matrix and the idea is related to the concept of $1$-factors I think...
So I tried the following:
  1. I set up matrices $X=(x_{kl})\odot A$, where $\odot$ is the Hadamard product ($Y$ and $Z$ accordingly),
  2. plugged them into $(1)$ and $(2)$,
  3. let the computer solve the set of equations
  4. received some promising results for small dimensions (less than $10$)
  5. and some frustating for larger ones (more than $20$).
I tried to use facts like, all entries in $A_k$ are either $0$ or $1$, so squares of certain variables in $(2)$ could be written as linear terms as well.
So my question is:
Is there a principle problem with this approach? Which other mathematical tricks can I use?
draks ...
  • 18,449
    Have you read about snarks? These are precisely the cubic graphs that are not 3-edge-colorable and hence your problem is in a way equivalent to recognizing snarks. See https://en.wikipedia.org/wiki/Snark_%28graph_theory%29 – Jernej Oct 09 '13 at 10:29
    @Jernej I have, and therefore I tried examples where I knew a $3$-edge-colouring in advance, i.e. planar cubic graphs...In other words: No snarks, please... – draks ... Oct 10 '13 at 20:06
    You might want to have a look at http://cstheory.stackexchange.com/questions/2578/complexity-of-edge-coloring-in-planar-graphs , which appears to cover precisely this question. – Steven Stadnicki Nov 20 '13 at 21:14
  • @StevenStadnicki great link, thanks... – draks ... Nov 20 '13 at 21:16
