let $K$ be a field an $A$ a commutative $K$-algebra with unit. fix an element $f(X) \in A[X]$, unequal elements $a$ and $b$ of $K \subset A$, and an integer $t > 0$.
Question. if $(X - a)^t \mid f(X)$ and $(X - b)^t \mid f(X)$, then does $(X - a)^t \cdot (X - b)^t \mid f(X)$ in $A[X]$?
this is "trivial" when $A \mathbin{/} K$ is itself a field, essentially by unique factorization in $A[X]$: $X - a$ and $X - b$ are unequal irreducibles in this ring.
i can prove this in general in the case $t = 1$: in this case the hypothesis implies that $f(a) = f(b) = 0$. by the Euclidean algorithm, $f(X) = (X - a) \cdot q(X) + r(X)$, where $\deg(R) < 1$, and in fact $r = 0$ must hold. now $0 = f(b) = (b - a) \cdot q(b)$, so that $q(X)$ also vanishes at $b$ (here we use the fact that $b - a \in K \subset A$ is a unit), and so $q(X) = (X - b) \cdot q'(X)$ by the same logic. we see that $f(X) = (X - a) \cdot (X - b) \cdot q'(X)$, as desired.
what about $t > 1$?
