The region $D$ is formed by the area under a curve of length $\ln(1+\sqrt{2})$ that connected points $(\ln(1+\sqrt{2}), \sqrt{2})$ and $(\sqrt{2}, 2)$. What is the maximum volume of the solid of revolution obtained by rotating the region $D$ around the $x$-axis?
$$ \begin{align*} & I(f)=\int\limits_{\ln(1+\sqrt{2})}^{\sqrt{2}}\pi f^2\ dx+\lambda\left(\ \int\limits_{\ln(1+\sqrt{2})}^{\sqrt{2}}\sqrt{1+f'^2}\ dx-\ln(1+\sqrt{2})\right)\\\\ & (1+f'^2)(f^2-c^2)=\lambda^2\\\\ & ds=\frac{c_2}{c_1-f^2}\ dx\\ \end{align*} $$ I'm stuck on solving this differential equation. I'm not sure if it can be solved with parametric equations or some "trick".
