Given a gradient dynamical system $$\frac{d\theta_i}{dt}=f_i(\theta_1,\cdots,\theta_n),\forall i\in\{1,\cdots,n\},$$ where $$\frac{\partial G}{\partial \theta_i}=f_i(\theta_1,\cdots,\theta_n),$$
where $G$ is the energy function.
Assume now that there exists a globally asymptotic stable equilibrium point. Does the Hessian matrix of the $G$ have to be positive semidefinite ($G$ is convex function)?
Remark
I basically curious that:
On the one hand, if we know there exists a globally asymptotic stable equilibrium point, whether we would have some properties on $G$.
On the other hand, what conditions on $G$ could deduce the globally asymptotic stability of an equilibrium point.
M.K
  • 541
  • Your question is unclear. You are talking about the Hessian of $G$, correct? – KBS May 10 '22 at 19:26
  • @KBS Yes, the Hessian of G. – M.K May 10 '22 at 20:37
  • Is $G$ convex an assumption or something that needs to be proven? It is not clear. – KBS May 10 '22 at 20:43
  • @KBS It is something I am not sure whether it is correct. I basically curious that if we know there exists a globally asymptotic stable equilibrium point, whether we would have some properties on $G$. – M.K May 10 '22 at 21:14
Let $U$ being an open set in $\mathbb{R}^n$ and $G:U\to \mathbb{R}$ a two times continuously differentiable function.
If $x(t)$ is a solution to the differential equation $$\begin{cases} \displaystyle \frac{dx}{dt}&=&\nabla G(x)\\x(0)&=&x_0\end{cases}\tag{1}$$ then $$\frac{dG(x(t))}{dt}=\nabla G(x(t))\cdot \nabla G(x(t))=\|\nabla G(x(t))\|^2\geq 0,\tag{2}$$ $x(t)$ follows the steepest ascent direction, and $G(x(t))$ is non decreasing.
If we assume that there exists a globally asymptotic stable equilibrium point $x^*$ to $(1)$. Then $x(t)\to x^*$, to any $x_0$, as $t\to +\infty$, and $$\max_xG(x)=G(x^*).\tag{3}$$
This, in particular, means that Hessian matrix $HG(x^*)$ has no positive eigenvalues. As so, it is not positive semidefinite.
You can find some related discussions searching for "\(\dot{x}=\nabla G(x)\)" on SearchOnMath, for instance.
Note:
  1. What happens if you choose $G(x)=e^{-\|x\|^2}$?.
  2. Now, if we assume that there is a unique global maximum $x^*$ for $(3)$. Then this point is an equilibrium point for $(1)$, and $x(t)\to x^*$, as $t\to +\infty$, for any $x_0$ close enough to $x^ *$ . If there is some $x_0\in U$ and some $r>0$, such that $\|x(t)-x^*\|\geq r$, as $t\to +\infty$, then $( 2)-(3)$ implies that $G(x(t))\to M$, for some $M<G(x^*)$. Therefore, if $x(t)$ is bounded, then $M$ is a local maximum, and $x(t)$ approximates some non-empty set $Y^*\subset{R}^n$ containing equilibrium points of $(1)$.
  3. Therefore, if we assume that there is a unique global maximum $x^*$ for $(3)$ and there is no other local maximum, then any bounded solution $x(t)$ to $(1)$, is such that $x(t)\to x^*$, as $t\to +\infty$, when $x_0$ is not a local minimum or saddle point.
  • Thanks a lot for your answer! I am bit confused about the statement, why is that: If we assume that there exists a globally asymptotic stable equilibrium point $x^*$ to (1). Then ()→∗, to any 0 as →∞, and $max_x(x)=(x^∗)$ – M.K May 11 '22 at 19:20
  • Since I think if $G(x)$ is concave, then we have $x^*$ is globally asymptotically stable. But inverse, I don't think it must hold. – M.K May 11 '22 at 19:22
  • Do you agreed that $x(t)$ follows the steepest ascent direction? If so, $x(t)$ goes to the maximum direction. The globally asymptotic stable equilibrium point definition tell us that no matter where $x_0$ is, $x(t)\to x^*$. – José C Ferreira May 11 '22 at 19:29
  • I misunderstood. what I was trying to say it that to guarantee $x^*$ is globally asymptotically stable, it is not necessary for $G(x)$ to be globally convex function. – M.K May 11 '22 at 20:36
  • I agree that if $x^$ is globally asymptotic stable (GAS), then $x$ is the global maximum of $G(x)$. Inversely, if $G(x)$ is global maximum on $x^$, we cannot conclude that $x^$ is GAS, right? Then, what additional condition is needed to conclude it? My attempt is that, we need $G(x)$ is globally convex. Thanks! P.s. thanks for the link of search on math, I don't know there exists such useful tool before. – M.K May 11 '22 at 20:39
  • @HJ_dynamics I include some notes. – José C Ferreira May 19 '22 at 11:46
