Hi I ask for a proof about the inequality :
Let $a,x>0$ . Does one have the following inequalities
Let $a,x>1$ or $a\geq 1\geq x$ or $a\leq 1\leq x$ or $0.1\leq a\leq 1$ and $0<x\leq 1$ :
$$\sqrt{\frac{a^x}{x}} - \frac{a-1}{a+1} + \frac{x-1}{x+1}-1\geq 0 \,?$$
I can show it for $a,x> 1$ using Bernoulli's inequality .Wwe need to show :
$$\frac{1+\left(a-1\right)x^{2}}{x}-\frac{a^{2}-1}{a^{2}+1}+\frac{x^{2}-1}{x^{2}+1}-1\geq 0$$
This last inequality is not hard .
Using RiverLi's answer here (show this inequality $\sqrt{\frac{a^b}{b}}+\sqrt{\frac{b^a}{a}}\ge 2$) we need to show in the case $a\geq 1\geq x$ :
$$\frac{1}{x}\frac{1+a+(a-1)x^{2}}{1+a-(a-1)x^{2}}-\frac{\left(a^{2}-1\right)}{a^{2}+1}+\frac{\left(x^{2}-1\right)}{x^{2}+1}-1\geq 0$$
This last inequality is again not hard
Another case with $x\leq a\leq 1$ and $a\geq 0.1$ :
Using the well-know inequality $e^x\geq x+1$ on $(-\infty,\infty)$ it seems we have :
$$\frac{1+\ln a^{x^{2}}}{x}-\frac{\left(a^{2}-1\right)}{a^{2}+1}+\frac{\left(x^{2}-1\right)}{x^{2}+1}-1\geq 0$$
I go a little bit further using Bernoulli's inequality (with a trick ) we have for $1\geq x\geq a \geq 0.2$ :
$$\frac{a}{x}\cdot\frac{1}{\left(1-\left(a-1\right)\left(x^{2}-1\right)\right)}-\frac{\left(a^{2}-1\right)}{\left(a^{2}+1\right)}+\frac{\left(x^{2}-1\right)}{x^{2}+1}-1\geq 0$$
This inequality is smooth .
Last edit :
It seems we have for $2\geq x\geq 1$ and $1\geq a$ :
How to show the rest or find a counter-example ?
Thanks !
I post a curious fact about RiverLi's lemma :
Using the fact that with Bernoulli's we have :
$$a^{0.5x^{2}}\ge a^{0.5}\cdot\frac{1}{\left(1-0.5\left(a-1\right)\left(x^{2}-1\right)\right)}$$
And again with Bernoulli's :
$$a^{0.5x^{2}}\ge\frac{\left(1+0.5\left(a-1\right)\left(x^{2}+1\right)\right)}{a^{0.5}}$$
Remarking that $x^2=0.5x^2+0.5x^2$ so multiplying these two inequalities we get the desired result on a certain interval by example $a=6$ and $x\in [2,\infty)$
Alternative sketch of proof for $0<x\leq 1\leq a$
Using derivative we have the inequality :
$$\left(1+\left(a\cdot\frac{1}{1-\left(a-1\right)\left(x-1\right)}-1\right)x\right)\leq a^{x^2}$$
Then we need to show :
$$\frac{\left(1+\left(a\cdot\frac{1}{1-\left(a-1\right)\left(x-1\right)}-1\right)x\right)}{x}-\frac{\left(a^{2}-1\right)}{\left(a^{2}+1\right)}-1+\frac{\left(x^{2}-1\right)}{x^{2}+1}\geq 0$$
Wich is not really hard .
