If we define the set of all sets to be $A$,
Then why can't I say that the set $R=\{G \in A | G \notin G\}$ is not well defined?
If it was well defined then $R\in A$ and the condition $G\notin G$ must be well defined if we substitute $G=R$
but it isn't well defined because "Russell's paradox"
so you can change the condition to be $ \begin{equation} \begin{cases} true\ \ \ \ \ \ \ \ G=R\\ G\notin G\ \ \ \ G\neq R \end{cases} \end{equation} $ and then it will be well defined
Where is my misunderstanding?
btw, the same idea can be included if you try to disproof the existing of the sets of all sets with Cantor's theorem. If you use the Wikipedia's proof then we can choose $f=Id$ then B is exactly $\{G \in A | G \notin G\}$ and its not well defined as i said before.
Edit:
Lot of peoples referencing this question but this question is about "why we care about Russell's paradox", but my question is about "Russell's paradox is not a paradox"
I got the answer to the question: Russell's paradox apply on the standard way we define sets-a condition that all element must met to be part of the set. but I thought about sets in more specific way-an infinite/finite nesting of sets.
for example, the set $\{X|X\in X\land\emptyset\in X\land|X|=2\}$ is like {{},{{},{...}}}
This answer shows a good explanation.
