Let $R$ be a commutative ring with $1_R$ and let $$ S = \biggl\{ \begin{pmatrix} a & b \\ 0 & c \end{pmatrix} \;\Biggm| \; a,b,c \in R \;\biggr\}. $$
If $s = \begin{pmatrix} a & b \\ 0 & c \end{pmatrix} \in S$, is it true that $$ s \in U(S) \iff \det(s) \in U(R)? $$
My instinct says it isn't but I cant find an example so I can make my mind right.
user26857
  • 52,094
NickSorgas
I assume that by $U(S)$, and $U(R)$ you mean the invertible elements of the ring? This statement is true. Take $s\in U(S)$, there is some $s^{-1}$ such that $ss^{-1}= \text{Id}$. Taking determinants $$ \det(s)\det(s^{-1})=1_R, $$ thus $\det(s)\in U(R)$. Conversely, suppose $\det(s)= ac\in U(R)$, then there is some $d\in R$ such that $acd=1_{R}$. Let $$ t= \begin{pmatrix}cd & -bd\\ 0 & ad\end{pmatrix}. $$ It's easy to see that $$ st= \begin{pmatrix}acd & -abd+abd\\ 0 & cad\end{pmatrix}= \begin{pmatrix}1_R & 0\\ 0 & 1_R\end{pmatrix}. $$
vmastr
  • 880
-1
Answer: For any commutative ring $A$ and any $n\times n$ matrix $R\in Mat(n,A)$ with coefficients in $A$ you may define the adjunct matrix $adj(R)$. This matrix has the property that $adj(R)R=Radj(R)=det(R)Id$ where $Id$ is the $n\times n$ identity matrix and $det(R)$ is the "determinant". The determinant $der(R)\in A$ is multiplicative: $det(RR')=det(R)det(R')$. From this it follows that $R$ is invertible (there is a matrix $R^{-1}\in M(n,A)$ with $RR^{-1}=R^{-1}R=Id$) iff $det(R)\in A^*$ is a unit in $A$.
Proof: If $R$ is invertible it follows $RR^{-1}=Id$ hence $det(RR^{-1})=det(R)det(R^{-1})=det(Id)=1$ hence $det(R)\in A^*$. Conversely if $det(R)\in A^*$ it follows $det(R)^{-1}adj(R):=R^{-1}$ is an inverse in $M(n,A)$.
You may check that in your case it follows $adj(s)$ is upper triangular, hence in your case the inverse (if it exists) lives in $S$. There is an explicit formula for the adjunct matrix for $2\times 2$-matrices:
Why the inverse of a matrix involves division by the determinant?
hm2020
    This does not answer the question. The ring $S$ is not the full ring of two-by-two matrices with entries in $R$, and so what needs to be shown is that if $S$ has invertible determinant, then the inverse of $S$ is in $M_{2}(R)$ is upper triangular. – Alex Wertheim Aug 20 '21 at 09:49
  • @AlexWertheim - the question is a bit "imprecise" - it is not clear if he is asking about an inverse that is upper triangular. In this case the adjunct matrix $adj(s)$ is upper triangular. – hm2020 Aug 20 '21 at 10:25
    @hm2020 Alex Wertheim made a very relevant comment which you are mistaken in brushing off: the question poster is asking what are equivalent (determinant involving) conditions for an arbitrary matrix $M \in \mathscr{S}$ to be invertible in the specific subring $\mathscr{S}$, of upper-triangular matrices and not just as a matrix in general (in the parent ring of all square matrices of order $2$). In algebra invertibility intimately depends on the ambient structure with respect to which it is considered. – ΑΘΩ Aug 20 '21 at 10:25
  • "I assume that by U(S), and U(R) you mean the invertible elements of the ring?" – hm2020 Aug 20 '21 at 10:44
  • @hm2020 Yes, although it is not perhaps a universal practice of notation it is nevertheless the case that some authors refer to the group of $\underline{\mathrm{u}}$nits of ring $A$ by $\mathrm{U}(A)$. – ΑΘΩ Aug 21 '21 at 11:15
