Put $k(x)=f(x)g(x)$. Then $k(x+h)=f(x+h)g(x+h)$ and you just apply the general procedure of expanding a function into its Taylor series:
$$k(x+h)=k(x)+hk'(x)+\frac{h^2}{2}k''(x)+O(h^3)$$
Writing out the derivatives of $k$ in terms of $f,g$, we have
$$f(x+h)g(x+h)=f(x)g(x)+h(f'(x)g(x)+f(x)g'(x))+\frac{h^2}{2}(f''(x)g(x)+2g'(x)f'(x)+f(x)g''(x))+O(h^3)$$
On the other hand, you could also multiply the Taylor expansions directly:
$$(f(x)+hf'(x)+\frac{h^2}{2}f''(x)+O(h^3))(g(x)+hg'(x)+\frac{h^2}{2}g''(x)+O(h^3))$$
and collecting the powers of $h$ you get exactly the same expansion
as above, where $O(h^3)$ will absorb all the powers of $h$ higher than $2$.
The first method is of course easier. The second one shows that the first is equivalent to multiplying the separate series.
