For an ellipse of eccentricity $e$ the formulas are:
${x^2 \over a^2} + {y^2 \over b^2} = 1 \\ e = \sqrt {1-\left({b \over a} \right)^2}$
what about the "3D case"?
There is no 3D analogue of eccentricity, in the sense that there isn't a single real parameter that uniquely characterizes the shape up to scale. An $n$-dimensional ellipsoid's shape can be characterized up to rotations and reflections by $n$ real parameters, the lengths of its principal axes. These generalize the semimajor and semiminor axes, and for an ellipsoid with equation
$$\sum_{i=1}^n \left( \frac{x_i}{\sigma_i} \right)^2 = 1$$
are given by the denominators $\sigma_i$. More generally, for an ellipsoid with equation $x^T M x = 0$ where $x = \left[ \begin{array}{c} x_1 \\ \vdots \\ x_n \end{array} \right]$ and $M$ is a positive-definite symmetric matrix, the principal axes are the lines spanned by the eigenvectors of $M$ and the lengths of the principal axes are the inverses of the corresponding eigenvalues.
An ellipsoid is characterized up to rotations, reflections, and scaling by the ratios $\frac{\sigma_i}{\sigma_j}$ among the lengths of its principal axes; it suffices to consider the $n-1$ ratios $\frac{\sigma_i}{\sigma_{i+1}}$, arranging the lengths in order $\sigma_1 \ge \sigma_2 \ge \dots \ge \sigma_n$. Only when $n = 2$ does this boil down to a single number.
Quadrics which are not ellipses also have principal axes although the corresponding eigenvalues may be negative or zero, so the corresponding "lengths" may be negative or infinite.
In the aspect of measure of the boundary
Perimeter of an ellipse
\begin{align} 1 &= \frac{x^2}{a^2}+\frac{y^2}{b^2} \tag{$a \ge b$} \\ P &= 4aE(e_{ab}) \\ e_{ab} &= \frac{\sqrt{a^2-b^2}}{a} \\ \end{align}
Surface area of an ellipsoid
\begin{align} 1 &= \frac{x^2}{a^2}+\frac{y^2}{b^2}+\frac{z^2}{c^2} \tag{$a \ge b \ge c$} \\ S &= 2\pi \left[ c^2+\frac{bc^2}{\sqrt{a^2-c^2}}F(\theta,k)+b\sqrt{a^2-c^2} E(\theta,k) \right] \\ \theta &= \cos^{-1} \frac{c}{a} \\ k &= \frac{a}{b} \sqrt{\frac{b^2-c^2}{a^2-c^2}} \\ &= \frac{e_{bc}}{e_{ac}} \\ k' &= \sqrt{1-k^2} \\ &= \frac{c}{b} \sqrt{\frac{a^2-b^2}{a^2-c^2}} \\ &= \frac{e_{ab}}{e_{ac}} \end{align}
$$b=c \implies (k,k')=(0,1)$$
$$a=b \implies (k,k')=(1,0)$$
In the aspect of confocal system
Confocal conics
\begin{align} 1 &= \frac{x^2}{a^2+s}+\frac{y^2}{b^2+s} \\ e^2 &= \frac{a^2-b^2}{a^2+s} \end{align}
Confocal quadrics
\begin{align} 1 &= \frac{x^2}{a^2+s}+\frac{y^2}{b^2+s}+\frac{z^2}{c^2+s} \\ \kappa^2 &= \frac{a^2-c^2}{a^2+s} \end{align}
For $s\to \infty$, $\kappa \to 0$ which close to a sphere.
For $s\to -c$, $\kappa \to 1$ which shrinks to focal ellipse namely
$$0=z=\frac{x^2}{a^2-c^2}+\frac{y^2}{b^2-c^2}-1$$
