I've been struggling with this integral for a few days.
$$\int_{0}^{\pi /2}\!\arccos\left(\frac{\cos(x)}{1+2\cos(x)}\right)dx$$
Any help would be appreciated. Cheers.
Kenta S
  • 16,151
  • 26
  • 53
Lmnop
This is the so-called Coxeter integral. It is related to Ahmed integrals. You can refer to this and this for calculating it. The result is $$ \int_{0}^{\frac{\pi}{2}}\arccos \left (\frac{ \cos(x)}{1+2 \cos(x)}\right )dx=\frac{5\pi^2}{24} $$
Also you can find more on this page.
FFjet
  • 5,041
    I saw solution of the integral. The first step is to simplify the integrand and then maybe integration by parts — but Feynman algorithm shall definitely be used in order to compute integral. I found the document wherein I discerned solution but can't attach so you would see it. Integral is rather simple but from the point of technical view :) – sergei ivanov Dec 20 '20 at 15:28
  • Search in Google: Two very challenging calculus problems. You will, should you have not yet, understand about what I am speaking of. – sergei ivanov Dec 20 '20 at 15:30
  • Could you please put a link here? I don't understand what you mean. – FFjet Dec 20 '20 at 15:38
  • https://www.math.ucla.edu/~josephbreen/Some_Very_Challenging_Calculus_Problems-2.pdf – Lmnop Dec 20 '20 at 16:21
  • @Lmnop OK, but the series was solved by Mathematica in $0.0003$ sec, while the integral... no way! – Raffaele Dec 20 '20 at 17:13
