I have some trouble understanding (in my opinion) two conflicting definitions of the quaternion logarithm or the conversion between quaternions and axis-angle representation.
In the second paragraph of this Wikipedia article, a rotation / orientation quaternion is defined as
$$[a, b, c, d] = [\cos(\theta/2),e_x \sin(\theta/2),e_y \sin(\theta/2),e_z \sin(\theta/2)]$$
representing a rotation of $\theta$ about a unit axis $[e_x, e_y, e_z]$ (changed notation). If we want to obtain the axis-angle representation from a quaternion, we can determine the angle as $\theta = 2\arccos(a)$.
I also often see this definition of the quaternion logarithm:
$$\log([a, b, c, d]) = \log ([\cos \theta, e \sin \theta]) \equiv [0, \theta e]$$
Which does not imply that there is a factor 2 involved in the conversion. You would compute $\theta = \arccos(a)$.
Now, the definition in this paper (Equation 19, page 4) is similar and is used to obtain an axis-angle representation from the quaternion. However, to obtain angular velocity from the logarithm of the difference of two quaternions, they multiply the logarithm by 2 again:
$$\omega = 2 \log(q_1 * \overline{q}_2)$$
So it seems like you could as well define
$$\log([a, b, c, d]) = \log ([\cos \theta / 2, e \sin \theta / 2]) \equiv [0, \theta e]$$
to obtain $\theta = 2\arccos(a)$ and then define
$$\omega = \log(q_1 * \overline{q}_2).$$
Are these actually two conflicting definitions of this conversion (or the quaternion representation of rotations)? What is the reason and how can this be resolved?
