I am asked to prove by induction that $7\times11^{2n+1}-3^{4n-1}$ is divisible by $10$.
I wonder whether there is a more direct method, for example factorizing by $10$. If an expression is divisible by $10$, does this mean that I can factorize it by $10$?
Thanks in advance
J. W. Tanner
  • 60,406
Romain
  • 57
    Just think about the last digit. – Angina Seng Sep 19 '20 at 17:04
    With any statement about the set $\Bbb N$ (especially, when the claim doesn't hold for a larger set), a proof by induction is arguably the most direct one. This is somewhat by definition of $\Bbb N$ – Hagen von Eitzen Sep 19 '20 at 17:05
    Are you familiar with congruences such as $,11^2\equiv 3^4\pmod{10},?\ \ $ – Bill Dubuque Sep 19 '20 at 18:37
  • I take it you mean for $n\ge 1$. The persistence of divisibility can be shown in various ways. The numbers $k_n=Aa^n+Bb^n$ satisfy the recurrence $k_{n+1}=(a+b)k_n-abk_{n-1}$ (you can easily verify this by substitution) so (in appropriate cases) once you show that two successive elements are divisible by $d$ then they all are. These problems are quite often used as examples for induction. – Mark Bennet Sep 19 '20 at 19:39
  • Thank you all so much for those answers that will help me more deeply understand this kind of problems. I just still hesitate on this : if an expression in N is divisible by 10, does this mean that I can factorize it by 10 ? – Romain Sep 19 '20 at 22:06
  • Divisible by $10$ means it gives remainder $0$ after division by $10$, and also yes, if you divide it by $10$, the result will be an integer. So $20$ is divisible by $10$ and $20/10=2$ is an integer, while for example $5$ is not divisible by $10$ and $5/10=1/2$ is not an integer (but does not mean you cannot divide it, you can, the result just won't be an integer). Notice also I used term "divide" instead of "factorize". To factorize or factor means typically to decompose into product, so for example we factorize $20$ as $20=2\cdot 10$ (or typically to primes, so $20=2^2\cdot 5$) – Sil Sep 20 '20 at 06:40
9 Answers9
A direct and intuitive way. Every integer power of $11$ has $1$ as last digit, so every number of the form $7 \cdot 11^{2n+1}$ ends with the digit $7$.
The last digits of the integer powers of $3$ follows the four-step cycle $(3,9,7,1)$, so that every number of the form $3^{4n-1}$ has $7$ as last digit.
Therefore, subtracting this second number from the first one we get a number ending with the digit $0$. This implies that this last number is divisible by $10$.
Anatoly
  • 17,079
Below are four proofs using various methods.
You seem to seek a direct proof showing a factor of $10$ so let's do that first.
$$\begin{align} x &\,=\ \ \ \ \, 7\cdot 11^{\large 2n+1}\ -\ 3^{\large 4n-1}\\[.2em] \Rightarrow\ \ 3x &\,=\ \ \, 21\cdot 11\cdot 121^n - 81^n\\[.2em] &\,=\, (21\cdot11\!-\!1)121^n+ \color{#0a0}{121^n-81^n}\\[.2em] &\,=\, \color{#c00}{10}\,(23\cdot 121^n + \color{#c00}4(121^{n-1} + \cdots + 81^{n-1}))\ \end{align}\qquad$$
where we used the Factor Theorem to deduce $\,\color{#c00}{10\cdot 4} = 121\!-\!81\,$ divides $\,\color{#0a0}{121^n-81^n}.\,$ Thus $\,10\mid 3x\Rightarrow 10\mid x\,$ by Euclid (or directly $\,10\mid 7(3x)\!-\!20x = x,\,$ or cancel $3$ from $121$'s and $81$'s).
It's much easier by modular arithmetic (congruences)
$$\begin{align}\bmod 10\!:\ \ 3x &\equiv 21\cdot 11^{\large 2n+1} - 81^{\large n}\\ \iff\ 3x &\equiv \ \ 1\ \cdot\ 1^{\large 2n+1}\ -\ 1^{\large n} \equiv\color{#0a0} 0\\ \iff\ \ \ x &\equiv\,3^{-1}\cdot\color{#0a0} 0\equiv 0 \end{align}\qquad$$
by basic congruence laws. We used the fact that scaling by an invertible (here $3$) yields an equivalent congrence (recall by Bezout that $3$ is invertible being coprime to the modulus $10)$
By induction: base case $\,n=1\,$ is $\!\bmod 10\!:\ 7\cdot 11^3\equiv 3^3\,$ (or $\,7\cdot 11\equiv 1/3\,$ for $\,n=0)\,$ which are both true, and the induction step follows conceptually by simply by multiplying the first two congruences below using $\rm\color{#0a0}{CPR} =$ Congruence Product Rule,
$$\begin{align}\bmod 10\!:\qquad\ \ \ \color{#c00}{11^{\large 2}}\ &\equiv\ \color{#c00}{3^{\large 4}}\\[.2em] {\rm times}\ \ \ \ \ \ \ 7\cdot 11^{\large 2n+1}&\equiv3^{\large 4n-1}\quad \ P(n)_{\phantom{|}}\\[.2em] \hline \Longrightarrow\ \ \ \ \ 7\cdot 11^{\large 2n+\color{#c00}3}&\equiv 3^{\large 4n+\color{#c00}3}\quad\ P(n\!+\!\color{#c00}1), \ \ \rm by \ \,\color{#0a0}{CPR}^{\phantom{|^|}}\end{align}\qquad $$
If congruences are unfamiliar we can preserve the arithmetical essence of this simple proof by using an analogous product rule for divisibility (DPR), as explained here.
Or as here use Binomial Theorem on $\,(1\!+\!10)^{2n+1}$ and $(-1\!+\!10)^{4n-1}$ (or $\,(1\!+\!80)^n\,$ in $3x)$
Remark $ $ All these methods do in fact use induction (on $n),\,$ but it may be hidden (encapsulated) in the proof of a theorem that is invoked, e.g. the Factor Theorem or Binomial theorem, or the Congruence Power Rule $\,a\equiv b\Rightarrow\, a^n\equiv b^n$.
Bill Dubuque
  • 272,048
  • Thank you all so much for those answers that will help me more deeply understand this kind of problems. I just still hesitate on this : if an expression in N is divisible by 10, does this mean that I can factorize it by 10 ? – Romain Sep 19 '20 at 22:11
  • @Romain $,10\mid n,,$ i.e. $10$ divides $n$ means by definition that $, n = 10k,$ for some integer $k,,$ It is often quicker to prove that in ways that don't require explicitly calculating the integer cofactor $k = n/10$ that is witness to the divisibility, e.g. using modular arithmetic (congruences) as above. – Bill Dubuque Sep 19 '20 at 22:14
  • " if an expression in N is divisible by 10, does this mean that I can factorize it by 10 ?" Yes, but you might not always know how. – fleablood Sep 20 '20 at 01:02
    Sadly there seems to be at least one user who consistently downvotes ansers that have multiples proofs. In the unlikely chance that this has anything to do with matehmatics then please leave a constructive comment so that any deficiency you perceive may have a chance to be addressed. – Bill Dubuque Sep 20 '20 at 19:30
we have $$7{(10+1)}^{2n+1}-3{(10-1)}^{2n-1}$$
indeed by binomial theorem it is equivalent to:
$$7(10k+1)-3(10m-1)=10+70k-30m$$
which is div by $10$
Using modular arithmetic: \begin{align}3(7\cdot 11^{2n+1}-3^{4n-1})&=21\cdot 11^{2n+1}-9^{2n}\\&\equiv 1\cdot (1)^{2n+1}-(-1)^{2n}\\&=0 \pmod {10}.\end{align}
Sil
  • 16,612
We have $$3(3^3)=81 \equiv 1 \pmod{10}$$
$$3^{-1}\equiv 3^3 \equiv 7 \pmod{10}$$
\begin{align} 7(11^{2n+1})-3^{4n-1} &\equiv 7 (1^{2n+1}) - (3^4)^n3^{-1}\\ &\equiv 7(1)-(1)(7) \\ &\equiv 0 \pmod{10} \end{align}
Siong Thye Goh
  • 149,520
  • 88
  • 149
Best method? Depends on what you know.
If you know modular arithmetic and Eulers Theorem then
$7\cdot 11^{2n+1} - 3^{4n-1}\equiv 7\cdot 1^{2n+1} - (3^{-1})\cdot 3^{4n}\equiv 7-(3^{-1})\pmod{10}$ and as $3\cdot 7 \equiv 1 \pmod {10}$ then $3^{-1}\equiv 7 \pmod {10}$ and $7-7\equiv 0\pmod {10}$ so $10|7\cdot 11^{2n+1} - 3^{4n-1}$.
But that assumes you are comfortable with many concepts
If you don't know any modular arithmetic:
$11^k = (10+1)^k = 10^k + k10^{k-1} + ...... + k\cdot 10 + 1 = 10 M + 1$.
And $3^{4n-1} = 3\times 3^{4n-2}= 3\times 9^{2n-1}$. And if $k=2n-1$ is odd the $9^k = (10-1)^k = 10^k - k10^{k-1} + ....... + k\cdot 10 - 1= 10N-1$.
So $7\cdot 11^{something} - 3^{1+2\times something\ odd} = 7(10M + 1)- 3(10N-1)= 70M -30N +10$.
fleablood
  • 124,253
  • You didn't invole Euler (maybe you meant to say Euclid for computing the inverse?) – Bill Dubuque Sep 20 '20 at 01:29
  • I meant Euler and I meant that $3^{4n} \equiv 1\pmod {10}$ so $3^{4n-1} \equiv 3^{-1}$. – fleablood Sep 20 '20 at 02:15
  • Ah, I didn't expect use of Euler in such a simple case since it is much easier by repeated squaring $!\bmod 10!:\ (3^2)^2\equiv (-1)^2\equiv 1,,$ or even directly $,(3^2)^2\equiv 9^2\equiv 81\equiv 1.\ \ $ – Bill Dubuque Sep 20 '20 at 02:24
Since
$\quad 11^k \equiv 1 \pmod{10} \quad \forall k \in \Bbb Z$
and
$\quad 3^{4n-1} \equiv {(3^2)}^{2n} \times 3^{-1} \equiv (-1)^{2n} \times 7 \equiv 7 \pmod{10}$
we can write
$\quad 7\times11^{2n+1}-3^{4n-1} \equiv 7 - 7 \equiv 0 \pmod{10}$
Elementary Number Theory:
The invertible elements in $\mathbb{Z}/{10}\mathbb{Z}$ are
$\quad [1], [3], [7] \text{ and } [9]$
allowing one to quickly determine that $3^{-1} \equiv 7 \pmod{10}$.
CopyPasteIt
  • 11,366
The OP is looking for a factorization argument and so we give a problem/hint that can be directly solved without elementary number theory using simple algebra; this is the step case of the induction proof.
Problem: Show that if $k \ge 1$ and
$\tag 1 \displaystyle 7\times11^{2k+1}-3^{4k-1} = 10q$
then
$\tag 2 \displaystyle 7\times11^{2(k+1)+1}-3^{4(k+1)-1} = 10 \times (11^2 q + 4 \times 3^{4k-1})$
CopyPasteIt
  • 11,366
Multiply $n=7\times11^{2n+1}-3^{4n-1}$ by $3$ to get $3n=21\times11^{2n+1}-81^{n}$, which is divisible by $10$
(ones digit is $0$, because it is the difference of two numbers whose ones digit is $1$).
Now if $3n$ is divisible by $10$, for an integer $n$, then $n$ is divisible by $10$. QED.
J. W. Tanner
  • 60,406
