20
I am trying to prove the following statement but have trouble comprehending/going forward with some parts! Here is the statement:
If $A$ is any set, then $|A|$ $<$ $|P(A)|$
Here is what I have so far:
We need to show that there is an injection from $A$ to $P(A)$ but not a surjection.
A natural choice for an injection is the function $ f(x)$ $=$ $\{x \}$, which in plain English, takes any element $x$ (that is in $A$) and sends it to the one-element set $\{x \}$. Thus $f(x)$ is injective!
To show that there is no surjection, for the sake of contradiction, assume there is a surjection. Here is where I start to have trouble. Surjectivity means that every element of the co-domain is mapped to an element of the domain, correct? Consequently, in this particular case, we are "matching" sets (from $P(A)$) to elements (from $A$) right?
If the above is correct, my problem arises here. I am not sure how to prove that $f$ is not surjective. Unfortunately, I am easily confused by notation so please explain in English. Thank you in advance!! :)
nicefella
  • 1,069
  • This can be proved by contradiction. Take your bijective map and construct a "contradictory" set in power set such that it is absurd that there is a map from $A$. – Daniel Li May 15 '18 at 17:03
What you want here is the so-called diagonal argument. The idea is to show that no matter what function $f:A\to\wp(A)$ you look at, you can find a subset $S_f$ of $A$ that is not in the range of $f$. If you can do that, you’ve shown that there is no map of $A$ onto $\wp(A)$ and therefore certainly no bijection from $A$ to $\wp(A)$.
To build the set $S_f$, imagine that you could somehow go through the set $A$ one element at a time. You look at an element $a\in A$, and one of two things must be true: either $a\in f(a)$, or $a\notin f(a)$. (Remember, $f(a)$ is some subset of $A$, so it’s meaningful to ask whether that subset contains $a$.) Since we’re building the set $S_f$ to suit ourselves, we get to decide whether $a\in S_f$ or not, and we’ll decide in exactly the opposite way from the function $f$: if $a\notin f(a)$, we’ll put $a$ into $S_f$, and if $a\in f(a)$, we won’t put $a$ into $S_f$. After we’ve done this for each $a\in A$, our set $S_f$ will contain exactly those $a\in A$ such that $a\notin f(a)$:
$$S_f=\{a\in A:a\notin f(a)\}\;.$$
For each $a\in A$, therefore, the sets $S_f$ and $f(a)$ differ in how they treat $a$: if $a\in f(a)$, then $a\notin S_f$, and if $a\notin f(a)$, then $a\in S_f$.
That’s almost the entire argument: all you have to do to finish it off is explain why this ensures that for $S_f$ is not the set $f(a)$ for any $a\in A$ and why this implies that $S_f$ is not in the range of $f$ and hence that $f$ is not a surjection.
Brian M. Scott
  • 616,228
  • Thank you for your answer! I feel as though this is a stupid question, but how can $a$ not be an element of $f(a)$ ? Can you please provide an example of this? – nicefella Apr 08 '13 at 05:35
    @nicefella: Let $A={0,1}$, and define $f:A\to\wp(A)$ by $f(0)={1}$ and $f(1)=\varnothing$, for instance. Then $0\notin{1}=f(0)$, and certainly $1\notin\varnothing=f(1)$. – Brian M. Scott Apr 08 '13 at 05:42
The idea is to prove that any mapping from $A$ to $P(A)$ will miss certain subsets of $A$. Consider any mapping, say $\phi$ from $A$ to $P(A)$. Now look at the set $B$ defined as follows. $$B = \{a \in A: a \notin \phi(a)\}$$ Clearly, $B \in P(A)$. Now can we find $b \in A$ such that $\phi(b) = B$?
Hint: Assume you have a surjection, consider the set $$T:x\not \in f(x)$$ and claim that $T$ is not empty. How does this help?
Bombyx mori
  • 19,638
  • 52
  • 112
-1
Suppose that we had such a matching. Then, for every element $a\in A$, there is a subset $S_a$ of $A$ matched to it, so that every subset of $A$ occurs as $S_a$ for some $a$.
We have to show that this is impossible, by producing a set which is missed out. We follow Russel's Paradox.
Let $B$ consist of all those elements a of $A$ which do not lie in the subset they label:
$$B=\{a\in A\ |\ a\not\in A_a\}$$
Now, if we have a complete matching, then the subset $B$ must occur in the matching, that is, $B = S_b$ for some element $b \in A$, but this is impossible:
If $b\in S_b$, then by definition $b \not\in B$, while if $b \not\in S_b$, then $b \in B$; so the sets $B$ and $S_b$ differ at the element $b$ (one contains it, the other doesn’t) and cannot be equal. So the proposed matching is not complete.
well
