I have two limit problems which are quite similar, so I've put them both into this post.
- $((4^{10}+2^{n})^{\frac{1}{n}})$
- $((3n^{2}+n)^{\frac{1}{n}})$
Attempt:
For 1, I'm not sure if this is permissible. I know that $\lim_{n \to \infty}(x^{n}+y^{n})^{\frac{1}{n}} = \max\{x,y\}$. Obviously $4^{10}$ is a constant so it's not quite in the same form, but I believe it is still okay to use this result, and so the limit is $2$.
For 2, I've got $((3n^{2}+n)^{\frac{1}{n}}) = (n(3n+1)^{\frac{1}{n}})$, but then I'm not too sure how to proceed.
I also thought of taking the log and proceeding that way, however in the notes I'm learning from they haven't covered l'hopital yet, so I'm trying to not use it.
Thanks.
