There's a problem (#10.23) in Apostol's Mathematical Analysis of which I am having a rough time solving: Let $F(y)= \int_{0}^{\infty}\frac{\sin xy}{x(x^{2}+1)}dx$ if $y > 0$. Show that $F$ satisfies the differential equation $F''(y)-F(y)+\frac{\pi }{2} = 0$ and deduce that $F(y)= \frac{1}{2}\pi(1-e^{-y})$. Use this result to deduce the following equations, valid for $y > 0$ and $a > 0$: Use this to deduce that for $y>0$ and $a>0$ \begin{align} \int\nolimits_{0}^{\infty}\frac{\sin xy}{x(x^{2}+a^{2})}dx = \frac{\pi}{2a^{2}}(1-e^{-ay}), \newline \int_{0}^{\infty}\frac{\cos xy}{x^{2}+a^{2}}dx = \frac{\pi e^{-ay}}{2a}, \newline \int_{0}^{\infty}\frac{x\sin xy}{x^{2}+a^{2}}dx = \frac{\pi}{2}e^{-ay} \end{align} We could use $\int_{0}^{\infty}\frac{\sin x}{x}dx = \frac{\pi}{2}$
How can I show this?
    You can use dollar signs to get your tex code compiled. – Rasmus Apr 20 '11 at 21:39
    this problem has multiple parts. Which one are you stuck at? – Alon Amit Apr 20 '11 at 21:43
    Which parts do you have trouble with? – Rasmus Apr 20 '11 at 21:43
    This is posted as an answer to a previous question: http://math.stackexchange.com/questions/9402/calculating-the-integral-int-0-infty-frac-cos-x1x2-without-using-c/9409#9409 . – Raeder Apr 20 '11 at 21:57
  • @user9848: Assume all the nice things like swapping the derivative with the integral etc. Are you having trouble with justifying this or with the algebra part? –  Apr 20 '11 at 22:35
Let $f(x,y)=\frac{\sin(xy)}{x(x^2+1)}$. Then $$f_{yy}(x,y)-f(x,y)=-\frac{x\sin(xy)}{x^2+1}-\frac{\sin(xy)}{x(x^2+1)}=-\frac{\sin(xy)}{x}$$ It follows that $$F''(y)-F(y)=\int_0^\infty -\frac{\sin(xy)}{y} dx=-\int_0^\infty \frac{\sin(xy)}{xy} \,d(xy)=-\pi/2$$ Then $F(y)$ is a solution to the differential equation $z''-z+\frac{pi}{2}=0$. It follos that $F(y)=ae^y+be^{-y}+\frac{\pi}{2}$. From the definition of $F(y)$ one can check that $\lim_{y\to 0} F(y)=0$ and $\lim_{y\to 0} F'(y)=\pi/2$. Then $a+b+\pi/2=0$ and $a-b=\pi/2$. Solving for $a$ and $b$ we have $a=0$ and $b=-\pi/2$. Therefore $$F(y)=\frac{\pi}{2}(1-e^{-y})$$. Let $$G(y):=\int_{0}^{\infty}\frac{\sin xy}{x(x^{2}+a^{2})}dx.$$By substitution $t=x/a$ one can show that $G(y)=\frac{F(ay)}{a^2}=\frac{\pi}{2a^2}(1-e^{-ay})$ and then $$\begin{align*}G'(y)&=\frac{F'(ay)}{a}=\frac{\pi e^{-ay}}{2a}\\G''(y)&=F''(ay)=-\frac{\pi}{2}e^{-ay}\end{align*}$$
user9077
  • 1,811
