Known that $a^{\theta}b^{1-\theta}\leq\theta a+(1-\theta)b$ for all $a,b\geq0$ and $\theta\in[0,1]\\$. Now I want to prove, for $x,y\in R^n$ and $p,q>1$ s.t. $\frac{1}{p}+\frac{1}{q}=1$: $\sum_{i=1}^{n}{x_iy_i} \leq (\sum_{i=1}^{n}|x_i|^p)^{\frac{1}{p}}(\sum_{i=1}^{n}|y_i|^q)^{\frac{1}{q}}$. Here is the hint: $let\quad a = \frac{|x_i|^p}{\sum_{j=1}^{n}|x_j|^p}\quad b = \frac{|y_i|^q}{\sum_{j=1}^{n}|y_j|^q}$ and $\theta=\frac{1}{p}.$ $\quad$ I've tried to plug in the formula as hint indicated and moved the RHS of the desired inequality to one side but don't know what to do next.
MafPrivate
  • 4,033
Walls
  • 75
Assume first that $\sum |x_i|^{p}=\sum |y_i|^{q}=1$. Then we get $|x_i|^{p\theta}|y_i|^{q(1-\theta)}=|x_iy_i| $. Hence $\sum |x_iy_i| \leq \sum _i(\frac 1 p |x_i|^{p} +\frac 1 q |y_i|^{q}) \leq 1$. This proves the result when $\sum |x_i|^{p}=\sum |y_i|^{q}=1$. For the general case just apply what you have proved with $x_i$ replaced by $\frac {x_i} {(\sum |x_i|^{p})^{1/p}}$ and $y_i$ replaced by $\frac {y_i} {(\sum |q_i|^{p})^{1/q}}$.
Proof without going to the special case:
Let $A=(\sum |x_i|^{p})^{1/p}$ and $A=(\sum |x_i|^{p})^{1/p}$. Then $\frac 1 A|x_i| \frac 1 B|y_i| \leq \frac 1 p |x_i|^{p}/A^{p}+\frac 1 q |y_i|^{q}/A^{q}$. Summing this and multiplying by $AB$ we get $\sum |x_iy_i| \leq \frac 1 p(\sum |x_i|^{p} /A^{p-1}+\frac 1 q(\sum |y_i|^{q} /B^{q-1}$. Now can you finish the proof?
  • You can do this in single step, but have considered a special case first because it is easier to type the proof in this case. – Kavi Rama Murthy Sep 21 '19 at 05:14
  • I've tried but it seems not working. Would you please explain in more details? – Walls Sep 21 '19 at 05:30
  • @Walls Can you tell which step in my answer you have difficulty with? – Kavi Rama Murthy Sep 21 '19 at 05:32
  • When replacing the $x_i$, I've got concerns when generalizing the special case. Does your solution follow the hint? I've tried what the hint says and I've moved the RHS of the goal to one side but the other side seems to be too complicated and I cannot see how it relates to $\sum{x_i y_i}$ – Walls Sep 21 '19 at 05:42
  • @Walls I have given a direct proof. You should get $\frac 1 p AB+\frac 1 q AB=AB$ at the end of the proof. – Kavi Rama Murthy Sep 21 '19 at 06:02
