I'd like to find the equation of the parabola that passes through two points, and for which the slope of the parabola is defined at those two points; I believe that these conditions fully define, but do not over-define the parabola. Note that, in general, the axis of symmetry of the parabola won't be parallel to the $x$ or $y$ axis, so that the equation can't be written as $ax^2 + bx + c - y = 0$. As an example, consider the parabola that passes through point $A$ at $(-95,3)$ and is tangent (at $A$) to a line with slope of $35^{\circ}$ to the x axis. It also passes through $B$ at $(-150,50)$ and is tangent (at $B$) to a line with slope of $8^{\circ}$ to the x axis. What's the equation of the parabola that satisfies these conditions? I believe that the general equation of a parabola is $ax^2 + bxy + cy^2 + dx + ey + f = 0$. I also understand that I need to differentiate at the tangency points to find two linear equations, but I'm unsure how to find my six unknowns ($a$ through $f$) from the conditions that define my parabola. Many thanks in advance!
Solving the system can be problematic, since you don't know which coefficient(s) might vanish. A "direct" (though computationally-expensive) approach, described in this answer, uses a $6\times 6$ determinant for the five-point conic. Two points are your givens ($A$ and $B$); two more are infinitesimally-displaced from those along the tangent lines. You'll need a fifth point, which geometry provides: If $M$ is midpoint of $A$ and $B$, and $N$ is the point where the tangent lines meet, then the midpoint of $M$ and $N$ lies on the parabola. – Blue Sep 13 '19 at 23:49
Effectively a duplicate of https://math.stackexchange.com/q/3206543/265466. See also https://math.stackexchange.com/q/2622143/265466 and https://math.stackexchange.com/q/2999165/265466. – amd Sep 14 '19 at 04:05
Note that you can reduce the number of unknowns immediately. Since you know that the curve is a parabola, the quadratic part must be a perfect square, so you can replace it with $(\alpha x+\beta y)^2$. – amd Sep 14 '19 at 06:17
Expanding upon my comment, and following the same basic strategy as in this answer, we can get the equation mechanically using the determinant for the five-point conic through $P=(P_x,P_y)$, $Q=(Q_x,Q_y)$, $R=(R_x,R_y)$, $S=(S_x,S_y)$, $T=(T_x,T_y)$: $$\left|\begin{array}{c,c,c,c,c,c} x^2 & y^2 & x y & x & y & 1 \\ P_x^2 & P_y^2 & P_x P_y & P_x & P_y & 1 \\ Q_x^2 & Q_y^2 & Q_x Q_y & Q_x & Q_y & 1 \\ R_x^2 & R_y^2 & R_x R_y & R_x & R_y & 1 \\ S_x^2 & S_y^2 & S_x S_y & S_x & S_y & 1 \\ T_x^2 & T_y^2 & T_x T_y & T_x & T_y & 1 \\ \end{array}\right| = 0 \tag{$\star$}$$
It happens to be convenient to have the origin at the midpoint of the given points, so let us take $$P = (d\cos\theta,d\sin\theta) \qquad Q = (-d\cos\theta, -d\sin\theta) \tag{1}$$ Two more points come from infinitesimally-displacing $P$ and $Q$ along their tangent lines (in directions, say, $\phi$ and $\psi$, respectively): $$R = P + (p\cos\phi, p\sin\phi) \qquad S = Q + (q\cos\psi,q\sin\psi) \tag{2}$$ for "very small" $p$ and $q$. The fifth point is provided by the specific geometry of the parabola; if $M$ is the midpoint of $P$ and $Q$, and $N$ is the point where the tangent lines at $P$ and $Q$ meet, then the midpoint of $M$ and $N$ lies on the parabola. Thus, we can take $$T = \frac{d}{2\sin(\phi-\psi)}\left(\cos\phi\sin(\psi-\theta)+\cos\psi\sin(\phi-\theta), \sin\phi\sin(\psi-\theta)+\sin\psi\sin(\phi-\theta)\right) \tag{3}$$ Substituting into $(\star)$, and letting a computer algebra system crunch some symbols, we factor-out and cancel a $p$ and $q$, then set the remaining $p$s and $q$s to zero. Canceling factors of $d^2 \csc^2(\phi-\psi) \sin(\phi-\theta)\sin(\psi - \theta)$, we have
$$\begin{align} 0 &= \phantom{2}x^2 (\sin\phi\sin(\psi-\theta)+\sin\psi\sin(\phi-\theta))^2 \\ &+ \phantom{2}y^2 (\cos\phi\sin(\psi-\theta)+\cos\psi\sin(\phi-\theta))^2 \\ &-2x y (\sin\phi\sin(\psi-\theta)+\sin\psi\sin(\phi-\theta))(\cos\phi\sin(\psi-\theta)+\cos\psi\sin(\phi-\theta)) \\ &-4 x d \sin\theta \sin(\phi-\psi) \sin(\phi-\theta) \sin(\psi-\theta) \\ &+4 y d \cos\theta \sin(\phi-\psi) \sin(\phi-\theta) \sin(\psi-\theta) \\ &-4 d^2 \sin^2(\phi-\theta)\sin^2(\psi-\theta) \end{align} \tag{$\star\star$}$$
- 75,673
Thanks Blue, that's brilliant. I really appreciate you working so hard on this. So applying this solution to my original example, I would "move" the origin to the mid-point between A and B, which I find to be at (-122.5,26.5). That means that P = (27.5,-23.5) and Q = (-27.5, 23.5). I then find that d = 36.1732 and theta = -0.7071 radians. I originally defined A as being at 35° to the x axis (I realized I didn't specify whether it was a positive or negative slope, but let's assume negative for both angles), so phi = -0.6109 radians and psi = -0.1396 radians. Does this seem correct so far? – Nexus Sep 14 '19 at 03:39
As a check, I use the x co-ordinates of points P & Q in the beautiful equation you found, but I don't find that the six terms sum to zero. This is likely an error on my part, but I wanted to ask if (i) I followed your solution correctly up to the point of solving the equation and (ii) whether you found all terms to sum to zero using P and Q as test cases. Many thanks again, Blue - you're a champion. – Nexus Sep 14 '19 at 03:42
@Nexus: I agree with all of your calculations. Inputting them into $(\star\star)$ with Mathematica, I get that the parabola's equation is $$217.074+36.927x-1.38651x^2+43.2124y-4.72149xy-4.01955y^2=0$$ Entering the $x$ and $y$ coordinates of $P$ yields $-4.54747\times 10^{-13}$, which, given the numerical approximations involved, counts as zero. ... I've double-checked that I didn't make a typo. ... You can tell that $(x,y)=d(\cos\theta,\sin\theta)$ "should" work: the linear terms instantly cancel; the second-degree terms factor as a perfect square that simplifies to cancel with the constant. – Blue Sep 14 '19 at 04:36
Thanks for your reply, @Blue, and apologies for belabouring this problem, since you've clearly solved it already. When I take your coefficients and enter the coordinates of P, I also get ~0. However, I can't arrive at the same coefficients. We've agreed on the input values, so let me break down the math for each coefficient, in order to find out what I'm doing wrong. Once again, I'm using:
d = 36.1732 ; theta = -0.7071 ; phi = -0.6109 ; psi = -0.1396
– Nexus Sep 14 '19 at 15:04 -
x^2: (sin(-0.6109)sin(-0.1396--0.7071)+sin(-0.1396)sin(-0.6109--0.7071))^2 = 0.1035 (but you get -1.38651) – Nexus Sep 14 '19 at 15:15
y^2: (cos(-0.6109)sin(-0.1396--0.7071)+cos(-0.1396)sin(-0.6109--0.7071))^2 = 0.2868 (but you get -4.01955) – Nexus Sep 14 '19 at 15:18
1and one more for the constant term: -4(36.1732)^2(sin(-0.6109--0.7071))^2*(sin(-0.1396--0.7071))^2 = -13.9701 (but you get 217.074). I won't write out the other three coefficients, for which I also get different answers - I suspect those should be enough to trouble-shoot what's going wrong. Thanks again, Blue - I really appreciate you sticking with this problem! – Nexus Sep 14 '19 at 15:24
@Nexus: I don't know what happened with my earlier comment. (I feel like I'm taking crazy pills!) Sorry about that. The equation should be $$-13.9701-2.20474x+0.103484x^2-2.58001y+0.344524xy+0.286753y^2=0$$ So, we would seem to be in agreement, at least about the second-degree and constant terms. Mathematica tells me that $P$ and $Q$ satisfy this equation (with an approximate $0$). – Blue Sep 14 '19 at 16:23
1Brilliant - that's helped me zero in on my error, which was a typo in the xy coefficient (which I thought I'd thoroughly checked...). Thanks so much, Blue - I really appreciate your help, and all the hard work. – Nexus Sep 14 '19 at 16:45
