How to prove, in an elegant way that
$$I=\int_0^1\frac{\ln x\ln^2(1-x)}{1+x}dx=\frac{11}{4}\zeta(4)-\frac14\ln^42-6\operatorname{Li}_4\left(\frac12\right)\ ?$$
First, let me show you how I did it
\begin{align} I&=\int_0^1\frac{\ln x\ln^2(1-x)}{1+x}\ dx\overset{1-x\ \mapsto x}{=}\int_0^1\frac{\ln(1-x)\ln^2x}{2-x}\ dx\\ &=\sum_{n=1}^\infty\frac1{2^n}\int_0^1x^{n-1}\ln^2x\ln(1-x)\ dx\\ &=\sum_{n=1}^\infty\frac1{2^n}\frac{\partial^2}{\partial n^2}\int_0^1x^{n-1}\ln(1-x)\ dx\\ &=\sum_{n=1}^\infty\frac1{2^n}\frac{\partial^2}{\partial n^2}\left(-\frac{H_n}{n}\right)\\ &=\sum_{n=1}^\infty\frac1{2^n}\left(\frac{2\zeta(2)}{n^2}+\frac{2\zeta(3)}{n}-\frac{2H_n}{n^32^n}-\frac{2H_n^{(2)}}{n^22^n}-\frac{2H_n^{(3)}}{n2^n}\right)\\ &=2\zeta(2)\operatorname{Li}_2\left(\frac12\right)+2\ln2\zeta(3)-2\sum_{n=1}^\infty\frac{H_n}{n^32^n}-2\sum_{n=1}^\infty\frac{H_n^{(2)}}{n^22^n}-2\sum_{n=1}^\infty\frac{H_n^{(3)}}{n2^n} \end{align}
By substituting
$$S_1=\sum_{n=1}^\infty \frac{H_n}{n^32^n}=\operatorname{Li}_4\left(\frac12\right)+\frac18\zeta(4)-\frac18\ln2\zeta(3)+\frac1{24}\ln^42$$
$$ S_2=\sum_{n=1}^{\infty}\frac{H_n^{(2)}}{{n^22^n}}=\operatorname{Li_4}\left(\frac12\right)+\frac1{16}\zeta(4)+\frac14\ln2\zeta(3)-\frac14\ln^22\zeta(2)+\frac1{24}\ln^42$$
$$S_3=\sum_{n=1}^\infty\frac{H_n^{(3)}}{n2^n}=\operatorname{Li_4}\left(\frac12\right)-\frac{5}{16}\zeta(4)+\frac78\ln2\zeta(3)-\frac14\ln^22\zeta(2)+\frac{1}{24}\ln^42$$
along with $\operatorname{Li}_2(1/2)=\frac12\zeta(2)-\frac12\ln^22$ we get the closed form on $I$. Note that $S_1$, $S_2$ and $S_3$ can be found here, here and here respectively.
Now we can see how boring and tedious our calculations are as we used results of three harmonic series with powers of 2 in the denominator. A friend ( who proposed this problem ) suggested that the integral can be done without using harmonic series, so any idea how to do it that way?
Thanks
Ali Shadhar
  • 25,498
  • Define "without harmonic series"; the answer involves a dilogarithm, which are usually defined by a series. Are you asking for a solution that avoids using Euler Sums, and instead uses integral identities for the dilogarithm? Potential solutions involve considering partial derivatives of the Beta function and perhaps carefully decomposing either $\frac{1}{1+x}$ or one of the logarithms into a Taylor Series and using integral identities. I'm afraid I don't have time right now to check though. – Brevan Ellefsen Aug 17 '19 at 03:06
    We can use easy common euler sums but not the sums I used. – Ali Shadhar Aug 17 '19 at 04:54
  • @Zacky why did you delete your solution? It's a nice idea can you undelete it? – Ali Shadhar Aug 17 '19 at 15:21
    Since $\int_0^1 \frac{\ln^3(1-x)}{1+x}dx=-6\operatorname{Li}_4\left(\frac12\right)$ it might be better to show first that: $$\int_0^1 \frac{\ln \left(\frac{x}{1-x}\right) \ln^2(1-x)}{1+x}dx=\frac{11}{4}\zeta(4)-\frac14\ln^4 2$$ Do you have any ideas for this one? (that doesn't use harmonic series). – Zacky Jan 31 '20 at 17:26
    @Zacky by integration by parts we have
    $$\int_0^1\frac{\ln x\ln^2(1-x)}{1+x}\ dx=2\int_0^1\frac{\ln x\ln(1-x)\ln(1+x)}{1-x}\ dx-\int_0^1\frac{\ln^2(1-x)\ln(1+x)}{x}\ dx$$
    The first integral can be treated the same way you treated the blue integral. As for the second integral, its trivial.
    – Ali Shadhar Jan 31 '20 at 18:46
8 Answers8
I'll just show an idea that avoids those type of sum, but skip the calculations. You might also have better ideas to solve them.
For start we will denote $a=\ln(1-x)$ and $b=\ln(1+x)$ and use the following identity: $$a^2=\frac12 (a+b)^2+\frac12(a-b)^2-b^2$$ $$\Rightarrow I=\frac12 \underbrace{\int_0^1 \frac{\ln x\ln^2(1-x^2)}{1+x}dx}_{I_1}+\frac12\underbrace{ \int_0^1 \frac{\ln x\ln^2\left(\frac{1-x}{1+x}\right)}{1+x}dx}_{I_2}-\underbrace{\int_0^1 \frac{\ln x\ln^2(1+x)}{1+x}dx}_{I_3}$$
For the first integral we will write the denominator as: $$\frac{1}{1+x}=\frac{1}{1-x^2}-\frac{x}{1-x^2}$$ $$\Rightarrow I_1=\int_0^1 \frac{\ln x\ln^2(1-x^2)}{1-x^2}dx-{\int_0^1 \frac{x\ln x\ln^2(1-x^2)}{1-x^2}dx}$$ $$\overset{x^2\to x}=\frac14 \int_0^1 \frac{\ln x\ln^2(1-x)}{1-x}\frac{dx}{\sqrt x}-\frac14\int_0^1 \frac{\ln x\ln^2(1-x)}{1-x}dx$$ Those two integral can be found using the second identity from here.
Let's also take $I_2$ and substitute $\frac{1-x}{1+x}\to x$. $$\Rightarrow I_2=\underbrace{\int_0^1 \frac{\ln(1-x)\ln^2 x}{1+x}dx}_{P}-\underbrace{\int_0^1 \frac{\ln(1+x)\ln^2 x}{1+x}dx}_{Q}$$ $$P-Q=I_2;\quad P+Q=\int_0^1 \frac{\ln(1-x^2)\ln^2 x}{1+x}dx$$ And again with the same trick done for $I_1$, we have: $$P+Q=\int_0^1 \frac{\ln(1-x^2)\ln^2 x}{1-x^2}dx-\int_0^1 \frac{x\ln(1-x^2)\ln^2 x}{1-x^2}dx$$ $$\overset{x^2\to x}=\frac18\int_0^1 \frac{\ln(1-x)\ln^2 x}{1-x}\frac{dx}{\sqrt x}-\frac18 \int_0^1 \frac{\ln(1-x)\ln^2 x}{1-x}dx$$ Henceforth we can extract our second integral, $I_2$ as: $$I_2=P-Q=(P+Q)-2Q$$ Note that $P+Q$ can again be found using the second identity from here.
Finally, we only need to find $Q$.
$$Q=\int_0^1 \frac{\ln(1+x)\ln^2 x}{1+x}dx=\sum_{n=1}^\infty (-1)^{n+1} H_n\int_0^1 x^{n}\ln^2 x=2\sum_{n=1}^\infty \frac{(-1)^{n+1}H_n}{(n+1)^3}$$ So $Q$ is actually an Euler sum in disguise, but you nicely found it here.
Also, $I_3$ is pretty easy, one just needs to use the same approach as done for $I_1$ in your following post. $$I_3=\int_0^1 \frac{\ln x \ln^2(1+x)}{1+x}dx\overset{IBP}=-\frac12\int_0^1 \frac{\ln^3(1+x)}{x}dx$$
Zacky
  • 27,674
  • @Zazky your solution involves the alternating sum of weight 4 which is related to $S_1$ in the post body. But all in all it's a nice solution. – Ali Shadhar Aug 17 '19 at 18:58
    I think that if you assume only the following formula for $0<|a|<1$ :\begin{align}\int_0^1\frac{\ln^r x}{1-ax},dx=\frac{(-1)^r r!}{a}\text{Li}_{r+1}(a)\end{align} and using integration by parts and univariate change of variable, the computation is doable. I'm working on it. – FDP Aug 17 '19 at 19:30
  • It's possible to compute \begin{align}\int_0^1 \frac{\ln(1+x)\ln^2 x}{1+x},dx\end{align}without using series expansion. See, for example, https://math.stackexchange.com/a/2174007/186817 – FDP Aug 18 '19 at 19:31
    About your $I_3$, we can use the generalization here https://math.stackexchange.com/q/3440584 . – Ali Shadhar Jan 31 '20 at 19:26
    @Zacky your integral $Q$ is calculated here https://math.stackexchange.com/q/3530782 using only integration. So your solution is actually complete. – Ali Shadhar Feb 01 '20 at 21:48
  • @FDP the integral $\int_0^1\frac{\ln(1+x)\ln^2x}{1+x}\ dx$ is calculated here https://math.stackexchange.com/q/3530782 without euler sums. – Ali Shadhar Feb 01 '20 at 21:52
  • @Ali Shather: see https://math.stackexchange.com/a/3511294/186817 – FDP Feb 03 '20 at 19:30
  • @FDP ah i see my approach is similar to yours , Also Felix Martin did it before. – Ali Shadhar Feb 06 '20 at 18:20
  • Ali Shather: Did you use Euler sum? I didn't. Lately i have written down a way to compute $\text{Li}_3\left(\frac{1}{2}\right)$ without Euler sum, using IBP and simple changes of variable. – FDP Feb 06 '20 at 21:50
Here is a solution using only integration and with a bonus
Let
$$P=\int_0^1\frac{\ln x\ln^2(1-x)}{1+x}\ dx$$
$$Q=\int_0^1\frac{\ln^2x\ln(1-x)}{1+x}\ dx$$
I am going to establish two relations and solve for $P$ and $Q$.
The first relation:
Use the identity
$$3ab^2-3a^2b=(a-b)^3-a^3+b^3$$
set $a=\ln x$ and $b=\ln(1-x)$ we have
$$3P-3Q=\int_0^1\frac{\ln^3\left(\frac{x}{1-x}\right)}{1+x}\ dx-\int_0^1\frac{\ln^3x}{1+x}\ dx+\underbrace{\int_0^1\frac{\ln^3(1-x)}{1+x}\ dx}_{1-x\to x}$$
Subbing $\frac{x}{1-x}\to x$ gives
$$\int_0^1\frac{\ln^3\left(\frac{x}{1-x}\right)}{1+x}\ dx=\int_0^\infty\frac{\ln^3x}{(1+x)(1+2x)}\ dx$$ $$=\int_0^1\frac{\ln^3x}{(1+x)(1+2x)}\ dx+\underbrace{\int_1^\infty\frac{\ln^3x}{(1+x)(1+2x)}\ dx}_{x\to 1/x}$$
$$=\int_0^1\frac{\ln^3x}{(1+x)(1+2x)}\ dx-\int_0^1\frac{\ln^3x}{(1+x)(2+x)}\ dx$$
$$=2\int_0^1\frac{\ln^3x}{1+2x}\ dx+\int_0^1\frac{\ln^3x}{2+x}\ dx-2\int_0^1\frac{\ln^3x}{1+x}\ dx$$
$$\Longrightarrow 3P-3Q=2\int_0^1\frac{\ln^3x}{1+2x}\ dx+\int_0^1\frac{\ln^3x}{2+x}+\int_0^1\frac{\ln^3x}{2-x}\ dx-3\int_0^1\frac{\ln^3x}{1+x}\ dx$$
$$P-Q=-2\operatorname{Li}_4\left(\frac12\right)+\frac{7}4\zeta(4)-\ln^22\zeta(2)-\frac1{12}\ln^42\tag1$$
The second relation:
By integration by parts we have
$$P=2\underbrace{\int_0^1\frac{\ln x\ln(1-x)\ln(1+x)}{1-x}\ dx}_{Y}-\underbrace{\int_0^1\frac{\ln^2(1-x)\ln(1+x)}{x}\ dx}_{Z}\tag2$$
For $Y$, use the identity $4ab=(a+b)^2-(a-b)^2$
set $a=\ln(1-x)$ and $b=\ln(1+x)$ we have
$$4Y=\underbrace{\int_0^1\frac{\ln x\ln^2(1-x^2)}{1-x}\ dx}_{Y_1}-\underbrace{\int_0^1\frac{\ln x\ln^2\left(\frac{1-x}{1+x}\right)}{1-x}\ dx}_{Y_2}$$
For $Y_1$, using @Zacky's technique above $\frac1{1-x}=\frac{1+x}{1-x^2}=\frac{1}{1-x^2}+\frac{x}{1-x^2}$
$$Y_1=\int_0^1\frac{\ln x\ln^2(1-x^2)}{1-x^2}\ dx+\int_0^1\frac{x\ln x\ln^2(1-x^2)}{1-x^2}\ dx$$
$$\overset{x^2\to x}=\frac14 \int_0^1 \frac{\ln x\ln^2(1-x)}{1-x}\frac{dx}{\sqrt x}+\frac14\int_0^1 \frac{\ln x\ln^2(1-x)}{1-x}dx$$
$$Y_1=-\frac{17}{4}\zeta(4)+7\ln2\zeta(3)-3\ln^22\zeta(2)$$
where the last result follows from using Beta function.
For $Y_2$, set $\frac{1-x}{1+x}\to x$
$$Y_2=\int_0^1\frac{\ln\left(\frac{1-x}{1+x}\right)\ln^2x}{x(1+x)}\ dx$$ $$=\int_0^1\frac{\ln\left(\frac{1-x}{1+x}\right)\ln^2x}{x}\ dx-\underbrace{\int_0^1\frac{\ln(1-x)\ln^2x}{1+x}\ dx}_{Q}+\int_0^1\frac{\ln(1+x)\ln^2x}{1+x}\ dx$$
where
$$\int_0^1\frac{\ln\left(\frac{1-x}{1+x}\right)\ln^2x}{x}\ dx=\sum_{n=0}^\infty\frac{-2}{2n+1}\int_0^1 x^{2n}\ln^2x \ dx=\sum_{n=0}^\infty\frac{-4}{(2n+1)^4}=-\frac{15}{4}\zeta(4)$$
and we proved here
$$\int_0^1\frac{\ln(1+x)\ln^2x}{1+x}\ dx=4\operatorname{Li_4}\left(\frac12\right)-\frac{15}4\zeta(4)+\frac72\ln2\zeta(3)-\ln^22\zeta(2)+\frac{1}{6}\ln^42$$
$$\Longrightarrow Y_2=4\operatorname{Li_4}\left(\frac12\right)-\frac{15}2\zeta(4)+\frac72\ln2\zeta(3)-\ln^22\zeta(2)+\frac{1}{6}\ln^42-Q$$
Collect the results of $Y_1$ and $Y_2$ we get
$$4Y=-4\operatorname{Li_4}\left(\frac12\right)+\frac{13}4\zeta(4)+\frac72\ln2\zeta(3)-2\ln^22\zeta(2)-\frac{1}{6}\ln^42+Q\tag3$$
For the integral $Z$, its common to use algebraic identities for such integrals
$$a^2b=\frac16(a+b)^3-\frac16(a-b)^3-\frac13b^3$$
$$Z=\frac16\underbrace{\int_0^1\frac{\ln^3(1-x^2)}{x}\ dx}_{x^2\to x}-\frac16\underbrace{\int_0^1\frac{\ln^3\left(\frac{1-x}{1+x}\right)}{x}\ dx}_{\frac{1-x}{1+x}=x}-\frac13\int_0^1\frac{\ln^3(1+x)}{x}\ dx$$
$$=\frac1{12}\underbrace{\int_0^1\frac{\ln^3(1-x)}{x}\ dx}_{-6\zeta(4)}-\frac13\underbrace{\int_0^1\frac{\ln^3x}{1-x^2}\ dx}_{-\frac{45}{8}\zeta(4)}-\frac13\int_0^1\frac{\ln^3(1+x)}{x}\ dx$$
The last integral can be calculated using the generalization
$$\int_0^1\frac{\ln^n(1+x)}{x}\ dx=\frac{\ln^{n+1}(2)}{n+1}+n!\zeta(n+1)+\sum_{k=0}^n k!{n\choose k}\ln^{n-k}(2)\operatorname{Li}_{k+1}\left(\frac12\right)$$
$$\Longrightarrow\int_0^1\frac{\ln^3(1+x)}{x}\ dx=-6\operatorname{Li_4}\left(\frac12\right)+6\zeta(4)-\frac{21}{4}\ln2\zeta(3)+\frac32\ln^22\zeta(2)-\frac{1}{4}\ln^42$$
Therefore
$$Z=2\operatorname{Li_4}\left(\frac12\right)-\frac58\zeta(4)+\frac{7}{4}\ln2\zeta(3)-\frac12\ln^22\zeta(2)+\frac{1}{12}\ln^42\tag4$$
Plug $(3)$ and $(4)$ in $(2)$ we get
$$2P-Q=-8\operatorname{Li_4}\left(\frac12\right)+\frac92\zeta(4)-\ln^22\zeta(2)-\frac{1}{3}\ln^42\tag5$$
Now solve $(1)$ and $(5)$ as a system of equations,
$$P=\frac{11}{4}\zeta(4)-\frac14\ln^42-6\operatorname{Li}_4\left(\frac12\right)$$
$$Q=\zeta(4)+\ln^22\zeta(2)-\frac16\ln^42-4\operatorname{Li}_4\left(\frac12\right)$$
Ali Shadhar
  • 25,498
A fancy way of calculating the integral
Here is a fancy way proposed by Cornel (it's pretty amazing for the mathematical connections involved). Let's briefly start with recalling and using Dilogarithm reflection formula, $$\operatorname{Li}_2(x)+\operatorname{Li}_2(1-x)=\zeta(2)-\log(x)\log(1-x),$$ where if we multiply both sides by $\displaystyle\frac{\log(1-x)}{1+x}$ and then consider to integrate from $x=0$ to $x=1$, we may express our integral as follows $$\int_0^1\frac{\log(x)\log^2(1-x)}{1+x}\textrm{d}x$$ $$=\zeta(2)\underbrace{\int_0^1\frac{\log(1-x)}{1+x}\textrm{d}x}_{\displaystyle \text{Trivial}}-\underbrace{\int_0^1\frac{\log(1-x)\operatorname{Li}_2(x)}{1+x}\textrm{d}x}_{\displaystyle I}-\underbrace{\int_0^1\frac{\log(1-x)\operatorname{Li}_2(1-x)}{1+x}\textrm{d}x}_{\displaystyle J}.$$ Let the party begin ...
By Landen's Identity, the integral $I$ may be connected to the integral $$\int_0^1 \frac{\displaystyle \log(1-x)\operatorname{Li}_2\left(\frac{x}{x-1}\right)}{1+x} \textrm{d}x=\frac{29}{16} \zeta (4)+\frac{1}{4}\log ^2(2) \zeta (2) -\frac{1}{8} \log ^4(2),$$ which appears in (Almost) Impossible Integrals, Sums, and Serie, page $17$, with a nice solution, and therefore we immediately obtain the desired value of $I$. A different solution than the one presented in the book may be found here.
The last integral (the integral $J$) is also a very pleasant and unexpected game! The magic will happen by letting the variable change $x\mapsto 1-x$, and then connecting the form of the integral to the generalization $$ \int_0^1 \frac{\log (x)\operatorname{Li}_2(x) }{1-a x} \textrm{d}x=\frac{(\operatorname{Li}_2(a))^2}{2 a}+3\frac{\operatorname{Li}_4(a)}{a}-2\zeta(2)\frac{\operatorname{Li}_2(a)}{a},$$ which is given in the article A simple idea to calculate a class of polylogarithmic integrals by using the Cauchy product of squared Polylogarithm function by C. I. Valean, and the solution is straightforward if we expand the integral in series and then use the Cauchy product of $(\operatorname{Li_2}(x))^2$. In other words, we have that $$J=\int_0^1\frac{\log(1-x)\operatorname{Li}_2(1-x)}{1+x}\textrm{d}x=\frac{1}{2}\int_0^1\frac{\log(x)\operatorname{Li}_2(x)}{1-x/2}\textrm{d}x$$ $$=\frac{1}{2}\left(\frac{(\operatorname{Li}_2(a))^2}{2 a}+3\frac{\operatorname{Li}_4(a)}{a}-2\zeta(2)\frac{\operatorname{Li}_2(a)}{a}\right) \biggr|_{a=1/2}.$$ End of party (story)
An important note: the necessity of calculating advanced alternating harmonic series or advanced harmonic series with powers of $2$ in the denominator is completely removed by the actual procedure. In fact, by carefully checking the development of the solution to the integral $\int_0^1 \frac{\log(1-x)\operatorname{Li}_2\left(\frac{x}{x-1}\right)}{1+x} \textrm{d}x$ in the book (Almost) Impossible Integrals, Sums, and Series, one may observe that reaching the point with harmonic series may be completely avoided if necessary and the calculation can be accomplished with the use of integrals only (to be clearer, I'm talking about the famous Au-Yeung series).
user97357329
  • 5,319
  • @AliShather Thanks. I left a link above for an alternative way to $$\int_0^1 \frac{\displaystyle \log(1-x)\operatorname{Li}_2\left(\frac{x}{x-1}\right)}{1+x} \textrm{d}x.$$ If you refer strictly to $I$, it's a challenge to find something elegant. – user97357329 Feb 01 '20 at 05:14
Integrate as follows \begin{align} I=&\int_0^1 \frac{\ln x\ln^2(1-x)}{1+x}dx\\ = &\int_0^1 \frac{\ln^2 x\ln(1-x)}{2-x}dx = \int_0^1 \ln(1-x)\> d\left( \int_1^x \frac{\ln^2 t}{2-t}dt\right) \\ =& \int_0^1 \frac1{1-x}\left( \int_0^x \frac{\ln^2 t}{2-t}\overset{t=xy}{dt}- \int_0^1 \frac{\ln^2 t}{2-t}dt \right) dx\\ =& \int_0^1 \left( \int_0^1 \frac{\ln^2 (xy)}{2-y} \left( \frac1{1-x}-\frac2{2-xy}\right){dy}- \frac1{1-x}\int_0^1 \frac{\ln^2 t}{2-t}dt \right) dx\\ =& \int_0^1 \int_0^1 \frac{\ln^2 x+2\ln x\ln y}{(1-x)(2-y)} dydx - \int_0^1 \int_0^1 \frac{2\ln^2(xy)}{(2-y)(2-xy)} \overset{t=xy}{dx}dy\\ =& \> 2\ln2 Li_3(1)+2Li_2(1)Li_2(\frac12) + \int_0^1 \overset{ibp}d\left(\ln \frac y{2-y}\right)\int_0^y\frac{\ln^2t}{2-t}dt\\ =& \>2\ln2 Li_3(1)+2Li_2(1)Li_2(\frac12)-6Li_4(\frac12)-K\tag1 \end{align} where \begin{align} K=&\int_0^1 \frac{\ln^2x \ln (2-x)}{2-x}dx\\ = &\>\ln2 \int_0^1 \frac{\ln^2x}{2-x}dx + \int_0^1 \frac{\ln^2x \ln\frac{2-x}2}{2-x} \overset{x\to 2x}{dx}\\ =&\>2\ln2Li_3(\frac12)+\ln2 \int_0^{\frac12} \frac{\ln(2x^2)\ln(1-x)}{1-x}\overset{ibp}{dx} + \int_0^{\frac12} \frac{\ln^2x\ln(1-x)}{1-x}dx\\ =&\>2\ln2Li_3(\frac12)+\ln2 \left( \frac12\ln^32 +\int_0^{\frac12} \frac{\ln^2(1-x)}{x}dx\right) -\frac14\ln^42+ \frac12J\\ =& \>2\ln2Li_3(1)-2\ln^22Li_2(\frac12)-\frac34\ln^42+\frac12J\tag2\\ \\ J=&\int_0^1 \frac{\ln^2x \ln (1-x)}{1-x}dx\\ = &\int_0^1 \frac{\ln^2x}{1-x}\left(\int_0^1 \frac {-x}{1-x y}dy\right) dx =\int_0^1 \frac{1}{1-y}\left(\int_0^1 \frac {\ln^2x}{1-yx}dx - 2Li_3(1)\right) dy \\ =& \>2 \int_0^1\frac{Li_3(y)}{y}dy + 2 \int_0^1\frac{Li_3(y)-Li_3(1)}{1-y}\>\overset{ibp}{dy} = 2Li_4(1) - Li_2^2(1) \end{align} Plug the result for $J$ into (2) and then $K$ into (1) to obtain \begin{align} I= &-6Li_4(\frac12) -Li_4(1)+2(Li_2(1)+\ln^22)Li_2(\frac12)+\frac12Li_2^2(1)+\frac34\ln^42\\ =& -6Li_4(\frac12)+\frac{11\pi^4}{360}-\frac14\ln^42 \end{align}
Quanto
  • 97,352
This does indeed have a closed form. I have to go to work now, but I will be back later unless someone else gets around to it first.
You are aiming for $$\displaystyle \zeta(4)+\zeta(2)\ln^{2}(2)-1/6\ln^{4}(2)-4Li_{4}(1/2)$$
Perhaps begin with the representation:
$$\frac{\psi(k+1/2)-\psi(1/2)}{(2k+1)^{3}}=1/2\int_{0}^{\infty}t^{2}e^{-(2k+1)t}dt\int_{0}^{1}\frac{(1-u^{k})u^{-1/2}}{1-u}du$$
Or, expand $\displaystyle \frac{\ln(1-x)}{1+x}$ in a power series:
$$\frac{\ln(1-x)}{1+x}=\sum_{k=1}^{\infty}\left[(-1)^{k}\ln(2)-(\psi(k/2+1)-\psi(k+1)+\ln(2))\right]x^{k}$$
multiply by $\displaystyle \ln^{2}(x)$, then integrate. The resulting series will be in terms of digamma sums.
It leads to: $$2\ln(2)\sum_{k=1}^{\infty}\frac{(-1)^{k}}{(k+1)^{3}}-2\sum_{k=1}^{\infty}\frac{\psi(k/2+1)}{(k+1)^{3}}+2\sum_{k=1}^{\infty}\frac{\psi(k+1)}{(k+1)^{3}}-2\ln(2)\sum_{k=1}^{\infty}\frac{1}{(k+1)^{3}}$$
Of course, the two sums without digamma are simply zeta series:
$$2\ln(2)\sum_{k=1}^{\infty}\frac{1}{(k+1)^{3}}=2\ln(2)(\zeta(3)-1)$$
$$2\ln(2)\sum_{k=1}^{\infty}\frac{(-1)^{k}}{(k+1)^{3}}=2\ln(2)(3/4\zeta(3)-1)$$
and using the known:
$$\sum_{k=1}^{\infty}\frac{\psi(k+1)}{(k+1)^{3}}=\frac{\pi^{4}}{360}-\gamma\zeta(3)+\gamma$$.
and
$$\sum_{k=1}^{\infty}\frac{\psi(k/2+1)}{(k+1)^{3}}=\frac{-\pi^{4}}{360}-\gamma\zeta(3)+\gamma-1/4\ln(2)\zeta(3)-\frac{\pi^{2}}{12}\ln^{2}(2)+1/12\ln^{4}(2)+2Li_{4}(1/2)$$.
Putting these pieces together gives the required result.
Let $I$ denote the integral in the question. Then we can write
\begin{align*} I &= \int_0^1\frac{\log^2 (x) \log(1-x^2)-\log^2(x)\log(1+x)}{1+x}dx \\ &= \int_0^1\frac{\log^2 (x) \log(1-x^2)}{1+x}dx-\int_0^1 \frac{\log^2(x)\log(1+x)}{1+x}dx \quad \cdots (1) \end{align*}
The first integral can be manipulated as follows:
\begin{align*} \int_0^1\frac{\log^2 (x) \log(1-x^2)}{1+x}dx &= \frac{1}{8}\int_0^1 \frac{\log^2(x) \log(1-x)}{(1+\sqrt{x})\sqrt{x}}dx \\ &= \frac{1}{8} \left( \int_0^1 \frac{\log^2(x)\log(1-x)}{(1-x)\sqrt{x}}dx-\int_0^1 \frac{\log^2(x)\log(1-x)}{1-x}dx\right) \end{align*}
Calculation of these two integrals is done by differentiating the beta function. The end result is
$$\displaystyle \int_0^1\frac{\log^2 (x) \log(1-x^2)}{1+x}dx = \frac{7}{2} \zeta (3) \log (2)-\frac{11 \pi ^4}{360} \quad ... (2)$$
Now we turn our attention to the second integral of equation (1): \begin{align*} \int_0^1 \frac{\log^2(x)\log(1+x)}{1+x}dx &= \sum_{n=1}^\infty (-1)^{n+1} H_n \int_0^1 x^n \log^2(x)\; dx \\ &= 2 \sum_{n=1}^\infty \frac{(-1)^{n+1}H_n}{(n+1)^3} \\ &= 4 \text{Li}_4\left(\frac{1}{2}\right)+\frac{7}{2} \zeta (3) \log (2)-\frac{\pi ^4}{24}+\frac{\log ^4(2)}{6}-\frac{1}{6} \pi ^2 \log ^2(2) \quad ...(3) \end{align*}
Substitute everything in equation (1) to get
$$\displaystyle I=\boxed{\displaystyle -4 \text{Li}_4\left(\frac{1}{2}\right)+\frac{\pi ^4}{90}-\frac{\log ^4(2)}{6}+\frac{1}{6} \pi ^2 \log ^2(2)}$$
Martin.s
  • 22
we start with the following result: $$\sum\limits_{n = 1}^\infty {\frac{1}{{{n^3}}}} \left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right) = \frac{7}{4}\zeta \left( 3 \right)\ln 2 - \frac{{{\pi ^4}}}{{288}}$$ which can be found in the paper "Euler Sums and Contour Integral Representations",written by Philippe Flajolet and Bruno Salvy,then we can get the value of this integral after expanding it into a series: $$\int\limits_0^1 {\frac{{\ln \left( {1 + x} \right){{\ln }^2}x}}{{1 - x}}dx} = 2\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{n}\left( {\sum\limits_{k = n + 1}^\infty {\frac{1}{{{k^3}}}} } \right)}$$ by Bailey's Transform,it is $$= 2\sum\limits_{n = 1}^\infty {\frac{1}{{{n^3}}}} \sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} - 2\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^3}}}} = - \frac{{19{\pi ^4}}}{{720}} + \frac{7}{2}\zeta \left( 3 \right)\ln 2$$....................$(1)$ and,we have to caculate another one: $$\int\limits_0^1 {\frac{{\ln \left( {1 + x} \right)\ln \left( {1 - x} \right)\ln x}}{x}dx} = - \frac{{3{\pi ^4}}}{{160}} - \frac{{{\pi ^2}}}{{12}}{\ln ^2}2 + \frac{{{{\ln }^4}2}}{{12}} + 2L{i_4}\left( {\frac{1}{2}} \right) + \frac{7}{4}\zeta \left( 3 \right)\ln 2$$....................$(2)$ which comes from $$\frac{1}{4}\int\limits_0^1 {\frac{{{{\ln }^2}\left( {1 - x} \right)\ln x}}{x}dx} = \int\limits_0^1 {\frac{{{{\ln }^2}\left( {1 - x} \right)\ln x}}{x}dx} + \int\limits_0^1 {\frac{{{{\ln }^2}\left( {1 + x} \right)\ln x}}{x}dx} + 2\int\limits_0^1 {\frac{{\ln \left( {1 + x} \right)\ln \left( {1 - x} \right)\ln x}}{x}dx}$$ and $$\int\limits_1^\infty {\frac{{{{\ln }^3}\left( {1 + x} \right) - {{\ln }^3}x}}{x}dx} = \int\limits_0^1 {\frac{{{{\ln }^3}\left( {1 + x} \right) - 3{{\ln }^2}\left( {1 + x} \right)\ln x + 3\ln \left( {1 + x} \right){{\ln }^2}x}}{x}dx}$$, now,with some replacements of variables and using the definition of polylogarithm function,it turns true,anyone who is intrested can make up the details. now,back to the question above, integrate $$\int\limits_0^1 {\frac{{\ln \left( {1 + x} \right){{\ln }^2}x}}{{1 - x}}dx}$$ by parts,we get $$\int\limits_0^1 {\frac{{\ln \left( {1 - x} \right){{\ln }^2}x}}{{1 + x}}} dx = \zeta \left( 4 \right) + \zeta \left( 2 \right){\ln ^2}2 - \frac{{{{\ln }^4}2}}{6} - 4L{i_4}\left( {\frac{1}{2}} \right)$$
Martin.s
  • 22
there are many of this kind associated with EulerSums or Alernating EulerSums,they can be proved by combination of the methods of Contour integration、skills of Translating integrals into series or Translating series into integrals、 bailey transform and something else, I'd like to share some with you. $(1)$. $$\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^3}}}\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)} = \frac{{{\pi ^4}}}{{60}} + \frac{{{\pi ^2}}}{{12}}{\ln ^2}2 - \frac{1}{{12}}{\ln ^4}2 - 2L{i_4}\left( {\frac{1}{2}} \right)$$
$(2)$.$$\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{{{k^2}}}} } \right)} = - \frac{{17{\pi ^4}}}{{480}} - \frac{{{\pi ^2}}}{6}{\ln ^2}2 + \frac{1}{6}{\ln ^4}2 + 4L{i_4}\left( {\frac{1}{2}} \right) + \frac{7}{2}\zeta \left( 3 \right)\ln 2$$
$(3)$.$${\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)} ^2} = - \frac{{61{\pi ^4}}}{{1440}} + \frac{{{\pi ^2}}}{3}{\ln ^2}2 + \frac{1}{6}{\ln ^4}2 + 4L{i_4}\left( {\frac{1}{2}} \right) + \frac{7}{4}\zeta \left( 3 \right)\ln 2$$
$(4)$.$$\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)} = \frac{{29{\pi ^4}}}{{1440}} + \frac{{{\pi ^2}}}{8}{\ln ^2}2 - \frac{1}{8}{\ln ^4}2 - 3L{i_4}\left( {\frac{1}{2}} \right)$$
$(5)$.$$\int\limits_0^1 {\frac{{{{\ln }^2}\left( {1 - x} \right)\ln \left( {1 + x} \right)}}{x}} dx = - \frac{{{\pi ^4}}}{{144}} - \frac{{{\pi ^2}}}{{12}}{\ln ^2}2 + \frac{1}{{12}}{\ln ^4}2 + 2L{i_4}\left( {\frac{1}{2}} \right) + \frac{7}{4}\zeta \left( 3 \right)\ln 2$$
$(6)$.$$\int\limits_0^1 {\frac{{{{\ln }^2}\left( {1 + x} \right)\ln \left( {1 - x} \right)}}{x}} dx = - \frac{{{\pi ^4}}}{{240}}$$
$$(7)$.let $I = \int\limits_0^1 {\frac{{\ln x{{\ln }^2}\left( {1 + x} \right)\ln \left( {1 - x} \right)}}{x}} dx$ and $J = \int\limits_0^1 {\frac{{\ln x{{\ln }^2}\left( {1 - x} \right)\ln \left( {1 + x} \right)}}{x}} dx$$,then $$I = \frac{7}{{48}}{\pi ^2}\zeta \left( 3 \right) - \frac{{25}}{{16}}\zeta \left( 5 \right)$$ $$J = - \frac{1}{9}{\pi ^2}{\ln ^3}2 + \frac{2}{{15}}{\ln ^5}2 + 4L{i_4}\left( {\frac{1}{2}} \right)\ln 2 + 4L{i_5}\left( {\frac{1}{2}} \right) - \frac{1}{{16}}{\pi ^2}\zeta \left( 3 \right) + \frac{7}{4}\zeta \left( 3 \right){\ln ^2}2 - \frac{7}{2}\zeta \left( 5 \right)$$ proof(brief,detailed proof is very long): notice the fact $$\int\limits_1^\infty {\frac{{{{\ln }^4}\left( {1 + x} \right) - {{\ln }^4}x}}{x}} dx = \int\limits_0^1 {\frac{{{{\ln }^4}\left( {1 + x} \right)}}{x}} dx - 4\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 + x} \right)}}{x}} dx + 6\int\limits_0^1 {\frac{{{{\ln }^2}x{{\ln }^2}\left( {1 + x} \right)}}{x}} dx - 4\int\limits_0^1 {\frac{{{{\ln }^3}x\ln \left( {1 + x} \right)}}{x}} dx$$, the left integral,and the 1st、4th integral of right side are esay to be caculated.and the 3rd integral can be translated into series,the hard term of which is $$\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^4}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)}$$ and has been studied in "Euler Sums and Contour Integral Representations",therefore,we finally get $$\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 + x} \right)}}{x}} dx = \frac{1}{3}{\pi ^2}{\ln ^3}2 - \frac{2}{5}{\ln ^5}2 - 12L{i_4}\left( {\frac{1}{2}} \right)\ln 2 - 12L{i_5}\left( {\frac{1}{2}} \right) + \frac{1}{2}{\pi ^2}\zeta \left( 3 \right) - \frac{{21}}{4}\zeta \left( 3 \right){\ln ^2}2 + \frac{{99}}{{16}}\zeta \left( 5 \right)$$...............$(1)$ on the other hand,we consider $$\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 - x} \right)}}{x}} dx - 3\int\limits_0^1 {\frac{{\ln x{{\ln }^2}\left( {1 - x} \right)\ln \left( {1 + x} \right)}}{x}} dx + 3\int\limits_0^1 {\frac{{\ln x{{\ln }^2}\left( {1 + x} \right)\ln \left( {1 - x} \right)}}{x}} dx - \int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 + x} \right)}}{x}} dx$$ $$ = \int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {\frac{{1 - x}}{{1 + x}}} \right)}}{x}} dx$$ $$ = 2\int\limits_0^1 {\frac{{\ln \left( {1 - x} \right){{\ln }^3}x}}{{1 - {x^2}}}} dx - 2\int\limits_0^1 {\frac{{\ln \left( {1 + x} \right){{\ln }^3}x}}{{1 - {x^2}}}} dx$$ $$ = \int\limits_0^1 {\frac{{\ln \left( {1 - x} \right){{\ln }^3}x}}{{1 - x}}} dx + \int\limits_0^1 {\frac{{\ln \left( {1 - x} \right){{\ln }^3}x}}{{1 + x}}} dx - \int\limits_0^1 {\frac{{\ln \left( {1 + x} \right){{\ln }^3}x}}{{1 - x}}} dx - \int\limits_0^1 {\frac{{\ln \left( {1 + x} \right){{\ln }^3}x}}{{1 + x}}} dx$$ the 1st、4th integrals are easy to be worked out,and all integrals of right side can be translated into EulerSums,the results of which have been gotten in "Euler Sums and Contour Integral Representations",so we arrive at $$3I - 3J = \frac{1}{3}{\pi ^2}{\ln ^3}2 - \frac{2}{5}{\ln ^5}2 - 12L{i_4}\left( {\frac{1}{2}} \right)\ln 2 - 12L{i_5}\left( {\frac{1}{2}} \right) + \frac{5}{8}{\pi ^2}\zeta \left( 3 \right) - \frac{{21}}{4}\zeta \left( 3 \right){\ln ^2}2 + \frac{{93}}{{16}}\zeta \left( 5 \right)$$...............$(2)$ another relation comes from $$\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 - x} \right)}}{x}} dx = 4\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 - {x^2}} \right)}}{x}} dx = 4\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 - x} \right)}}{x}} dx + 4\int\limits_0^1 {\frac{{\ln x{{\ln }^3}\left( {1 + x} \right)}}{x}} dx + 12\int\limits_0^1 {\frac{{\ln x{{\ln }^2}\left( {1 - x} \right)\ln \left( {1 + x} \right)}}{x}} dx + 12\int\limits_0^1 {\frac{{\ln x{{\ln }^2}\left( {1 + x} \right)\ln \left( {1 - x} \right)}}{x}} dx$$ with $(1)$, after simplified,the above is $$12I + 12J = - \frac{4}{3}{\pi ^2}{\ln ^3}2 + \frac{8}{5}{\ln ^5}2 + 48L{i_4}\left( {\frac{1}{2}} \right)\ln 2 + 48L{i_5}\left( {\frac{1}{2}} \right) + {\pi ^2}\zeta \left( 3 \right) + 21\zeta \left( 3 \right){\ln ^2}2 - \frac{{243}}{4}\zeta \left( 5 \right)$$...............$(3)$ from $(2)$$(3)$,we get I、J. $(8)$.let$$x = \sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^3}}}{{\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)}^2}}$$,$$y = \sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{1}{{{k^2}}}} } \right)}$$,$$z = \sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{{{k^2}}}} } \right)}$$,$$w = \sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^3}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)}$$,then $$x = - \frac{1}{9}{\pi ^2}{\ln ^3}2 + \frac{2}{{15}}{\ln ^5}2 + 4L{i_4}\left( {\frac{1}{2}} \right)\ln 2 + 4L{i_5}\left( {\frac{1}{2}} \right) - \frac{{11}}{{48}}{\pi ^2}\zeta \left( 3 \right) + \frac{7}{2}\zeta \left( 3 \right){\ln ^2}2 - \frac{{19}}{{32}}\zeta \left( 5 \right)$$ $$y = \frac{1}{9}{\pi ^2}{\ln ^3}2 - \frac{2}{{15}}{\ln ^5}2 - 4L{i_4}\left( {\frac{1}{2}} \right)\ln 2 - 4L{i_5}\left( {\frac{1}{2}} \right) + \frac{5}{{32}}{\pi ^2}\zeta \left( 3 \right) - \frac{7}{4}\zeta \left( 3 \right){\ln ^2}2 + \frac{{23}}{8}\zeta \left( 5 \right)$ $z = - \frac{{13}}{{48}}{\pi ^2}\zeta \left( 3 \right) + \frac{{125}}{{32}}\zeta \left( 5 \right)$$ $$w = \frac{2}{{45}}{\pi ^4}\ln 2 + \frac{1}{{36}}{\pi ^2}{\ln ^3}2 - \frac{1}{{60}}{\ln ^5}2 + 2L{i_5}\left( {\frac{1}{2}} \right) - \frac{1}{{48}}{\pi ^2}\zeta \left( 3 \right) - \frac{7}{8}\zeta \left( 3 \right){\ln ^2}2 - \frac{{37}}{{16}}\zeta \left( 5 \right)$$ brief proof: we transform the integrals of I、J of $(7)$ into series of EulerSums: $$x + y = - \frac{7}{{96}}{\pi ^2}\zeta \left( 3 \right) + \frac{{73}}{{32}}\zeta \left( 5 \right)$$...................$(1)$ $$z + w = \frac{2}{{45}}{\pi ^4}\ln 2 + \frac{1}{{36}}{\pi ^2}{\ln ^3}2 - \frac{1}{{60}}{\ln ^5}2 + 2L{i_5}\left( {\frac{1}{2}} \right) - \frac{7}{{24}}{\pi ^2}\zeta \left( 3 \right) - \frac{7}{8}\zeta \left( 3 \right){\ln ^2}2 + \frac{{51}}{{32}}\zeta \left( 5 \right)$$...............$(2)$ and we consider two contour integrals $$\int_C {\frac{1}{{{z^2}}}} {\mathop \psi \limits^{\_\_} ^{(1)}}\left( z \right){\left( {\psi \left( z \right) + \gamma } \right)^2}dz$,$\int_C {\frac{1}{{{z^3}}}} \mathop \psi \limits^{\_\_} \left( z \right){\left( {\psi \left( z \right) + \gamma } \right)^2}dz$$ where $$\psi \left( z \right) + \gamma = \frac{d}{{dz}}\ln \Gamma \left( z \right) = - \frac{1}{z} + \sum\limits_{n = 1}^\infty {\left( {\frac{1}{n} - \frac{1}{{n + z}}} \right)}$$,$$\mathop \psi \limits^{\_\_} \left( z \right) = \frac{1}{2}\psi \left( {\frac{{z + 1}}{2}} \right) - \frac{1}{2}\psi \left( {\frac{z}{2}} \right)$,${\mathop \psi \limits^{\_\_} ^{(1)}}\left( z \right) = \frac{d}{{dz}}\mathop \psi \limits^{\_\_} \left( z \right)$$,just same as the the authors did in the paper " Euler Sums and Contour Integral Representations", we get $$x + y + z = - \frac{{11}}{{32}}{\pi ^2}\zeta \left( 3 \right) + \frac{{99}}{{16}}\zeta \left( 5 \right)$$...............$(3)$ $$x - 2w = - \frac{4}{{45}}{\pi ^4}\ln 2 - \frac{1}{6}{\pi ^2}{\ln ^3}2 + \frac{1}{6}{\ln ^5}2 + 4L{i_4}\left( {\frac{1}{2}} \right)\ln 2 - \frac{3}{{16}}{\pi ^2}\zeta \left( 3 \right) + \frac{7}{2}\zeta \left( 3 \right){\ln ^2}2 + \frac{{129}}{{32}}\zeta \left( 5 \right)$$...............$(4)$ solve equations $(1)$,$(2)$,$(3)$,$(4)$,we complete the proof. $(9)$.here are some other EluerSums,on the base of above results,they can be proved. $$\int\limits_0^1 {\frac{{\ln \left( {1 + x} \right)\ln \left( {1 - x} \right)}}{x}} L{i_2}\left( { - x} \right)dx = \frac{1}{9}{\pi ^2}{\ln ^3}2 - \frac{2}{{15}}{\ln ^5}2 - 4L{i_4}\left( {\frac{1}{2}} \right)\ln 2 - 4L{i_5}\left( {\frac{1}{2}} \right) + \frac{5}{{96}}{\pi ^2}\zeta \left( 3 \right) - \frac{7}{4}\zeta \left( 3 \right){\ln ^2}2 + \frac{{123}}{{32}}\zeta \left( 5 \right)$$ $$\sum\limits_{n = 1}^\infty {\frac{1}{{{n^3}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)} = \frac{2}{{45}}{\pi ^4}\ln 2 + \frac{1}{{36}}{\pi ^2}{\ln ^3}2 - \frac{1}{{60}}{\ln ^5}2 + 2L{i_5}\left( {\frac{1}{2}} \right) + \frac{1}{{16}}{\pi ^2}\zeta \left( 3 \right) - \frac{7}{8}\zeta \left( 3 \right){\ln ^2}2 - \frac{{193}}{{64}}\zeta \left( 5 \right)$$ $$\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}{{\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)}^3}} = - \frac{1}{6}{\pi ^2}{\ln ^3}2 + \frac{1}{5}{\ln ^5}2 + 6L{i_4}\left( {\frac{1}{2}} \right)\ln 2 + 6L{i_5}\left( {\frac{1}{2}} \right) - \frac{9}{{32}}{\pi ^2}\zeta \left( 3 \right) + \frac{{21}}{8}\zeta \left( 3 \right){\ln ^2}2 - \frac{9}{4}\zeta \left( 5 \right)$$ $$\sum\limits_{n = 1}^\infty {\frac{1}{{{n^2}}}{{\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)}^3}} = - \frac{{29}}{{160}}{\pi ^4}\ln 2 + \frac{{11}}{{12}}{\pi ^2}{\ln ^3}2 - \frac{1}{{20}}{\ln ^5}2 - 6L{i_4}\left( {\frac{1}{2}} \right)\ln 2 - 24L{i_5}\left( {\frac{1}{2}} \right) + \frac{1}{{12}}{\pi ^2}\zeta \left( 3 \right) + \frac{{367}}{{16}}\zeta \left( 5 \right)$$ $$\sum\limits_{n = 1}^\infty {\frac{{{{\left( { - 1} \right)}^{n - 1}}}}{{{n^2}}}\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{{{{\left( { - 1} \right)}^{k - 1}}}}{{{k^2}}}} } \right)} = \frac{{49}}{{720}}{\pi ^4}\ln 2 - \frac{1}{{18}}{\pi ^2}{\ln ^3}2 + \frac{1}{{10}}{\ln ^5}2 + 4L{i_4}\left( {\frac{1}{2}} \right)\ln 2 + 8L{i_5}\left( {\frac{1}{2}} \right) + \frac{1}{{96}}{\pi ^2}\zeta \left( 3 \right) - \frac{{35}}{4}\zeta \left( 5 \right)$$ $$(10)$.$\sum\limits_{n = 1}^\infty {\frac{1}{{{n^3}}}\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)\left( {\sum\limits_{k = 1}^n {\frac{1}{{{k^2}}}} } \right)} = - \frac{{101}}{{45360}}{\pi ^6} + \frac{5}{2}{\zeta ^2}\left( 3 \right)$$ $$\sum\limits_{n = 1}^\infty {\frac{1}{{{n^3}}}{{\left( {\sum\limits_{k = 1}^n {\frac{1}{k}} } \right)}^3} = } \frac{{31}}{{5040}}{\pi ^6} - \frac{5}{2}{\zeta ^2}\left( 3 \right)$$
Martin.s
  • 22
