Similar questions --- without the requirement that $e^A,e^B\in SO(n)$ --- have been asked multiple times on this site before. See If $e^A$ and $e^B$ commute, do $A$ and $B$ commute? for instance.
The answer is still "no" even if you require that $A,B$ are skew-symmetric and $e^A,e^B\in SO(n,\mathbb R)$ when $n\ge3$. Consider
A=\pmatrix{0&-2\pi&0\\ 2\pi&0&0\\ 0&0&0},\ B=\pmatrix{0&0&0\\ 0&0&-2\pi\\ 0&2\pi&0}.
Then $e^A$ commutes with $e^B$ because both matrix exponentials are equal to $I_3$, but
AB-BA=\pmatrix{0&0&4\pi^2\\ 0&0&0\\ -4\pi^2&0&0}\ne0
and the eigenvalues of $A+B$ are $0$ and $\pm\sqrt{8}\pi i$, so that $e^{A+B}$ is similar to $\operatorname{diag}(1,e^{\sqrt{8}\pi i},e^{-\sqrt{8}\pi i})$ and it cannot possibly be equal to $e^Ae^B=I_3$.
However, in a "generic" case, the answer to your question is "yes". More specifically, if the spectra of $A$ and $B$ are $2\pi i$-congruence free (this assumption does not hold in the counterexample above), then $e^A$ commutes with $e^B$ if and only if $A$ and $B$ commute. Therefore, we also have $e^{A+B}=e^Ae^B$ in this case. See Is $\exp:\overline{\mathbb{M}}_n\to\mathbb{M}_n$ injective? (and loup blanc's answer in particular) for more details.
When $n=2$ and $A,B$ are skew-symmetric, the answer is certainly yes because all skew-symmetric matrices commute in this case.
