Further to this question, A hard Cubic Diophantine equation I considered the more general equation $N=x^3+y^3+z^3-2xyz$.
As $x^3+y^3+z^3-2xyz$ is homogenous, any solution $(N_0,x_0,y_0,z_0)$ to $x^3+y^3+z^3-2xyz=N$ gives a set of solutions $(k^3N_0,kx_0,ky_0,kz_0)$.
In particular, any solution with positive $N$ gives a solution for $-N$ using $k=-1$, so it’s not necessary to further consider negative $N$
For example, $(N,x,y,z)=(13,-3,2,2)$ gives $(-13,3,-2,-2)$
Clearly, $(x,y,z)$ are interchangeable.
Using a small search up to $N=152$ I’ve found, with $a,b,k$ integer, just
$$(N,x,y,z)=(0,-a,0,a)$$
$$(N,x,y,z)=(19k^3,(-b-1)k,3k,(b-1)k)$$
Examples as $(N,x,y,z)$
$$(0,-45,0,45)$$ $$(19,-6,3,4)$$ $$(152,-12,6,8)$$
I’ve noticed other $N$ that seem possible candidates, but haven’t spotted the patterns. For example,
$$(9,-1575,583,1163)$$ $$(9,-944,522,545)$$ $$(9,-703,-198,838)$$ $$(9,-323,-187,457)$$ $$(9,-167,80,108)$$ $$(9,-162,86,97)$$ $$(9,-47,-34,72)$$ $$(9,-7,4,4)$$ $$(9,-2,1,2)$$ $$(9,0,1,2)$$ $$(9,1,2,2)$$
Other $N$ values that look interesting are $6,17,33,37,48,51,72,93,96,107,114,117,136$
My question:
Apart from $0$ and numbers of the form $19k^3$, for what $N$ does $N=x^3+y^3+z^3-2xyz$ have infinite integer solutions?
Update 5th March 2018
I’m also interested in:
values of $N$ where all solutions are known
values of $N$ where it can be shown that there are a finite number of solutions
values of $N$ where it can be shown that there no solutions.
Old Peter
  • 1,357
  • The equation $x^3+y^3+z^3-2xyz=9$ curiously has a lot of integer solutions. What were the search bounds used? – Tito Piezas III Mar 06 '18 at 13:00
  • @TitoPiezasIII I looked in the range $-3000$ to $3000$. The other $N$ I note as interesting are much the same. Up to $N=152$, without counting them all, $117$ perhaps has the most with $21$ solutions. Please let me know if you wish me to include these, or other, results within my question. – Old Peter Mar 06 '18 at 15:28
  • The case $N=9$ will do for now. The situation is reminiscent to the problem $x^3+y^3+z^3 =N$ where some (like $N=792$) have many integer solutions, but is not known if there is infinitely many. – Tito Piezas III Mar 06 '18 at 16:01
  • I think the general equation is $x^3+y^3+z^3+Mxyz = N$ where my post is $M=0$ while yours is $M=-2$. It seems general results are not yet known. – Tito Piezas III Mar 06 '18 at 16:04
  • Do you still have the data for $N=117 = 9\times13$? Can you include it (not necessarily in Latex form) in the post? We might now know better how to spot a pattern, if any. – Tito Piezas III Jan 10 '24 at 10:17
  • No pattern yet? Perhaps just post the results here. Maybe the community can find something. – Tito Piezas III Jan 18 '24 at 16:00
  • @Tito Piezas III some results shown as a answer. Sorry for the delay, – Old Peter Jan 19 '24 at 19:25
  • Hmm, with 20 solutions for $N = 117$, I assumed there would be a pattern but it is harder to ascertain than I thought. – Tito Piezas III Jan 20 '24 at 12:00
  • @Tito Piezas III I’ve found the last solution in the previously used range. If you want further solutions, I need info to speed up the search. Can you see any way to express one variable in terms of the other two? Perhaps range restristions of $y,z$ given $x$? – Old Peter Jan 20 '24 at 19:02
  • I tried to find one variable in terms of the other two, like what Bailey and I did for $x^3+y^3+z^3 = (z+1)^3$, but the proper substitution eludes me for now. – Tito Piezas III Jan 21 '24 at 03:08
Regarding the above equation shown below:
Seiji Tomita has given an identity on his web site:
http://www.maroon.dti.ne.jp/fermat
Click on the link "Computational number theory" & then select article #264.
His identity is $x^3+y^3+z^3-n(xyz)=(n^3-27)$
where $(x,y,z)=(m,n-m,-3)$
For $n=2$ we have,
$(-m)^3+(m-2)^3+3^3-2(m)(2-m)(3)=19$
Since $m$ can take infinite values, then $N = 19$ can take on infinite integer solutions.
Sam
  • 56
Updated 20/1/24 with “$-2171$” solution. Search in range $-3000$ to $3000$
Too big for a comment
As requested, some solutions for $N=117$
I don’t have the original results, and there are unexpected and unusual problems with my 2018 program, but here some small solutions.
(x,y,z)=
(-2171,-704 ,2654),
(-1964 ,653 ,1508),
(-1404 ,173 ,1288),
(-1331 ,449 ,1017),
(-773 ,-351 ,1019),
(-878 ,-106 ,949),
(-560,173,440),
(-353,-289,569),
(-202,-107,278),
(-91,-44,122),
(-91,40,62),
(-62,-52,101),
(-59,25,41),
(-43,-36,70),
(-27 ,10 ,20 ),
(-18 ,-11 ,26 ),
(-11 ,-4 ,14 ),
(-11 ,2 ,10 ),
(-2 ,0 ,5 ),
(1 ,1 ,5 ),
(2 ,4 ,5 )
Old Peter
  • 1,357
