This question is informed by a lemma that is needed in pursuit of an ergodic theory result specifically to do with weak mixing.
We first need two definitions before we can state the proposition in question:
Upper and Lower Density: Given a set $A\subseteq \mathbb{Z}$, define it's upper density as, $$ \overline{\delta}(A) := \limsup_{n\to \infty}\frac{|A\cap \{1,2,\cdots, n\}|}{n}.$$ We define the lower density of $A$, write $\underline{\delta}(A)$, in the same way by just replacing $\limsup$ above by $\liminf$.
Density Convergence: A real valued sequence $(x_n)$ and a fixed $x\in\mathbb{R}$. The sequence is said to converge in density if for every open neighbourhood of $x$, say $V_x$, $$ \overline{\delta}\left(\{n\in \mathbb{N}: x_n \in V_x\}\right) =1. $$ We write, $$ D-\lim_{n\to\infty}x_n = x.$$
Proposition: Given a real valued sequence $(x_n)$. Then we have that, $$D-\lim_{n\to\infty}x_n >0 $$ if and only if there exists a set $S\subseteq \mathbb{N}$ with $\underline{\delta}(S)>0$ such that $x_n>0$ for all $n\in S$.
$(\impliedby)$
Assume that there is a set $S\subseteq \mathbb{N}$ with positive lower density such that $x_n>0$ for all $n\in S$. Suppose for the sake of a contradiction that $D-\lim_{n\to\infty}x_n=0$. There exists some $\epsilon>0$ such that $x_n>\epsilon>0$ for a set $S'\subseteq \mathbb{N}$ with positive lower density. By the supposition that $D-\lim_{n\to\infty}x_n=0$, we have that, $$ \overline{\delta}\left(\{n\in \mathbb{N}: x_n\in (-\epsilon, \epsilon)\}\right) =1. $$As a consequence, \begin{align*} 0 = \overline{\delta}\left(\{n\in \mathbb{N}: x_n>\epsilon \}\right)\geq \underline{\delta}(\{n\in \mathbb{N}: x_n>\epsilon \}) =\underline{\delta}(S')>0. \end{align*}Which clearly is a contradiction. It follows that $D-\lim_{n\to\infty}x_n>0$.
$(\implies)$ Assume that $D-\lim_{n\to\infty}x_n =c>0$. Fixing $\epsilon = c/2$, we know that, $$ \overline{\delta}\left(\{n\in \mathbb{N}: x_n \in (-c/2+c, c+c/2)\}\right) =1. $$ Thus, the set $\{n\in \mathbb{N}: x_n> c/2>0\}$ will also have upper density $1$.
At this point it is enough to show that any set $A\subseteq \mathbb{N}$ with upper density $1$ will necessarily have positive lower density. Although I am not sure if this is true. I am having trouble finding an alternative route.
Any suggestions are welcome, thanks in advance!
