Good morning,
I am coming from learning machine learning convolution for neural nets and was wondering about cross-correlation vs convolution.
I referenced this answer here: What's the difference between convolution and crosscorrelation?
But I fail to understand the practical difference that a mirrored 'filter' (not sure if that is the correct term in this context) produces when using convolution rather than cross-correlation. It seems that either method contains different representations of the same data. Whether (as in the link above) it is X+Y or Y-X, they both contain similar, albeit opposite, data.
Is this simply used to adjust the direction of the vector, as seemingly the magnitude would remain unchanged? Or am I missing some subtleties?
Thank you!
