Let's say I have a set of non-negative integers $a_1,..,a_n$ and a number $C$ which is a non-negative constant (an integer).
Consider an equation
$x_1\cdot a_1 + x_2\cdot a_2 + ... + x_n\cdot a_n - C = 0$
where $x_1,...,x_n$ are unknown non-negative integers. I have to say whether a solution to this equation exists, and when does it exist and when does it not exist.
I'd really appreciate anyone's help I've been struggling with this one for quite a while.
EDIT
Well so far i haven't made a good progress, i'm going to sleep and see you all in the morning.So far i got two conclusion. 1.) if the number C is not divisible by the gcd of the set than there certainly is no solution 2.)If C is divisble by gcd, If we divide all the numbers by the gcd than it becomes Frobenius coin problem.I'm now looking into upper bounds for FCP.See you all in the morning.
This problem is due in tuesday so i've got time no probs :)
– mikey Dec 05 '12 at 21:42
