I am a high school student. I was able to prove that the limit of $\sum_{k=1}^{n}\frac{1}{k}-\log n$ converges. However, I can’t prove the convergence value is greater than $\frac{1}{2}$. I tried a lot and was able to prove it is smaller than $1$. However, I can't greater than $\frac{1}{2}$.
check this out: https://en.wikipedia.org/wiki/Euler%E2%80%93Mascheroni_constant – farruhota Nov 10 '17 at 08:23
1Possible duplicate of How to show $\gamma$ aka Euler's constant is convergent? – Teddy38 Nov 10 '17 at 08:24
@farruhota I checked it out. Still, I can't prove the constant is greater than$\frac{1}{2}$. – Gymnast Nov 10 '17 at 08:27
2see the last part of this answer https://math.stackexchange.com/a/2443058/66096 – Gabriel Romon Nov 10 '17 at 09:23
@Gabriel Romon Thank you. That is actually the answer to this question. – Gymnast Nov 10 '17 at 09:40
Copied from this answer:
Note that $$ \begin{align} \frac1n-\log\left(\frac{n+1}n\right) &=\int_0^{1/n}\frac{t\,\mathrm{d}t}{1+t}\\ &\ge\int_0^{1/n}\frac{t}{1+\frac1n}\,\mathrm{d}t\\[3pt] &=\frac1{2n(n+1)} \end{align} $$ Therefore, $$ \begin{align} \gamma &=\sum_{n=1}^\infty\left(\frac1n-\log\left(\frac{n+1}n\right)\right)\\ &\ge\sum_{n=1}^\infty\frac1{2n(n+1)}\\[3pt] &=\sum_{n=1}^\infty\frac12\left(\frac1n-\frac1{n+1}\right)\\[6pt] &=\frac12 \end{align} $$
- 345,667
We can apply the Euler-MacLaurin Formula, which says that $$ \sum_{n=a}^b f(n) = \int_a^b f(x) dx + \frac{f(a)+f(b)}{2} + \sum_{k=1}^\infty \frac{B_{2k}}{(2k)!}(f^{(2k-1)}(b)-f^{(2k-1)}(a))+R $$
In this case, $f(n) = 1/n$ and the above summation reduces to
$$ \sum_{k=1}^n \frac{1}{n} = \log n + \frac{1}{2} + \frac{1}{2n} + Other_{terms} $$
Show that the $Other_{terms}$ is positive. For this you need the definition of Bernouli numbers, the $(2k-1)$-th derivative of $1/x$ and the definition of $R$
- 19,424
I'm sorry but I would like you to add something to this so that common high school student as me can understand.. – Gymnast Nov 10 '17 at 08:53
Well this is definitely not a high school pre calculus level problem even though the question itself may look simple and cute. So I am sorry but there is no choice for the problem solver other than a skill upgrade – Nilotpal Sinha Nov 10 '17 at 09:00
$$\gamma\stackrel{\text{def}}{=}\lim_{n\to +\infty}\left(H_n-\log n\right)=\sum_{n\geq 1}\left(\frac{1}{n}-\log\left(1+\frac{1}{n}\right)\right)\tag{A}$$ Now we may exploit the following facts to derive an integral representation for $\gamma$: $$ \frac{1}{n}=\int_{0}^{+\infty}e^{-nx}\,dx,\qquad \log(n)=\int_{0}^{+\infty}\frac{e^{-x}-e^{-nx}}{x}\,dx\quad(\text{Frullani})\tag{B}$$
$$ \gamma = \int_{0}^{+\infty}\left(\frac{1}{e^x-1}-\frac{1}{x e^x}\right)\,dx =\int_{0}^{1}\left(\frac{1}{\log x}+\frac{1}{1-x}\right)\,dx$$ By the (generalized) Shafer-Fink inequality we may derive arbitrarily accurate uniform approximation for the $\arctan$ and $\text{arctanh}$ functions, hence for the logarithm. We have, for instance, $\log(x)\geq \frac{3(x^2-1)}{x^2+4x+1}$ for any $x\in(0,1)$. By plugging in such inequality in the previous integral representation we get $$ \gamma \leq \frac{1+\log 2}{3} = 0.564382\ldots \tag{C1}$$ while by plugging in the improved inequality $$\forall x\in(0,1),\qquad \log(x)\leq \frac{45(x^2-1)}{7+32(x+1)\sqrt{x}+x(12+7x)}$$ we get: $$ \gamma \geq \frac{71-65\log 2}{45} = 0.576565\ldots\tag{C2} $$ This method can be used for producing even sharper approximations, see here.
- 353,855
$$ \left(\sum_{k=1}^{n}\frac{1}{k} -\log (n+1) \right) $$ has the same limit but is strictly increasing in $n.$ As soon as $n = 6$ the expression above is larger than $\frac{1}{2}.$
An alternative, using a little less, is if you can prove $$ e^3 > 20. $$ YES. $$ e > 1 + 1 + \frac{1}{2} + \frac{1}{6} + \frac{1}{24} + \frac{1}{120} = \frac{326}{120} = \frac{163}{60}. $$ Now, $$ \left( \frac{163}{60} \right)^3 = \frac{4330747}{216000} > 20, $$ as $20 \cdot 216000 = 4320000 < 4330747.$ $$ e^3 > 20. $$ And so $$ \log 20 < 3. $$ We have, which can be estimated by hand, $H_{19} > 3.54,$ after which $ \log 20 < 3 $ tells us that $\gamma > 0.54$
Fri Nov 10 11:54:52 PST 2017
1 harmonic 1 above 1 below 0.306853
2 harmonic 1.5 above 0.806853 below 0.401388
3 harmonic 1.83333 above 0.734721 below 0.447039
4 harmonic 2.08333 above 0.697039 below 0.473895
5 harmonic 2.28333 above 0.673895 below 0.491574
6 harmonic 2.45 above 0.658241 below 0.50409
7 harmonic 2.59286 above 0.646947 below 0.513416
8 harmonic 2.71786 above 0.638416 below 0.520633
9 harmonic 2.82897 above 0.631744 below 0.526383
10 harmonic 2.92897 above 0.626383 below 0.531073
11 harmonic 3.01988 above 0.621982 below 0.534971
12 harmonic 3.10321 above 0.618304 below 0.538261
13 harmonic 3.18013 above 0.615184 below 0.541076
14 harmonic 3.25156 above 0.612505 below 0.543512
15 harmonic 3.31823 above 0.610179 below 0.54564
16 harmonic 3.38073 above 0.60814 below 0.547516
17 harmonic 3.43955 above 0.606339 below 0.549181
18 harmonic 3.49511 above 0.604736 below 0.550669
19 harmonic 3.54774 above 0.603301 below 0.552007
20 harmonic 3.59774 above 0.602007 below 0.553217
21 harmonic 3.64536 above 0.600836 below 0.554316
22 harmonic 3.69081 above 0.599771 below 0.555319
23 harmonic 3.73429 above 0.598797 below 0.556238
24 harmonic 3.77596 above 0.597904 below 0.557082
25 harmonic 3.81596 above 0.597082 below 0.557862
26 harmonic 3.85442 above 0.596323 below 0.558583
27 harmonic 3.89146 above 0.59562 below 0.559252
28 harmonic 3.92717 above 0.594967 below 0.559875
29 harmonic 3.96165 above 0.594358 below 0.560456
30 harmonic 3.99499 above 0.59379 below 0.561
31 harmonic 4.02725 above 0.593258 below 0.561509
32 harmonic 4.0585 above 0.592759 below 0.561988
33 harmonic 4.0888 above 0.592291 below 0.562438
- 139,541
Maybe you can show that $\sum_{k=1}^{\color{red}{n-1}}\frac{1}{k}-\log n$ converges to the same limit, but is increasing in $n.$ Then you can get arbitrarily good lower bounds by calculating this sequence for large enough $n.$
- 25,286
